Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
My model # is 59679272993 and I need to know how I would get the cover off of the light in the top?
The power head of my 1165581590C Kenmore Power mate Whispertone 12 amp vacuum won't open. It is an older model and it desparately needs a clean!
I am not 100% sure of the model number but most of their powerheads come apart quite easily if you know how. There is a light lens cover on the top of your powerhead. On each side of this cover there is a little clip that holds it in place. You can usually see that spot by simply taking your thumb and pushing the light cover to one side or the other. Place a small flat head screwdriver in that slot and gently pry upward.
Once that cover is off, you will see two screws. Remove those two screws. Now simply grab each side of the cover towards the bottom and back of the nozzle and pull out. This should release it from the base. It will lift from forward from back to front..
Reassembly is pretty easy. Just reverse the instructions.
Let me know if this helps.
Dec 30, 2012 | Vacuums
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Honeywell Thermostat. I don't know the model number, but it states "replace battery" and no longer lights up. The problem is I don't know how to remove the cover. Please advise
DEPENDING ON THE TYPE OPEN COVER AND LOOK FOR 2 SCREWS IN THE LOWER CORNERS. OTHERS WITH NO SCREWS LIFT OFF FROM BOTTOM TO TOP BY PULLING OUTWARD ON BOTTOM. DONT FORCE LOOK IT OVER. WILL NEED TO REPROGRAM WHEN DONE.
Jan 05, 2011 | Honeywell Programmable Thermostat Heater
What is the capacity of kenmore refrigidare 596.79272993
Made by Amana, age should be over 10 years old. Users manual:
http://www.managemylife.com/mmh/owner_manuals/search?sid=MMHMxSearsx00019&query=59679272993+KENMORE
Many replacement chassis / cabinet parts not available. Common items are still available.
Have tried using multiple sources for size computation including parts look up. Most come up with 22.4 Cu ft
Kelly
Sep 22, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Does anyone know how to replace the light inside the oven? not the light that shines down. The oven does not light when you use it. The GE manual does not seem to have any information on this or any of...
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If there's no obvious removable cover over the bulb and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs (and 20A ceramic fuses) can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Jul 09, 2009 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Light out
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Mar 14, 2009 | Sanyo Microwave Ovens
GE xl1800 active vent bulb replacement
I think the key is pulling the vent to the left.
From page 36 of the online version of the owner's manual, which also mentions the active grille's presence on some models:
Oven Light
GE supplier.
or pull the plug.
cover off.
cover.
power to the oven.
Jan 10, 2009 | GE JVM1870 Microwave Oven
Please could you let me know how to change the light bulb in my Panasonic microwave
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Sep 14, 2008 | Panasonic Microwave Ovens
The interior light has blown in my Panasonic microwave. There is a plastic cover inside - is this the way in or do I have to unscrew the back of the unit
It depends on the model number.
If there's only one cover inside, it is the waveguide cover, not the light cover.
Sep 08, 2008 | Panasonic Microwave Ovens
Light as gone out on my pacific microwave and do not know how to get to or change the bulb there are screws around the casting but thats it
If you don't have your instructions, please reply back with your brand and model number.
Sep 02, 2008 | Microwave Ovens
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
67 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
