Question about Motorola Audio Players & Recorders
Motorola microphone wiring circit for gmn6130 a microphone
Find motorola tu 532 microphone details
Try Find wiring diagrams for motorola tu532
Mark
Motorola Support
Mar 05, 2015 | Motorola Audio Players & Recorders
Where do I get a HMN9030A WIRE DIAGRAM?
Contact Motorola Solutions Get Support for assistance.
Mark
Motorola Mobility Support
Mar 28, 2014 | Motorola HMN9030A Microphone
Microphone recommendation for KLM-2700
Just about any mic will do. I have used a Midland, Motorola, GE, Radio Shack and other microphones on these radio's. The mic element must be dynamic. Condenser microphones would require you to slightly modify the mic input circuit of the KLM to provide 5 to 10VDC through a 4K7 resistor to provide bias for the condenser element. It's easy to do if you have the skills to do it.
Jan 30, 2014 | Cobra Hand Microphone Wired For Klm Multi...
Motorola mic no longer works. Any fixes?
This is probably a broken wire inside. the microphone piece moves back and forth to turn this unit off and on and the wires have broken because of it. there is a similiar problem with the H800 as the mic extends in and out to turn it on and off.
Nov 07, 2009 | Motorola Mobility H710 Bluetooth Headset
Maytag MDB7130AWB dishwasher blows circit breaker.
These have been known to leak water into the door panel. If so the water can cause a short. Your breaker is keeping the machine from lighting up. Check any seals that may have been braeched in the door. Start at the dispencer latch
rubber.
Mar 07, 2009 | Maytag MDB7100AWB Dishwasher
Wiring diagram for accessory plug needed.
I am looking for the same wiring diagram. The headset Moto sells is a single earpiece with microphone, so how does that end up being a stereo connection Neto? Just curious how, or is there also a full headset with microphone? ( I dont' know, just asking)
Would this be a 4 ring TRS connector? Sleeve = ground, then left, right, and the tip as the microphone??
Jan 18, 2009 | Motorola Talkabout T5420 (14 Channels)...
Motorola IHF1000 bluetooth
Hey mawcab,
Based on the information provided it sounds like your microphone is not working. There a possibility it could simply be unplugged from the car kit control module. It will look like a head phone plug. If your car kit is aftermarket it was probably installed under the steering column. Check for a black box with an unplugged wire.
What type of work was done on the car?
Hope this helps!
Nov 05, 2008 | Motorola Mobility Blnc Bluetooth Car Kit...
56 people viewed this question
Top Motorola Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
richie46
Are you a Motorola Audio Player and Recorder Expert? Answer questions, earn points and help others
