Question about Roper RAX4232KQ Top Load Washer
I have a Roper RAX4232RQ4 Top Load Washer. My washer will not spin enough water out of the clothes. What can I do about this?
  • Roper Master
  • 8,220 Answers
Maybe your pump is obstructed or a hose has a sock in it from tub to pump. How it works Direct drive washer
Posted on Aug 29, 2010
My washer spins but not enough to get the water out of clothes.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 18, 2011 | Roper RAX4232KQ Top Load Washer
My washer spins but will not drain. the pump seems to be working but wont drain
The drain line is probably clogged... sometimes debris or small objects can get in between the tubs and plug the lines...if not, the pump may be bad. I just replaced my pump on my GE washing machine.
May 19, 2009 | Roper RAX4233PQ Top Load Washer
Washer will spin but clothes are still very wet
CHECK YOUR WASHER DRAIN PROTECTOR. GO TO www.repairclinic.com AND ENTER YOUR MODEL NUMBER. SCROLL ALL THE WAY DOWN AND CLICK THE RED 100, THEN LOOK FOR PART 541811. FIND IT AND CLEAN IT OUT. YOU TIMER ONLY ALLOWS A CERTAIN AMOUNT OF TIME TO DRAIN THE WATER OUT AND IF THIS PART IS CLOGGED THEN THE WASHER DOESN'T HAVE ENOUGH TIME TO EVACUATE THE WATER.
Apr 11, 2009 | Roper RAX4232KQ Top Load Washer
Roper washing machine fail to remove enough water from clothes on spin
I had the same problem, I found that my discharge hose was partially plugged and when the water level get down to a certian point it would not drain,
Took me 3 days to figure it out........
Feb 19, 2009 | Roper RAS6233KQ Top Load Washer
My roper washing machine fails to remove enough water from clothes on last spin every thing else seems ok model RAS 7133 KQ 1
Possibly the centrifugal clutch is slipping, would need to be replaced, Go to appliance guru to see how this is done, they have step by step on this procedure.
Kenmore washer spin cycle doesn't leave clothes dry
SOUNDS LIKE THE TRANSMISSION IS NOT ALWAYS SHIFTING INTO HIGH SPEED MODE,TRY A MED. SIZE LOAD AND SEE WHAT THAT DOES,TRANSMISSION MIGHT JUST BE GETTING OLD WHIH IS NORMAL-MIKE
Dec 06, 2008 | Roper RAB2121KW Top Load Washer
Roper RAX4232KQ Top Load Washer Logo
128 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
