Question about Epson Perfection 1250 Flatbed Scanner
Program opens off screen
When I open my scanning program window from the lower task bar it shoots up to the upper left of the screen and goes off screen , the computer says its open but I cant see it or access it only shut it down and it has scans in it !!!help
  • 26 Answers
Right->click your desktop and goto properties. Make the resolution of your monitor bigger, then open the program. This should allow you to grab the program and move it. Lower the resolution, and close the program. It should open in view now.
Posted on May 07, 2008
Office H&S 2013 purchased at Officeworks,installed on my desktop, but I need to put the icon on my screen. I find about 100 answers to Search on This PC -some updates others ? I had Excel on my
I assume you have Windows 8.1 as your OS. Unfortunately, the new OS doesn't add new programs to the Desktop, Task Bar or Start Screen. The best way to find the new programs is on the Start Screen. If you are in the Desktop, press the Windows key on the keyboard or the Start button in the lower left hand side of the screen. On the Start look between the Tiles and the Task Bar on the left side of the screen for an arrow that points downward. (You may need to move the mouse pointer.) This will bring up the All Programs list. Depending on your settings for the Start Screen, you may need to scroll past the Tiles for the non-desktop programs. Then you will see a list of Desktop programs organized by program manufacturer. All of the Microsoft Office software icons will be under the Microsoft Office header. If you right click on the Excel icon, you will be able to "pin" it to the Start menu or the Task bar. Repeat this for the other Office programs if you want them pinned. Another choice from the right click menu is to "Open File Location". This will open the File Explorer on the Desktop to the folder with the specific Office program. If you right click on the Application icon (the .exe file) and drag it to the Desktop, you will see an option to create a shortcut right there.
Once you have created the shortcuts on the Desktop or pinned them to the Start Screen, you may need to move them around. Just drag them to a more convenient location. On the Start Screen, all new Tiles are put to the very right hand side of the list. This may require scrolling several times to reach them. Holding the left mouse button will let you drag the icon.
I hope this helps.
(You can also find the Office Programs by just searching the folders - but that depends on which version of Office is installed. The default install has been the x32 version, start in the C:\Program Files (x86)\ folder. The 64-bit version will be in C:\Program Files\)
Dec 16, 2014 | The Computers & Internet
My computer wont show my desktop screen after i loggin to user account
LOL, ok it looks like a virus or infection has hidden your desktop or just disabled explorer from showing it.
Lets assume that it's just an explorer issue.
Press and Hold the CTRL+ALT+DEL. This will open the Task Manager. When it opens click the Processes Tab and then click on the column heading Image Name to sort them alphabetically. Look at the items under the Image Name column and see if you see explorer.exe. If you see explorer.exe click it once to highlight it then click End Process.
Next Click File at the top of the task manager window, then click New Task (Run...). When the Create New Task window opens type: explorer.exe and hit OK. The items on your desktop should start appearing. if not that means the virus or infection has them hidden so try the steps below.
Sounds like a virus has hidden your files and folders. When you click start do you see My Computer or is Start not there at the lower left on the screen?
If the Start is located at the bottom left then click it and see if you have things inside of it such as Programs or All Programs, etc.
Try the step below:
Open the Task Manager by clicking Ctrl+Alt+Del. Press and Hold the Ctrl key and the Alt Key, then hit the Del key. Run the Task Manger.
In the upper left hand corner of the Task Manager window click File then select New Task (Run...). When the Create New Task window opens type: explorer.exe and press OK. Look for My Computer on the left when explorer returns the results. Don't click the + sign to the left of My Computer, instead click directly on the words My Computer, then look to the right and you will see Local Disk C. Click on Local Disk C one time just to highlight it, you don't want to open it. Once you have it highlighted in blue go to the top of the window and click Tools/Folder Options/View and look down and select Show Hidden Files and Folders.
Things should start appearing if not you can open the Local Disk C drive and click Documents and Settings (Windows XP) or Users (Windows 7) and look down and find the userid or user folders and Right Click on the Folder and select Properties. Look down for the Attributes near the bottom and if the Hidden has check in the box Remove the Check and click Apply. When Prompted apply the setting to all subfolders so that they too will not be hidden. Depending on the of the folder this might take a few minutes. This should restore you back to being operational.
You should download and run MalwareBytes to get rid of the infection.
Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download andinstall malwarebytes from the sites download.cnet/malwarebytes. When thesite opens up click on the Green Download button on the left. Do notclick the Red Download button, that's junk. When it finishes installing the GuiInterface will open up with an offer to Accept a Trial Version or Decline. CLICK DECLINE you want the totally free version. Run a QUICK SCAN. As it scans, if it finds infections the number will be in red. When it finishes scanning, click SHOW RESULTS. A notepad text document will open up showing you the results. You can close the text document and go back to the Gui Interface where you will click REMOVE SELECTED RESULTS. The objects will already be selected for you. When I finishes removing the objects click ok and it will sometimes reboot your machine.
May 02, 2012 | Dell Latitude D630 Notebook
I need instructions on how to use the hot keys and function buttons
F1
  • Almost always used as the help key, almost every program will open the help screen when this key is pressed.
  • Windows Key + F1 would open the Microsoft Windows help and support center.
  • Open the Task Pane.
F2
  • In Windows commonly used to rename a highlighted icon or file.
  • Alt + Ctrl + F2 opens a new document in Microsoft Word.
  • Ctrl + F2 displays the print preview window in Microsoft Word.
F3
  • Often opens a search feature for many programs including Microsoft Windows.
  • Shift + F3 will change the text in Microsoft Word from upper to lower case or a capital letter at the beginning of every word.
F4
  • Open find window.
  • Repeat the last action performed (Word 2000+)
  • Alt + F4 will close the program currently active in Microsoft Windows.
  • Ctrl + F4 will close the open window within the current active window in Microsoft Windows.
F5
  • In all modern Internet browsers pressing F5 will refresh or reload the page or document window.
  • Open the find, replace, and go to window in Microsoft Word.
  • Starts a slideshow in PowerPoint.
Jan 15, 2011 | Computers & Internet
Please list the different tasks of the function keys
Hi Good day!!! Here are the list:
F1 * Almost always used as the help key, almost every program will open the help screen when this key is pressed.
* Windows Key + F1 would open the Microsoft Windows help and support center.
* Open the Task Pane.
F2 * In Windows commonly used to rename a highlighted icon or file.
* Alt + Ctrl + F2 opens a new document in Microsoft Word.
* Ctrl + F2 displays the print preview window in Microsoft Word.
F3 * Often opens a search feature for many programs including Microsoft Windows.
* Shift + F3 will change the text in Microsoft Word from upper to lower case or a capital letter at the beginning of every word.
F4 * Open find window.
* Repeat the last action performed (Word 2000+)
* Alt + F4 will close the program currently active in Microsoft Windows.
* Ctrl + F4 will close the open window within the current active window in Microsoft Windows.
F5 * In all modern Internet browsers pressing F5 will refresh or reload the page or document window.
* Open the find, replace, and go to window in Microsoft Word.
* Starts a slideshow in PowerPoint.
F6 * Move the cursor to the Address bar in Internet Explorer and Mozilla Firefox.
* Ctrl + Shift + F6 opens to another open Microsoft Word document.
F7 * Commonly used to spell check and grammar check a document in Microsoft programs such as Microsoft Word, Outlook, etc.
* Shift + F7 runs a Thesaurus check on the word highlighted.
* Turns on Caret browsing in Mozilla Firefox.
F8 * Function key used to enter the Windows startup menu, commonly use to get into Windows Safe Mode.
F9 * Opens the Measurements toolbar in Quark 5.0.
F10 * In Microsoft Windows activates the menu bar of an open application.
* Shift + F10 is the same as right-clicking on a highlighted icon, file, or Internet link.
F11 * Full-screen mode in all modern Internet browsers.
F12 * Open the Save as window in Microsoft Word.
* Shift + F12 save the Microsoft Word document.
* Ctrl + Shift + F12 prints a document in Microsoft Word.
Don't forget to vote thanks!!!
Oct 28, 2010 | Fujitsu AMILO PC Laptops
Advise uses of all F Keys.?.
F1
Open the Task Pane.
F2
F3
F4
Open find window.
F5
Sep 30, 2010 | Logitech EX110 Mouse
How to i scan pictures into the computor so i can send them to peoples e-mail????help
If you have a scanner installed, then its easy. follow these steps:
  1. Click the start button and point to all programs.
  2. click on accessories and look for Paint. this is a photo editing software packet that comes with microsoft windows. every version of windows have this paint. It has this icon of a little bucket with painting brushes. Click on it and it will open.
  3. click on files from the menu bar of the opened program.
  4. click on "from scanner or camera". This will locate your installed scanner.
  5. select your scanner from the list if it gives you options else you will see the scanning interface open.
  6. click on preview on the lower right part of the open window. this will display the preview of the picture you have placed in the scanner's bed.
  7. Use your mouse to adjust the screen to the portion you wish to scan.
  8. click on scan and wait. the scanner will scan you picture and send it to the paint program you opened.
  9. click on file from the manu bar and select save or save as to save your picture. note the location were you are saving it or direct it to were you want it to save.
  10. open your e mail and click on attach under the compose mail window. browse to the location of your saved scanned picture and you are set to go. cheers.
Apr 15, 2009 | Office Equipment & Supplies
Program columns are out of place
See if you can click and drag the start menu bar back to the bottom of your screen and then try to do the same for your program panel to attach it back to your start menu bar.
Also make sure your task bar is not locked by right clicking on it and seeing if there is a check next to it.
Dec 12, 2008 | Dell Inspiron 530 Desktop Computer...
Trouble shooting
it is because of some virus so u try some best antivirus programs to fix it
Jul 25, 2008 | Microsoft Windows XP Professional With...
HP Director won't open. I am on XP and IE7
HP Director has a flaw and is not compatible with IE7
I have a psc 1100 and I had to update my software from HP
CHECK THIS OUT
Go to HP, this link, type in your printer model #.
It still may fail to show...if it does not show HP recommends this
work around.
Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
  1. From desktop, double-click the HP Director icon to load the program into the memory. HP Director will not open at this step. Do not click anything else on the screen until Step 2 is completed.
  2. Press the Alt key and the Space bar together, and then select Minimize from the menu that appears at the upper left corner of the window. If necessary, click it again until HP Director minimizes. HP Director software displays as an item on the task bar (the row of open software programs that appears at the bottom of the desktop screen).
  3. Click HP Director on the task bar. The software opens and displays normally.
  4. Repeat Steps 1 through 3 every time you use HP Director.
    NOTE: The HP Director window might appear larger than normal, but the software is functional.
Cause In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software on products introduced after 2004, is compatible with Internet Explorer 7 and does not exhibit this issue.
Apr 30, 2008 | Computers & Internet
HP PSC 1315
If the patch or the updates did not work on the link I sent you try this Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
Mar 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
Epson Perfection 1250 Flatbed Scanner Logo
592 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
