Question about Whirlpool Refrigerators
The ice maker wont drop the ice - Whirlpool Refrigerators
    Champion:
  • 274 Answers
Try this pour Hot water in ice maker it may be stuck then see,if blades turn there could be something stuck in ice maker.write back (I had a piece of plastic bag get stuck on the rotateing blades that push the ice up to the drop tub underneath) I hope this works for you
Posted on Aug 29, 2010
  • 1073 Answers
SOURCE: Ice Maker Won't Drop Ice
you have a problem in the module of the ice maker if it is new take it back for a new one
Posted on May 02, 2008
rickzilla
  • 706 Answers
SOURCE: Ice maker not working
Depending on the ice maker style, they typically work off a motor timer. The timer motor rotates to set up the ice making process... starting with letting water into an empty ice mold tray, allowing ample time for that water to freeze and then to rotate that mold so that the cubes fall out into the bin. In conjunction with that process, a small heater is turned on to release the frozen cubes from the tray. The 'ice tray full' lever signals the system to stop making ice so you may want to verify that the lever is down and not causing the ice maker to stop, If that's down then I suggest you monitor the position of the motor gearset underneath an access cover. With power applied, the gears should rotate and cycle thru an ice making process. If it does and ice fails to fall out, your heater may be defective. Hope that helps...
Posted on Aug 06, 2008
ngfam1
  • 639 Answers
SOURCE: Ice maker
Friend,
ngfam1 At your service!
There are many parts in this component that may be the culprit .
One or more will need to be replaced.
This is not easy to diagnose. I've seen service order parts 2 or 3 times till they completed the ice maker repair on a side by side fridge!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Posted on Aug 31, 2008
docjohn174
  • 943 Answers
SOURCE: My amana sise by side fridge wont drop the ice
hi thanks for the question probably have a problem with ice maker the timer in ice maker is not advancing to the drop off cycle need a new ice maker thanks the appliance doc
Posted on Sep 18, 2008
EllaWatson25
  • 725 Answers
SOURCE: the ice maker wont drop the ice
You need a new ice maker on this unit. They only last about 2 years or so. Call us and we'll be sure to get the correct part out to you right away. We hope to hear form you real soon.
Posted on Oct 10, 2009
My kenmore 106.51133210 refrigerator is not making ice
Try filling the ice maker with tap water until the tray is full allow it to freeze turn on the ice maker and if after the water freezes it drops the ice into the ice container then replace the water control valve found at this link below
Water Inlet Valve WPW10341320
If after the water freezes with the ice maker on it does not drop into the ice bin then replace the ice maker itself part number below
Ice Maker Assembly WPW10251076
Thank you
Appliance 911 Sea Breeze
May 06, 2016 | Kenmore Refrigerators
Newly installed ice maker two days old, not dropping ice, frididaire refridgerator
Ice maker under warranty have them look at it will not cost you anything.
Aug 29, 2014 | Kitchen Appliances - Others
Wont make ice
For the moment I would like you to fill the ice maker with tap water unless the cubes are stuck there. Most times the water control valve on the rear are the problem. One side feeds the dispenser and the other feeds the ice maker. Model number Y13068002 Let me know if it will drop ice after filling tray with water. If not the focus will be on the ice maker. During that time I will get you a service manual if correct model number and a place to find parts to get yu going again, Thanks, Se Breeze
Jan 15, 2010 | Refrigerators
Oct 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Ice Maker Has Stopped Making Ice
Hi: I didn't see the simple first solution to try in your list. The ice maker is thermally protected. It won't make ice until the freezer is at 0degrees F. Set your freezer lower in temperature. It may seem cold to you but it has to be at 0degreesF. Frozen at 32 degrees wont cut it. Please don't open the door every 5 minutes to see if it's made ice, as it will raise the temperature. It appears in your question that you listen for the ice to drop. That's the right way. Give it a day to drop in temp. before resetting the temp. This is a free try before you have to call a technician. I hope this helps, Jeff
Jun 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
ELECTRICAL DIAGRAM
take a blow dryer and defrost the ice maker for a few minutes and see if it starts to work
when the water was off it usually freezes the last few drops of water in the ice maker and wont let water in after you reconnect the line
Apr 13, 2009 | Freezers
Jul 03, 2008 | Amana 22.6 cu. ft. Side-By-Side...
May 02, 2008 | Refrigerators
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
260 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
