Question about Microsoft SideWinder Precision Pro 2.0 Joystick
Serial joystick I've purchased an older Dell Pentium I and put a ISA SB16 card with gameport in the PCI to ISA bridge slot. Windows 95 recognizes with card and game port and software for the joystick enables me to use the joystick in Windows 95 (highest operating system available at the time) environment to calibrate. Problem exists when I try and use the joystick in true dos mode after reboot with popular game loaded Wing Commander's Privateer 2. I am using a boot disk but I am concerned that perhaps the joystick drivers aren't being loaded for the game. I just don't know how to load them. Can you help me?
  • 5 more comments
  • Cybermykl May 07, 2008
    Absolutely, in WC Privateer 2, you can switch from mouse to joystick (2 different modes of joystick one with/without throttle). So far only able to fly with mouse and it is very disconcerting. In WC Privateer 1 before you load a game you can choose and calibrate your gaming device but in Privateer 2 you do so from what is called a PAD "P" on keyboard inside of game at a planet (per se).
    The CD didn't allow me to do that within DOS.
    The joystick's installation program (MS Sidewinder Precision Pro 2.o) that is will not work in DOS mode, will it? No, I just tried it. I'm using an AMD Athlon 64 x 2 core with peripherals tied to a KVM switch. Checking your suggestions will be easy for me to do. Just fire away.
    Just finished eating dinner, sorry for delayed response. Will try your suggestions IrishDruid and check out the pages you sent. Thanks, and I'll get back to you before rating.
  • Cybermykl May 08, 2008
    Dell Optiplex GXPRO 180 Bios A08
    Integrated devices: Sound On,
    NIC: ON; Mouse: ON; Serial Port 1: Auto; Serial Port 2: Auto; Parallell Port: 378h; Parallel Mode: PS/2; IDE Hard Disk: auto; diskette: auto; speaker: on.
    No mention of a switch in cmos/setup to change PnP on/off. (Phoenix Bios Pro 1.10 ver A08.)
    The installation for SB16 Plug and Play with oncard gameport installed with dos drivers and sound in dos game is great.
    Researched CD installation disk that came wiht MS SideWinder Precision Pro and not sure what files I should be looking for. I did however reinstall the software. This did not help, however.
    Should there be a line in the config.sys or Autoexec.bat files that point to joystick? If so, what are they?
    I do have a MSINPUT.INI file in the program file of the c:\program files\microsoft hardware\msinput.ini which reads:
    [Setup]
    Game Controllers.Win95=C:\Program Files
    \Microsoft Hardware\Game Controllers
    These files are in a separate directory - not windows.
    The links didn't offer any clues.
    Hi Jack,
    downloaded the winrar file from Shrekken's setup file and expanded it. But, where does this file install to? Sorry, I'm not to software savvy.
    This is for IrishDruid,
    Precision Pro is a digital stick and will not therefore play in real dos. Changed to MS Sidewinder 3D Pro which I had and upgraded to the digital when using the MS Flight Sims. Strange how the joystick will work in the windows environment and not in the real dos environment and it's just software and hardware. Hmmm... anyway, After plugging in the 3D pro and reloading the software for it, tried it on in the Privateer 2 universe and it still didn't work. Not sure why...perhaps, you guys will earn my money and figure it out. Am now using an analogue joystick - MS Sidewinder 3D Pro.
    President:
  • 2,712 Answers
If you have Windows 95/98 its best to run in pure DOS mode by selecting Start -> Shutdown -> Restart in MSDOS Mode. Don't use the bootup disk..
Sound Card also has to have DOS Drivers for it's Game Port to work. Check Manufactures web site for more details.
MS Sidewinders can use CH FlightStick Pro setting in Control panel. CH Flightstick Pro is recognized in DOS games launched from Windows.
Try disabling 'PnP OS' in cmos/bios setup. When that happens the card may not respond to the game. That's why you often need to disable PnP OS in cmos/bios setup. That keeps windows from changing the bios settings.
With the joystick not working in dos I'd think either the port isn't enabled in dos or the joystick isn't compatible with dos.
Did you install the drivers/files necessary for DOS playback?
To run in pure dos you need to run a file or files--probably from autoexec.bat--to get it going. These are two different
downloads which look like they set up the card for DOS.
http://www.soundcard-drivers.com/dr...
http://vsynchmame.mameworld.net/als...
You should check the documentation for your joystick to see if it contains DOS setup. I'm not sure if the above downloads do that.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 07, 2008
  • Swilin Sampson
    Swilin Sampson May 07, 2008
    Also try using the joystick in Analogue mode.
  • Swilin Sampson
    sure thing..
    Sergeant:
    Champion:
  • 304 Answers
Have you try to configure it first on the control settings of the dos games before you start playing it..??
Thank you & pls post back..
  • Elizabeth Krijt
    Elizabeth Krijt May 07, 2008
    sometimes you have to setup it again on the game even you already configure and set it on the windows..
  • Elizabeth Krijt
    For MS Sidewinder Precision Pro joystick, try turning off 'use rudder for
    pilots head' on the launcher controls tab, or try downloading and installing
    Shrekken's setup file:
    http://mysite.freeserve.com/shrekkens_ha...
    zip . Poorly calibrated joysticks can also result in jittering. You cannot set
    the deadzone within the game. There may not be a solution other than to try a
    different controller.
I have just bought a new computer which has no facility for the parallel port plug-in so my 3D software will not work. MIne is a Designer 1 which takes floppy discs. I have bought an external...
Hi Christine,
If I'm following you correctly, your computer lacks a parallel or "printer" port. This port accepts the male printer plug and would look like this:
Most computers have this jack or port, but progress may be pushing them the way of the 5-1/4" floppy disk I suppose - in favor of USB ports instead. If this is correct so far, you have the option of installing an "expansion card" in one of the unused slots inside your computer. Most newer PCs have one or more PCI slots available for expansion card(s). Examples of these cards are network cards, sound cards and you guess it - serial and printer cards. Many of these functions are built into the motherboard nowadays, so there's not too much need for expansion slots - and those supplied seldom are used up.
You can purchase and install a printer card for short money. They look like this:
Some of these cards may be bundled with a 9 pin serial or "aux" port or other function. Serial or AUX port card were popular with external modems and non-usb mice. Both of which have been dying off for some years now. Anyway, it's your choice whether to get just a printer port like the one above or one with additional connections on it as well. They can be purchased for under $10 (more if it has extra functionality). Here's a link to some offered for sale. You'll need to check the available slot type(s) you have in you computer - most are PCI and some offer the older ISA style. Look at the picture below to help identify the slots in your computer:
In the picture above, the three long, black slots on the left edge of the board are ISA slots. The 4 shorter purple slots more towards the middle are PCI slots. The light brown slot to the right of the PCI slots is the graphics port. This slot or port as it is called, is neither ISA or PCI and is dedicated for a video card. This port is usually a PCI Express type slot, but some older PCs may have the slower AGP type slot instead. Prior to that was a very long slot - over twice as long as PCI called VESA Local Bus. These are almost never seen anymore. The earliest video slot was an ISA slot - like those on the left of your motherboard. You're going to be checking for an unused ISA or PCI slot in your computer after shutting it off and opening it up. If both are available, you should opt to buy PCI expansion cards instead of ISA expansion cards whenever you need to install a card - like the printer card shown earlier.
That's it. I hope this helps and good luck! Please rate my reply. Thanks.
May 05, 2011 | Husqvarna Designer I
Tip
Options for Adding Serial Ports The serial port is prevalent on PC's ...
The serial port is prevalent on PC's as well as scores of industrial, scientific and consumer devices, making it a convenient starting point for communications. Since RS-232 itself is only suited to short connections (50 ft. max.) many applications require that it be adapted to fit requirements. RS-422, typically used for extending RS-232 communications, provides full duplex communications between two devices. It can also provide one way communications from one master to several slaves. RS-485 communications standard allows cable lengths up to 4000 feet. It also provides very high noise immunity. Multidrop connections up to 32 different nodes can be made over a single twisted pair cable along with a signal ground connection.
This article summarizes the choices a system designer has when adding a serial (RS-232, RS-422, or RS-485) communications device. There are many different ways to add additional serial ports to your Desktop PC, Palm, or Laptop PC. USB, PCMCIA, PCI and ISA are some of the methods that will be discussed.
The Universal Serial Bus (USB) provides a high data rate and Hot Swap connection for PCs, providing an easy connection to a wide variety of multimedia and network USB devices. Generally considered to be for home or office use, USB is finding its way into Industrial applications.
PCMCIA Serial Ports are yet another way to add serial ports to a PC that has PCMCIA Slots available. Most Laptops today offer only one (if any at all) DB9 type serial ports. A PCMCIA Serial Card is a good way to add a serial port (or ports) to any laptop that is low on available serial ports (RS-232, RS-422 or RS-485).
PCI Cards are becoming more popular as a way to add serial ports to desktop PC's. PCI type slots are becoming the "norm" in standard PC's today, and PCI Serial Cards are an excellent way to add serial ports. The standard Desktop PC may only come with one serial port standard (if any serial ports at all). PCI Serial Cards use Software Drivers to address the ports to the PC.
ISA Cards are yet another way to add serial ports to the older desktop PC's. ISA type slots are becoming scarce in standard PC's today, but are still an excellent way to add serial ports. The ISA Cards are typically addressed using dip switches and shunts or jumpers to set IRQ's for each port. No Software Drivers are required with ISA style serial cards.
Palm OS PDA's may be connected to RS-422 or RS-485 data circuits using Palm adapters. These adapters offer total portability for collecting data and field service chores. The Palm device and the adapter will usually slip into a shirt pocket. Some models use the PDA's connecting cable, some include a cable and some are cradles that allow the PDA to nest in place and connect directly to the Palm base socket. PalmTerm Freeware allows you to transmit and receive data from the Palm serial port.
on Sep 12, 2010 | Computers & Internet
I have a Sidewinder 3D Joystick with the old standard gameport 15-pin connector. I bought a new motherboard that didn't come with a gameport, so I bought a PCI soundcard with a gameport incorporated. I...
Make sure you get the latest drivers for your soundcard. The drivers will include the software for the joystick port so its recognized properly by windows. Also you may want to go to the support page for your soundcard to see if any settings would need to be changed as well.
Sep 22, 2010 | Microsoft SideWinder 3D Pro 2.0...
I have an old emachine it has a regular phone connection and i want to update it to ethernet connection can you help me?
This is a PCI Network Card. It plugs into a PCI expansion slot on your computer. You will need to install the drivers for this network card to work properly.
How to install a network card Some newer computers come with network interfaces built in - your machine carefully for a socket that looks like a large telephone socket with a network_symbol.jpg next to it. These are sometimes hidden behind a flap or on the corner of your laptop next to the modem socket.
If you haven't got a network interface already on your machine you will have to install a network interface card. These are available to buy from the IT Service Desk.
  • USB Adaptors simply plug into a USB port.
  • PCMCIA Cards for laptops slot in a free PCMCIA slot on the side of your machine.
  • PCI Cards are a bit more fiddly and require you to open up your machine.
  • We advise that you use a USB adaptor for ease of installation
Instructions on how to fit a PCI network interface card.
  1. Shut down Windows and then turn the computer off and unplug it. Never work in your computer's insides with the power on or the power cord plugged in!
  2. Remove the cover from your computer. There are normally a number of screws on the outside of the case to remove. Put the screws someplace where they won't wander off.
  3. Find an unused expansion slot inside the computer. The expansion slots are lined up in a neat row near the back of the computer. All new computers have at least three or four slots known as PCI slots.
  4. Many older computers also have several slots known as ISA slots. You can distinguish ISA slots from PCI slots by noting the size of the slots. PCI slots are smaller than ISA slots, so you can't accidentally insert a PCI card in an ISA slot or vice versa. Figure 2 shows the different types of slots. PCI slots are white, ISA slots are black
  5. When you find the right type of slot that doesn't have a card in it, remove the metal backplate from the back of the computer's chassis. A small retaining screw holds the backplate in place. Remove the screw, pull the backplate out, keep it in a safe place in case you ever want to remove the network card.
  6. Insert the network card into the slot. Line up the connectors on the bottom of the card with the connectors in the expansion slot, and then press the card straight down. Sometimes you have to press uncomfortably hard to get the card to slide into the slot.
  7. Ignored the little cable that came with the card, you can chuck this in the bin. It is a Wake-On-LAN connector and isn't required for your card to work.
  8. Secure the network card with the screw that you removed in Step 4.
  9. Put the computer's case back together. Watch out for the loose cables inside the computer; you don't want to pinch them with the case as you slide it back on. Secure the case with the screws that you removed in Step 2.
  10. Turn the computer back on.
Please give a 4 star rating. we do this for free, the only reward we get is your approval.
Dec 04, 2009 | E-Machines etower 566i PC Desktop
Network card needs replaced,think have wrong card.
Check the cards next to one another. The older Win95 system may have used an ISA style board while the newer one is probably a PCI slot board. If the boards are the same length with the same notches....they should work. And Vista will probably have the device driver for the old NIC card.
May 17, 2009 | E-Machines eMachines Desktop PC
How to use ISA Slot in PCI Slot
There is an adapter available if you look on computer sites for product purchases, try to google it as there or companies than make such items, might be harder to find as PCI and ISA are older connectors and even AGP is begin phased out an PCI express is the lading connector. Google ISA to PCI adapter and see what you can get your compangies to pruchases from. Your local computer hardware shop might have it call first and ask before driving out there, If you find nothing try calling Tigerdirect as they might have older stock, you never know, If to no avail you will have to try and locate an older Motherboard with the two conncectors on it and run that if possible, or find this certain ISA card you're talking about in PCI. Good luck! :)
Jan 17, 2009 | Yamaha WaveForce SW60XG Sound Card
Old game conection
A Gameport to USB adaptor will not work with Suncom F-15 with or without the SFS Throttle. You have to obtain and install a PCI sound card that has a DB15 gameport. Creative AudigyLS cards work great, when these instructions are followed:
http://forums.americas.creative.com/t5/Windows-Vista/Gameport-support-pack-for-Vista-32-bit-x86-updated-on-07-07-2009/td-p/386462
Other PCI sound cards work, but be careful of some OEM cards.
Dec 12, 2008 | Suncom Technologies F-15E Talon...
Replacing a sound card for a dell dimension 3000
Check if your PC has a PCI slot. It is this white strip on you motherboard. Go to your PC shop and ask for a PCI sound card. Just insert it and install the Drivers CD. If it doesn't, You may have the old ISA slot and stores may not be available of any ISA sound card. But dont worry, generally all computers starting from pentium 2 has a PCI slot. You may worry only if your computer is as old as the 486 computers.
Oct 22, 2008 | Dell Dimension 3000 PC Desktop
PCI card not been detected via Windows.
the sound card is installed into the ISA slot not the PCI slot.
clear the cmos for a minute, set it normal again.
install the sound card to the ISA slot carefully - i mean a working sound card and couple the system unit and boot, surely you will have your sound card working.
UZOWUANYA
e-mail:uzowuanya@yahoo.ca
Feb 12, 2008 | ASUS A8N-SLI Deluxe Motherboard
Wrong Card Slot
no its not you have to buy cards especificaly to the board you are working with, isa or pci, the board cant be change one to another from diferent type..good luck
Aug 05, 2006 | Gigabyte GV-N66T128D GeForce 6600 GT, (128...
Microsoft SideWinder Precision Pro 2.0 Joystick Logo
228 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
