Question about Haier hwr10xc6 Air Conditioner
My air conditioner say E2 and wont do anything what could be wrong and what can i do to fix it
  • Haier Master
  • 43,501 Answers
The E-2 code is similar to the E-1
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Posted on Aug 29, 2010
I have a ge air conditioner model AHM24DPH1 WITH an error E2 / E1. What do I do to possibly fix.how do I reset maybe
E1 is humidity sensor error unplug unit and then plug it back in.
E2 is Temperature sensor error unplug unit and then plug it back in this will clear codes. if codes come back on then you will need to replace sensors.
Jun 24, 2014 | Heating & Cooling
I have an TCL aircon and it comes up with a message E2 and then switches it self off, the aircon is about 8 months old can someone help me with whats wrong with it please and thanks :)
TCL provide a 5 year warranty. i would suggest you contact the nearest Agent. An E2 error from what I remember is an overheat / overpressure problem. Check your filters on the indoor unit. If they are blocked, this error could appear and it wont be a warrantable fault...
Jul 14, 2011 | Turboair TAS-24H Split System Air...
I have an E2 error code, how do I resolve this
I simply disconnected my battery to reset the thermostat and my E2 problem fixed itself...
Jun 07, 2011 | Dometic Rooftop RV Air Conditioner
I have an E2 error message on my air conditioner. It has stopped working and resetting it doesn't help.
means you have less that 24 volts to thermostat check transformer or wireing to tstat
Aug 13, 2010 | Goodman CLQ36AR49 Air Conditioner
Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
Jun 29, 2009 | Carrier 38CKC060 Air Conditioner
E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Jun 13, 2009 | Haier Mechanical Air Conditioner HWF05XC7
Air conditoner won't go on and receiving E2 message on panel
E2 code is 24 volts loss. Check transformer and control voltage should be 24 volts.
Jun 05, 2009 | Carrier 38CKC036 Air Conditioner
Error message
Type in haier unit page, then,to Haier-model # or go to http://www.haieramerica.com/techsupport.
Jun 13, 2008 | Haier Energy Star ESA3183 Air Conditioner
Haier hwr10xc6 Air Conditioner Logo
418 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
