Question about Linksys WUSB54GC 802.11g/b Wireless Adapter
Wireless connection Hi what my ?? is that does a Wireless -N PCI wmp300n work with a Wireless -G Broadband Router ?? because i'm trying to get my neigbor connected to my wireless internet and it say that the connect is unplugged... Please Help Thank you Koretta
    Novelist:
    Scholar:
  • 134 Answers
There are so many possibilities.. The range or distance might be the trouble.. Is the neighbor using a notebook? If so, move the pc to within a few meters of the wireless router, to see if you get a signal. There are lots of other things you can try.. There is detection software to see available networks Eg 'netstumbler', can be downloaded free.. Your router might be setup in such a way, that it limits number of connections or by MAC address.. So you might need to change the configuration in the router. Mostly you can go into the router config. via a web browser like IE (Internet Explorer), just by typing in the IP address of the router.. But you might need to know the IP & user ID & password (if there is one).. So.. you can see there are a lot of things to be done, if you want to solve this problem..
Also here is a possible fix from another user on Fixya.. (to be carried out on the neighbor's pc)
you may have another wireless connection other than your own set as automatic, or more than one connection in your settings of the same name, so right click on your network icon in your task bar or in network connections in device manager and select view all wireless connections, click on it and when all the connections show, highlght, delete all of them, then close the window.
Your notebook should now indicate that it found new wireless connections, click on the popup and select your connection name and click connect, at this point you will be asked to enter the passkey if you have security enabled.
give it a go.. might help. Let me know if you want further help.
Rgds,
Posted on May 08, 2008
Lost my wireless connection. Works elsewhere. Have Windows 7 laptop computer and Linskys wireless-N broadband router Model WRT160N (just 1 yr. old this month. Already tried power cycling, reset IP...
Is the wireless card "ENABLED" in your computer if it is I think you should connect a cable to the computer/router and log in to the router to see if something has changed in the setup for the wireless settings.
Nov 14, 2010 | Computers & Internet
I have wmp300-n card. I install card (software & drivers). The wireless works fine for about 20 minutes then pc freezes up. I have tried to uninstall software that came with it and let windows run it,...
i had that problem with another adapter, then i figured out that i was having problems with another pci adapter. so if you have another pci at the same time, try unplugging it and left the wmp300n alone, it worked for me
Apr 25, 2010 | Linksys WMP300N Pre-802.11n Wireless...
I AM ON TOTAL BROADBAND HOW DO I CONNECT WIRELESS TO MY COMPUTOR
With a broadband connection you will need a wireless router (you will connect your broadband modem to the router) a wireless adaptor for every computer you want to be wireless. If you have a desktop you can either add a pci wireless card (you will need to open your pc and insert the card in a pci slot) or you can use a usb wireless adaptor.
Oct 28, 2009 | Computers & Internet
Router and pc configuration to connect broadband via dsl modem
Sorry i tried to open 192.168.0.50 and it could not display. what is the new IP
Aug 06, 2009 | D-Link AirPlus DI-524 Wireless Router
Cannot connect to wireless network
may be your router needs a firmware upgrade.
check the router's website.
and make sure the router and the wireless card are both using the same 802.11 protocol
Feb 22, 2009 | Linksys WMP300N Pre-802.11n Wireless...
Can't get my netgear PCI Adapter connected to my 2wire 1800hw broadband
You will need to modify the router configuration rather than the adapter to setup port forwarding. Normally Network Address Translation (NAT) will allow most of your services to connect without issue.
Nov 06, 2008 | 2wire HomePortal® 1800HW Router...
Linksys Wireless-N pci adapter model wmp300n
If it says local or unidentified network that means you are just connected to the router on the network but not through the internet. Try to go to manage wireless network, remover your network there and add it again, connect to your own network and make sure to type the correct network key., then check again. You can also try connecting to other wireless network to further isolate the problem.
May 25, 2008 | Linksys WMP300N Pre-802.11n Wireless...
I have an HP computer (Vista Home Premium Software) and Linksys wireless-G Broadband Router (WRT54G) installed and working. Problem--Trying to makea working wireless connection with a 2nd computer. An...
check that you have all updates for your linksys and cable modem and the new adapter you bought since your pc is old..
if that doesn't help then try the following:
i would shut down pc, uplug router power, turn off the cable modem and give it all at least 10-20 secs.. plug the other pc in the router then start up cable modem and router.. after that, then turn your pc on and see if it recognizes...
is the adapter for a desktop to make wireless of a laptop, just curious..
Feb 21, 2008 | Computers & Internet
Wireless Connection
Follow trhis posting as I'm working a pretty much the same prolem
Trendware TRENDnet TEW-421PC 54Mbps PCMCIA...
trying to get a laptop on aol
Hi We are trying to connect to Aol by laptop.... More...
Jeff
Feb 08, 2008 | Computers & Internet
Linksys WMP300N Endless Bootup Loop
Disable or uninstall the Linksys software that manages and monitors the connection.
Use instead the Microsoft Windows Wireless configuration utility.
That's what I did and didn't get problem after.
Dec 30, 2007 | Linksys WMP300N Pre-802.11n Wireless...
Linksys WUSB54GC 802.11g/b Wireless Adapter Logo
48 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
