Question about Whirlpool LSR6334LQ Top Load Washer
Have a whirlpool toploader #LSR6332KQO, doesnt complete cycles and cant even get water to drain and go into spin cycle???
  • 1314 Answers
SOURCE: whirlpool wont spin or drain...
something is jamming your drain pump Well I'm going to do my best to fix your washer. First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub.Rmove the spring clamp pull the hose now you may or may not have to replace the pump depending on if you can remove the object.
Posted on Jan 17, 2008
revamos
  • 16 Answers
SOURCE: whirlpool top load washer model # LXR7133JQ1
it's the spin tube or the cluch cant take the heavy loads
Posted on Apr 20, 2008
  • 1073 Answers
SOURCE: washing machine spins but doesnt drain water until I turn it back to spin only
timer contacts are burnt replace the timer
Posted on Jun 13, 2008
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
localwonder
  • 6784 Answers
SOURCE: Washing machine will not complete spin cycle
OK, what you are experiencing is a timer mechanism fault. the timer motor is malfunctioning. anytime you have to manually advance the timer knob, this will signal a fault within the control mech. this is easily fixed by, replacing the timer control module. i will place a link to the actual part needed to fix this issue. you can also purchase this timer on line at this site if you wish.
CLICK HERE
Posted on Jun 18, 2009
Lsr6332kqo shutting off
Please be more detailed. At what part of the cycle is it shutting down? Is there still water in the tub or did it drain? Or did it just fill then stop without washing/agitating?
Jul 19, 2016 | Whirlpool Washing Machines
Kenmore topload washing machine that wont switch to drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Seem like its not draining. soapy water when finished cycle.
found a kink in the drain hose, shortened hose-problem solved.
Mar 22, 2009 | Dishwashers
Washer will not drain or spin after wash cycle
Probably your filter or drain pipe is blocked. You have to clean out.
Click on your model number (below FIXYA) on this website, type in & search. You will get a shortlist; click on your model, below the page you will get Manual/Guides. Click on the blue, you have your manual on line. If available that is............
Feb 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
10yr whirlpool toploader wash machine no spin/agitat. but works?
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 08, 2009 | Whirlpool Washing Machines
GE toploader Washing Machine pumping problems
Sounds like the water is syphoning away due to the drain outlet hose being too low..Raise the hose higher, and this should solve the poroblem.
Oct 31, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Whirlpool LSR6334LQ Top Load Washer Logo
223 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
