Question about Samsung PCL545R 54" Rear Projection Television
I have a 55" samsung tantus pcl545r. and the screen is bowed on the sides and on the left i can see red and yellow and on the right i can see blue and green but the center still seems to have good focus. I was wondering what i can do to fix this if its worth it.
SOURCE: convergence
Im trying to install that same board on the same tv how did you do it?
Posted on Aug 12, 2007
  • 1694 Answers
SOURCE: blue shadow
Needs convergence circuit repair = replace convergence IC's,
then activate Magic Focus...............need step by step?......T.
Posted on Nov 30, 2007
ctf1800
  • 4402 Answers
SOURCE: IMAGE COMPRESSED
double post
Posted on Jan 29, 2008
MrBob84
  • 90 Answers
SOURCE: HX-P4241W appears yellow. Left and Right of screen are yellow
Yellow is the lack of blue. It can happen when you are running your contrast - which is your overall light level - too high.
Try turning down your contrast. On CRT tech, contrast should always be run at half what the factory allows as full, on the user controls. Full up is what calibrators call Torch Mode, and is NOT the way to get performance to be in the linear operating range of CRT tech.
If your sides are more yellow than your middle, your set may need lenstriping. Mild yellow on the sides is not uncommon, and usually not noticed. But heavy yellow on the sides would indicate that the blue image needs work on white field uniformity.
Yellow is the lack of blue, in CRT tech.
Mr Bob
Posted on Feb 04, 2008
Zero-G
  • 33 Answers
SOURCE: blurry.....convergence problem???
I agree with Shuttle83,
except with point #4 and #8,
#4 If you buy OEM Sanyo IC Convergence chips ruff looking black with rounded corners and up them to the next one up they will last longer. if you buy generic shiny smooth black with sharp corners they may only last 5 months. remember you get what you pay for the OEM's are usally $12-15 each, generics are $7-12
#8 you should reset to the factory settings after replacing the Convergence ships before trying to adjust again.
good luck!
Posted on Nov 03, 2008
Tv gets light blueand stays that way...comes back to perfect color the back to blue X-RAy looking it is a samsung pcl545r
Behind the screen, there are three color tubes: Red Green and Blue.
Unfortunately, rear projection screens often have these problems and the tubes do go out after extended use.
Take the television to a TV Repair shop to have this fixed. But in the long run, this may end up costing you a lot more than if you would purchase a new TV. The light tubes are fairly expensive.
Jun 03, 2011 | Samsung PCL545R 54" Rear Projection...
Bows on sides
Try degausing the set with the system software. if this doesnt fix it you will have to degause the set with a professional tool.
Jan 27, 2009 | Mitsubishi VS-55601 55" Rear Projection...
Green bow tie, convergence not helping
Yes, your geometry correction has failed and you will need to seek qualified tech for help. You need what are called STKs and you should be able to get the job done inhome for under 300.00
Craig www.classtorations.com
Jun 08, 2008 | Samsung PCL545R 54" Rear Projection...
Samsung PCL545R Color adjustment!
i'd recommend you return it to your friend..sounds like quite an issue with the innards.
Apr 20, 2008 | Samsung PCL545R 54" Rear Projection...
No green or blue color in pictures!
You need to find a qualified servicer. You have component failure.
Look for TV Repair on craigslist or yellowbook.
Skewed picture
Is it a projection? DLP? LCD? etc... depending on the type the suspicion i have is it is out of focus.  The symptom of writing triplicate comes from the thing being out of wack.. a tech needs to fix it.  all this is assuming ;you have a projection tv of some sort.
Mar 02, 2008 | Samsung PCL545R 54" Rear Projection...
Mr Bob
Feb 02, 2008 | Samsung HC-P4241W 42" Rear Projection...
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Samsung PCL545R 54" Rear Projection Television Logo
79 people viewed this question
Jerry Greenberg
Jerry Greenberg
