If you phone has English language file (if it came with the firmware) then this sequence would help you change the language.
Press the "Menu" button and locate the "Settings" (should look like a spanner), press "Ok" or "Select", once it's opened, locate the "phone settings" (it looks like a phone receiver or like a mobile handset) using the up and down key, open it and then the again select the first from the list (that should be theLanguage settings), once it's opened, you'll see the english language written in english as "English", select it [or you can just select "Automatic" if it's default language was "English"]. Now, the language of your mobile will change back to English.
If you need further help, let me know with more details.
Good luck.
Thanks for using FixYa.
