Question about Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune mah4000aww 53314036yk
The hot water runs all the time when in a cycle unless you stop cycle? water vavle is ok. has power to vavle at all times when in cycle?
  • 979 Answers
Check the solenoid. It may be bad. This allows the water to come in.
Posted on Jan 14, 2009
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
On my Maytag Neptune MAH-3, the water is running non-stop
check plastic hose out side of tub to pressure switch
if ok replace pressure switch
Oct 12, 2009 | Maytag Neptune Washer
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptne fav 6800 aww does not fill wiht hot water. works fi
Hi Big Wags
I would remove both water hoses at the back of the washer and check the Hot & Cold inlet screens for a clog/restriction.
They look like this;
You can turn the individual valves on in service mode using the procedure on page 16 of the Service Manual.
To enter Service Mode; press and hold simultaneously the Enviro Plus and Spin Only keys for three seconds or until the control beeps and the display reads “00”.
Now go into board output test by pressing the Delicates key.
Now press the Normal button to open the Hot Water Valve you can press the Normal button again to turn off the valve or just press the Off button to end the process. Or just use the wash cycle to toggle the H/C water valves on. I like folks to become familiar with using Service Mode and the SM.
If the inlet screens are free of debris and you have good water pressure from your source valve then you may have to replace the valve assembly Here is a link to check for FAV6800AW PARTS Sears Parts Direct. Shout back If you have questions. Rich
Jan 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune model number mah4000aww
its your pump.get at it thru the back.it may be blocked or may have failed.a volt meter will tell you if its getting voltage.if so should drain,make sure on about spin setting to check.ive had to replace the pump on my neptune
Dec 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
MY NEPTUNE MAH4000AWW WORK WHEN IT WANT TO WORK
Check for low water pressure. Clear screens in inlet valve. Do-not remove screens. This unit will turn off if not filled in specified time.
Nov 08, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Sounds like you have an intermittent problem with the board or one of the on board switches.
Oct 22, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune MDG5500AW Gas Dryer Logo
95 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
