Question about RCA RS2640 CD Shelf System
Tape Deck in Car
I just bought a cassette adaptor to play my ipod in my car. I've used one before, and it worked fine, but I've lost it since then. So I just put the new one in, and right when I put it in, it started making a loud buzzing noise. The sound definitely comes directly from the tape player, because the music still plays through my ipod and sounds perfectly clear through the speakers. I was wondering if there was possibly an easy way to fix this.
  • Clayton4 Dec 06, 2008
    I have the same problem in my car. I had been using the same cassette adapter for some time and it's been great. Just last week it started with this very loud buzzing and I can no longer distinguish an music being played.
    I've tried regular cassette tapes and I have the same issue occur.
    Has anyone ever found a solution?
  • Anonymous Mar 20, 2014
    I am wondering if perhaps a button got pushed that would make the tape player seem paused. Hoping for an easy fix.
  • 476 Answers
Sounds like a poor "connection" between the cassette head and the head in the adaptor.
This could be caused by either head being dirty, or the tape head may be mis-alligned.
You can clean the heads with a proprietary head cleaning fluid.
Check with a standard tape.
Also, if your head unit supports it, switch the auto-reverse control. Some adaptors have dual heads for auto-revers decks, and some only have a single head.
Posted on May 08, 2008
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
Tip
How can I connect an iPod to work through a car stereo?
<p>An iPod can store hundreds of songs makes it an ideal source for music on your car. Buy an adapter is the easiest and cheapest way to connect your iPod to your car stereo system. Do you know which adapter fits you best and know how to use the first steps to expand their musical possibilities. <br /> <p><br /> <p>Tape deck <br /> <p>1. Buy an iPod adapter cassette player, if your car has a cassette player. This is one of the easiest and cheapest way to get your iPod to play music from a car radio. A cassette adapter is shaped like a tape with a wire connected to an end. <br /> <p><br /> <p>2. For a cassette adapter or a store of electronic music in good standing. This adapter is relatively easy to find and can usually be purchased for less than $ 20. <br /> <p><br /> <p>3. Slide the cassette tape in the car. Take the end of the cable and connect the headset to your iPod. Select a song to your iPod and press the "Play". Be sure to order the car stereo's cassette player. <br /> <p><br /> <p>FM Transmitter <br /> <p>1. Purchase an FM transmission adapter if your car has a cassette player. This type of adapter connects to both your iPod headphone jack or car cigarette lighter and stream music via FM radio signal. <br /> <p><br /> <p>2. In an FM adapter to send any electronics store. This adapter is a little more expensive than a cassette adapter. Make sure you have an FM transmitter instead, for many FM stations broadcast from a transmitter can only be transmitted to a unit to buy. This gives you more options when you're in certain areas where FM stations are vague or nonexistent. <br /> <p><br /> <p>3. Connect the FM transmitter for the iPod to a lighter (depending on model purchased). Turn on your car's FM radio and find a channel that is unoccupied. Adjust the transmitter to the channel number exactly the same and then to match the iPod. For example, 99.1 FM if you find a free channel in your area, the FM transmitter on 99.1 reading. Connect the iPod and press "Play." <br /> <p><br /> <p>Extra- <br /> <p>1. Purchase an additional cable if your car has an auxiliary input panel. This type of iPod adapter is one of the easiest ways for your iPod to play music in the car. <br /> <p><br /> <p>2. Find a reputable shop and buy an electronic overhead. This type of iPod adapter is usually sold for about $ 10. <br /> <p><br /> <p>3. Connect the cable to the extra auxiliary input on the dashboard of your car and plug it into the iPod headphone jack. Make sure the sound of the car is in standby mode. Select a number and press the "Play" button on the iPod to the music to start. <br />
on Aug 09, 2011 | Apple iPod touch
Tascam 302 Tape Deck - When I press play it rewind/fastfoward
There is either a cam belt that is lose or the flywheel assist can not move the head base due to hardened grease. It needs to be serviced.
May 16, 2013 | Tascam 302 PRO DUAL CASSETTE DECK Single...
I have a 2003 Jeep Liberty Limited and when I try to put the cassette adapter into the player it just clicks like its checking both sides of the cassette then says error and pushes it back out.
Does the tape deck work fine with a regular tape? If so, you may be using an adaptor that is incompatible with your tape deck. If not, you may have a bad belt or motor. To see if the adaptor is is compatible with your deck remove it and try to turn the gears in the adaptor, if only one turns when you turn it, it will probably not work.
May 22, 2012 | Jeep Car Audio & Video
E 10 tape deck error/ tapes keep spitting out
The radio checks to make sure the drive capstan is turning - if not, gives the E10 error. Either the drive belt in the radio is slipping or the drive wheel in the adapter is sticking. If it does it with a real cassette, then it's probably the drive belt. If not, you can try to figure out why the wheel in the adapter is not turning freely.
Jun 21, 2017 | 2001 Oldsmobile Intrigue
I have a JVC KD-95 Cassette Deck. My left speaker Comes and goes lots of crackling. When I turn off the deck it crackles loudly then fades. my speakers work fine when using cd, radio etc.
Probably it's the playing head; must be damaged or worned out.. Accept fact; cassette players are outdated. make a listing of your favorite music and stat finding them on line.
By the way, even youtube rips are better quallity then thos cassette recors.
Aug 23, 2011 | JVC TD-W118 Single Cassette Deck
Cannot play ipod on 2000 malibu using tape adapter. malibu has cd player and remote tape deck
Instead use a radio adaptor where you would set you radio to a particular channel. The adaptor emits a signal correspondent to that radio signal and allows you to listen to your iPod.
Jul 08, 2009 | 2000 Chevrolet Malibu
1995 Saab 900S Left speaker doesn't work when using tape player
sounds like the cassette adapter has a bad channel, or didn't fully seat into place. Try removing and re inserting, to play the other side of the adapter if the wires will allow it. Then auto reverse the cassette deck to allow a different portion of the cassette head to be used for the signal. Those cassette adapters are poor quality, and put alot of time on the mech.
Jul 12, 2008 | 1996 Saab 900
CDR/ipod Not Connect wondow message
Select another function, fx V. Aux, then press menu-button. The display should then show "Ipod assign". Use select to find "Ipod: none" and press Enter...
Mar 01, 2008 | Denon AVR-2802
RCA RS2640 CD Shelf System Logo
1,092 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
