Mp3 player i have a wharfedale 1gb mp3 player code (513/5530) i formated it and when i try to turn it on it sayz profile needs 4mb please help it was a birthday present
  • Anonymous May 04, 2009
    tried to farmat the mp3 player (same model) format failed and i got the same message saying it needs 4mb for profile
Look on the back of the player. Tou will see a little pin hole with the word "reset" next to it.
Push a paperclip or other suitable pointed object into the hole and hold it for a five seconds.
This will reset the system to factory settings.
Away you go.
Posted on May 05, 2009
How do you upload music on to a wharfdale mp3 player model no:513/5530 please
Posted on Jan 28, 2010
Why when i turn my mp3 on it says profiling requires 4MB free space then shuts down??
hi, try to format the mp3 first, if doesnot works, reset the mp3 to factory settings , if you do that you loose all datas that you put in the mp3
Aug 12, 2010 | RCA JET S2002 MP3 Player
Mp3 player says profiling requires 4mb freespace
Format you device by connecting it to computer ... and it will get fine
Jun 30, 2009 | RCA M4002 Digital Media Player
Profiling requires 4mb free space; reformat required
1. Disconnect the player.
2. Download the new driver from http://support.rcaaudiovideo.com/
3. Install the software on your computer, then run it.
4. Reset your player by either pressing the reset button or removing the AA-battery from the player.
5. While holding down the "Play" key on your player, connect it to the PC via the USB cable. Release the "Play" key when you see the progress bar moving and "initializing" text. If you cannot see the "initializing" text, please disconnect your player and try again.
6. Click the "Start" button to upgrade your player
Jun 02, 2009 | RCA JET S2002 MP3 Player
Straiten the end of a paperclip and push it into the reset hole on the back. When you turn it on, it should operate as normal without any data loss.
Nov 13, 2008 | RCA OPAL M4001 MP3 Player
Sansa clip says i must free 4mb then switches off
You should format the device using windows media player or the device itself..that should fix the problem you are having..remember formatting will delete all the date you have on the device..
I hope that helps
Please rate accordingly
Thank you
Computerrep
Sep 19, 2008 | SanDisk Sansa Clip MP3 Player
Problem with My SanDisk Sansa m230
try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
Feb 21, 2008 | SanDisk Sansa m230 MP3 Player
Profiling
Reformat - corrupt db
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Feb 15, 2008 | RCA OPAL M4001 MP3 Player
RCA OPAL M4002A says it needs 4MB
You may be able to download new firmware to it. Try that it might help.
Jan 15, 2008 | RCA OPAL M4001 MP3 Player
Not enough room for music database please free 4 mb
The device needs at least 4MB of free space.
You need to keep deleting files until there is 4MB less than the total capacity of the device.
Its not syncing because the device is too full.
If removing the 4MB doesnt work. Try formatting the device thru My Computer>Device Name (m200)>Right Click and select FORMAT.
Best of Luck.
Please RATE my solution BELOW.
Nov 20, 2007 | SanDisk Sansa m200 SDMX3-512 MP3 Player
357 people viewed this question
 Grubhead
Grubhead
