Question about LG DLE2514 Electric Dryer
Dryer is not drying and how can u tell if heating element is gone
  • LG Master
  • 7,482 Answers
Locate your heating coil...
Remove the two wires from the terminals of the heating element.
Using an Ohm Meter set it to check for continuity accross the two terminals.
If you Ohm Meter buzzes or shows continuity across the terminals then the coil heater is good.
Please Rate Me
Posted on Aug 29, 2010
Kenmore dryer won't dry
If you are not getting any heat at all then I would suggest looking at your thermostats, as one of them may have gone bad and that could have cut power to the heating element. If you do have some heat but things still do not dry well, check your exhaust duct to make sure that it is clear of any obstruction. Also make sure that it is not crimped if you have a flex duct on your dryer.
Jul 24, 2014 | Kenmore Dryers
Dryer wont heat. how can I tell if it is the heating element
If there is no heat at all, it is the heating elment is most likly broke a wire in the elment. Be safe. Vern
Apr 26, 2014 | Dryers
Electric dryer tumbles but does not dry clothes on any setting. dryer is only 4 yrs old.
Heating element has gone bad. You need to unplug unit. remove back, then find heating element and remove it. Look for what looks like broken springs, if found replace element. 99% of electric dryers not drying are the heating element. Cost around $50
Sep 28, 2010 | Dryers
Won't heat up and doesn't shut off
You likely need to replace the element. test the dryer in auto and timed dry cycles. If the element is gone you will have no heat in either.
If the humidity sensor is shot or the dryer vent hose is clogged , the dryer will run forever and not dry or shut off.
Check for blockage first. then run a test cycles on both settings and post back
Sep 13, 2009 | Dryers
Heating element no longer working. dryer still operating except clothes wont dry
it is the theromstats or heater element has gone the only way to tell is to meter them out u need an expert to do this
Jul 31, 2009 | Fisher and Paykel SMARTLOAD DE62TG1...
Heating element gone in our kenmore dryer
Hi, Without having a model # so I can see the exact dry style you have, This is how to get to the most popular style element. UNPLUG the dryer! Remove the rear panel of the dryer and locate the element on the right hand side. Plug the dryer back in and test to see if there is 240V going to the element posts. If there is voltage, but no heat, change the element. If it does not, you need to test the thermostats for continuity. If any of the thermostats are open, replace it. I hope this helps you.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Jul 12, 2009 | Dryers
Dryer is not heating up, it is blowing out cool air
IT IS YOUR HEATING ELEMENT THAT IS GONE IN YOUR DRYER. THE HEATING ELEMENT IS WHAT WORKS TO GET YOUR CLOTHES DRY. CALL YOUR LOCAL REPAIRMAN OR THE STORE YOU BOUGHT IT FROM AND SEE HOW MUCH A NEW HEATING ELEMENT WOULD COST YA.
RODNEY
Apr 06, 2009 | Estate TEDS740JQ Electric Dryer
Dryer leaking water
it sounds to me like the heating element that heats up to dry the clothes has gone faulty or tripped out. Cant really tell from here.. when you open the drier is there a good level of heat ? If not, its the heating element section at fault.
Mar 17, 2008 | Dryers
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer shuts off
If the venting is clogged this will happen. And that is a good thing because it is a safety measure built in to prevent fires. There is a thermostat that can tell when your dryer is over-heating,(usually caused by clogged venting by lint) and this devise tells the heating element to turn off so as not to create a fire. Clean out venting, inspect thermostats and element, replace if neccesary. You may only have to clean out the venting.
Nov 27, 2007 | Kenmore Elite HE4 Electric Dryer
LG DLE2514 Electric Dryer Logo
69 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
