Toshiba Satellite A135-S4467 Notebook Logo
Posted on Aug 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I d mwireless switch turned on and was able to get online. Now suddenly i am unable to turn it on and its not showing up in the bios nor will fn f8 turn it on
Anonymous
Level 3:
President:
  • Master 1,851 Answers
  • Posted on Aug 29, 2010
Anonymous
Master
Level 3:
President:
Answers
1851
Questions
Helped
458013
Points
5616
First of all from this official link select your operating system (windows xp, windows 7 e.t.c.) and download the wi-fi drivers. Install the file and check if the problem is solved. In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, accept my solution. Please consider leaving a 4-thumbs rating; I'd appreciate it greatly.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
2answers
My Fn + key is not working on my lenovo y450 laptop.pls advise.
it migt be turn off. try to press Fn + F1 + F2 + F3 + F4 + F5 + F6 + F7 + F8 + F9 + F10 + F11 + F12 to turn OFF or to turn ON. or you may go to BIOS to turn it on from there.
I push fn + f8 and say: Wireless communication is disabled, how can i do for turn on the wireless communication switch?
Hi
have you tried to press FN+F8 again to enable the wireless switch
and or making sure that you have slid the wireless slide switch over to the right hand side to enable it it should show you a picture of what looks like a small satallite dish
9helpful
4answers
I need to know what the keys f1-f12 keys usage.
The uses for the function (f1-f12) keys varies based on which program you have open at the time. Different programs use them for different things.
However, your computer also has some default uses for these keys when combined with pressing the fn (function) key.
fn + f1 locks computer
fn + f2 changes our power use profile
fn + f3 puts the computer to sleep
fn + f4 puts the computer into hibernation mode
fn + f5 changes the display/output mode
fn + f6 decreases the screen brightness
fn + f7 increases the screen brightness
fn + f8 enables/disables wireless connections
fn + f9 enables/disables the touch pad
fn + f10 turns the cursor overlay on/off
fn + f11 turns the numeric overlay on/off
fn + f12 turns scroll lock on/off
My wi fi is turned off suddenly, in my hcl laptop, is any fault in my wi fi device or other problem. when i connect to wire it is working well.please help me how can i turned it on
Either: Fn+F2 or Fn+F8 or Fn+F12
There may also be a little on/off switch on the side or front of the laptop that you need to check is on.
Fn+F8 hotkey dose not work but the remain FX go fine
Another Alternative is to check your BIOS to see whether or not your Wireless is turned on, if it is not pressent in your BIOS then update your BIOS Driver on the Internet to ver 1.4, Double check your version Compatabillity. Next if the adapter driver is installed, follow the following intructions: start -> settings -> control panel -> system -> hardware -> device manager -> now look for the wireless adapter, see if it is operational or marked with an error -> if it is marked check that it is configured for automatic, and also the resources. Set the configuration manually if so. restart the system.
1) Resource conflict = change resource settings
2) No adapter = check if the adapter is enabled (Y) then see if there is any conflicts (y) correct the settings e.g. resources and see if windows shows that the device is enabled (N) try to enable this device. If (N) then goto BIOS settings to correct it.
Hope this helps
Unable to connect to internet through wireless router
Based on your post of Fn + F2, I would initially suspect that your laptop's wireless is the issue. Perhaps you may want to double check the drivers installation and determine if there is a hard switch to activate physically the wifi network. Additionally, you may want to check the manufacturer's website for updated WiFi drivers, download and install them.
Further, it may help if you can post back make and model of your laptop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
