JVC AV-32F577 No Vertical
I have a TV that has no vertical, has sound and has good hortizontal (rgb) line in the center, I was thinking a cap might be out in the circuit. Any ideas on which caps might be out.
Thanks,
Joey
  • 975 Answers
Need to replace the VERTICAL OUTPUT IC or transistor, hope this helps , please rate thanks AJ
Posted on May 07, 2008
AV-20920 thin horizontal line
hi, usually the cause in jvc tv is, a bad contacts on the vertical chip leges. you should solder those contacts. another option is to change the vertical chip . more rare is a missing of the 27v voltage that goes to the chip. in that case you should check the port of the high voltage transformer.
good luck!
Feb 14, 2011 | JVC AV-20920 20" TV
Video just reduced to a tiny horizontal line across the screen. sound is fine, what could be the problem? jvc tv model av-32720
You have a bad vertical IC at its worse or one that may need resoldered. Be sure to check the grounds on this IC and check for rings around the pins. And you can bet in the immediate area you have bad capacitors that created a hot vertical IC. This will cause the Vertical IC to break down!
May 02, 2010 | JVC AV-32720 32" TV
White line across center of screen
cold solder in vertical ic or bad.
Apr 03, 2010 | JVC AV-27820 27" TV
JVC AV-27920 white horizontal lines on top of the screen
YES THERE ARE 3 CAPS. 2 ARE SMALL ONE LARGE IN THE VERTICAL CIRCUIT. 1 OR 2.2 uF AND A 1000uF. ALL ARE VERY CLOSE TO THE VERT. IC AND YOKE PLUG. PHYSICAL EXAMINATION SHOULD SHOW WHICH ONES DRIED OUT AS THE HEAT SHRINK WRAPPING AROUND THEM PEALS UP. ALSO WHEN YOU UNSOLDER IT YOU MIGHT SMELL "STINKY FISH" AS THE ORGANIC ACID INSIDE IS LEAKING OUT THE BOTTOM. LOOK FOR BROWN OOZE ON THE LEGS ALSO.
Dec 27, 2009 | JVC AV-27920 27" TV
I have a JVC AV-32950 and have lines running across the top 3 - 4 inches of the picture. The picture also goes black on occassion and I have to hit the top of the TV to get the picture to come back. While...
It may be a dry solder point somewhere near the vertical IC. First take look at the solder points and if you found cracks pls resolder it. if the lines continous you have to replace Caps near the vertical or circuit.thank you
Nov 23, 2009 | JVC AV-32950 TV
No video on my JVC AV-30W475 30" flat screen.
It sounds like you have bad solder connections in the Vertical circuit or the horizontal circuit. The Vertical IC may need to be replaced if resoldering does not help.
You will need to call a good TV Tech for this repair.
Aug 09, 2009 | JVC AV-30W475 30" TV
Jvc av-32wf36--have sound no picture
A bright Horizontal Line indicates failure of teh Vertical deflection Circuits.
Get a competent Technician to have a look.
Nov 30, 2008 | JVC AV-27230 27" TV
No picture
try resoldering vertical output ic pins, no vertical deflection will shut off picture. may need ic replacing along with electrolytic cap.
Apr 22, 2008 | JVC AV-32260 32" TV
Is it fixable
your tv has a problem with vertical deflection circuit. probably the ic or capacitors surrounding the vertical ic. have it check by a qualified technician. good luck
Jan 07, 2008 | JVC AV-27D305 27" TV
Jvc av-27730 27"
One thing you should not do with electronic devices which have a start up proceedure is to turn the power off, and then on again without a wait of about five minutes. Some equipment manuals warn you about this, and specify a longer period. The start-up has to have time to reset. It will be more likely to reset if you do not leave it on standby, and even unplug it. In your TVs case you need to describe the distorted picture as it may give a clue to a fault, or incorrect start-up. The horizontal line indicates the frame timebase had stopped working. No picture could be a fuse blown inside the set, or a timed cutout which may reset after a time. Try after several hours to see if it comes on. If it is just the frame timebase (vertical) it is worth repairing.
Oct 22, 2006 | JVC AV-27230 27" TV
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
