Philips 19" monitor. volume control
The volume control for my monitor is stting in the middle of the screed and canot be shfted or removed. If I alter the volume, a new screed says "waiting for automatic adjustment" then reverts to the adjustment screen again at 100% volume.
  • menezesijohn Aug 06, 2008
  • 558 Answers
Damage to the board internally you need a new vga board may be a main board but I think it needs just a vga board.
Posted on May 08, 2008
Cannot adjust screed size with control buttons on FP988D monitor. The only one that seems to work is the on off.
Hi there!
It's seems your control buttons panel are busted. If you can access LCD control panel, reset to defaut setting. That might solve the problems... If not, you need a new Board.
May 21, 2010 | Fuji FP-988D 19" Flat Panel LCD Monitor
190b Philips monitor and the volume bar keeps popping up
change task bar properties...otherwise intall monitor software cd..
Mar 13, 2010 | Philips 190B6CB/27 19" LCD
A volume controle massage in the centre of my screen that I can not remove.
This particular Acer monitor has no speakers and the volume message is not comming from the monitor its comming from the computer.
Could you please prove this issue by connecting the monitor to another pc and see if some sort of menu display happens again?
Let me know your results
Mar 07, 2010 | Acer AL1916W 19" LCD Monitor
This monitor has been working fine for 8 months on another machine. I just moved it to another laptop. The mointo works, but is the same size as the laptop, not 19inches. Help
You need to alter the resolution settings on your laptop (Control Panel - Display) so they are the same as your 19" monitor.
microlite
Aug 15, 2009 | Soyo 19" LCD Flat Panel Monitor
Problem with OSD Main Contorls unlocked/locked
Philips say "To unlock the OSD Controls press the “MENU(OK)” button for more than 10 seconds while there is video input from PC."
Jan 29, 2009 | Philips 190B6CB/27 19" LCD
Samsung 193p 19" monitor died
I just finished fixing my Samsung 193p LCD with similar problem. The problem was a black/blank screen as if it was off. But if you are going to use a bright flash light there was data in it. So I suspect it was the inverter.
Procedures made.
1. Disconnect the power adapter and the D-sub cable.
2. Remove the small philip screws at the back of the LCD and remove the cover.
3. Remove 4 philip screws.
4. Disconnect the 2 data cables.
5. Openning the white cover is tricky. Use a flat screw driver and press it at the bottom middle part and use a credit card and pry from the middle part going to left or right side.
6. Remove the philip screws (black) around the LCD.
7. Remove the 4 philip screws and 4 at the middle part.
8. Be careful removing the switch cable. It is very fragile one of the 4 wires might come out (I did but fix it).
9. The Inverter board is at the left side. Take and remove the 4 inverter cables and the white wide cable.
10. This is another tricky part. Near the white cable there is a FUSE (brown in color). Check if it is open. If yes, You can use 2 think wires and solder on both ends. (Be careful the size of the fuse is soooo small like a half grain of rice). Or if you have a car fuse you can also use it.
11. Resolder the 6 terminals of the each transformer. There are 2 transformer so 12 terminals in all.
12. Assemble the parts back and you are done.
Good Luck. Happy fixing.
Roan
Triangle Tech Whiz
Dec 03, 2008 | Samsung SyncMaster 193P 19" LCD Monitor
Removal of front cover
To remove the front cover you need to start by putting the monitor down flat on its face on something that wont scratch the screen.
Next, remove the screws holding the base to the back of the monitor. (You might need to remove a plastic cover to get to the screws).
Once you have done this check for a screw under where the base was screwed on. Remove this screw.
Now check the back of the monitor for one screw in each corner. Not all models have these 4 screws,if they are there, remove them.
Now the front and back of the monitor are held together with plastic clips. You will need to gently pry the front and back apart.
Its easiest starting at the bottom middle and working around.
Once you have separated the front and back, the inner circuitry is exposed. The control panel for the unit can be removed by unscrewing 3 screws that hold it in.
Aug 26, 2008 | Philips 190B6CB/27 19" LCD
Philips LCD monitor
let volume control be pushed forever, use glue or something.
And buy new LCD
May 14, 2008 | Philips 190B6CB/27 19" LCD
LCD 19" monitor color sttings guide for me
threr is a control button in the below of the monitor
so u can ajust it from here or can reset it and degaus it.
Oct 31, 2007 | ViewSonic VX924 19" LCD Monitor
Philips magnavox tv volume control
if your are using a remote control,your volume button is shorted,and of you are using your manual control,your tact switch in volume is defective try to replaced  another one.
Oct 18, 2007 | Philips Magnavox PR1906C 19" TV
Computers & Internet Logo
1,452 people viewed this question
David Payne
David Payne
