Question about Maytag Refrigerators
Not colding properly and running water - Maytag Refrigerators
    Champion:
  • 274 Answers
Turn water off water first fine water valve were line is hooked up trace to the main.its the selenoid its in the back of the frige for ice maker its is stuck on or open. replace
Posted on Aug 29, 2010
Lg model lds5540 smells, will not clean properly and doesn't seem to have enough water during cycle. also occasionally shows the fe error code. ??? any thoughts?
WATER OVER FLOW ERROR // Water continuing to enter machine
The manufacturer has assigned this error or fault code to indicate that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.You can check it with a multimeter to confirm, it should show continuity on both hot and cold pins. try exchanging the how and cold water hoses, cold on hot and hot on cold, see what happens. have u tried running only cold water or hot water wash? as for the smell could be a build up of detergent or frabic softner, try washer running machine with hot water and vinigar to clean out also check inlet valve for dirt build up
Dec 08, 2016 | LG Washing Machines
What is causing my car to blow cold air from heat. them it over heats while blowing cold air when hot air does blow car runs fine no overheating please help. 2000 Monte Carlos 3.4
more than likely your losing cold water from your water system, make sure your water pump is up to scratch...sounds strange, but you need cold water for heat through your air conditioning...
Jan 21, 2015 | Cars & Trucks
I have a Maytag (FAV6800AWW) top load washer. The cold water won't shut off except at the valve. The cycle will run properly with hot water but if you have the cold on it just runs until it...
the water valve is bad in the rear area inside the machine,its controlled by electrical solenoids and the valve is stuck open even with the unit shut off,replace the valve combo hot and cold as these dont repair
May 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Cold water doesn't run into washer on any part of the wash/rinse cycle. Checked cold water line but not plugged uphecked back of washer where water line connects and no clog there either. Makes a...
Sounds like the valve isn't working properly.
One way to test is to turn off the water supplies and at the back of the machine switch the hoses.
Turn on the water and see if you get cold and not hot . If so replace the valve assembly
Jan 23, 2011 | Maytag Washing Machines
I have been delivered a Aquiras Extra WMA 40 but I only have a cold pipe but I notice the machine has a hot and cold pipes do I connect to just the cold pipe and will the machine heat the water inside
No, the machine does not have a heater unless it has a sanitizing cycle which heats already hot water even hotter.
For the machine to work as advertised, you'll need hot and cold water connections. However, if you just hookup the cold water and run the machine on its cold-water setting it will wash -- the laundry may not be as clean as you would like in some cases, but the machine will operate properly.
Charlie
Jan 06, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
My heater blows cold air. I have had it checked. The water is hot and is running properly through. Mechanic had no explanation as to why only cold air was blowing in and not hot.
It seems to Me that, the heatercore is not functioning properly. Its just like a radiator, the hot water runs through the core, once the thermostat opens at it's set temperature and having the blower motor on, it should blow out hot air.
Dec 28, 2010 | 2001 Jaguar S-Type
The cold water fill just trickles, I removed filter it was not clogged, hot water runs fine. I checked water flow at faucet, I checked for kinked hose. Did not find any obvious problem. Is there a check...
Good day,
The washer has a dual valve, Hot and cold. The cold side has failed. Valve needs to be replaced. Very common problem.
Before changing, turn off cold water supply, remove cold water hose at the machines valve, and turn on to check for proper pressure.
Dec 04, 2009 | KitchenAid KAWS850L Top Load Washer
Not hot washing or drying
has it always been connected to cold water??? cant see how that would getanything clean designe dfor how water.
Oct 30, 2008 | Westinghouse Dishwashers
Washer will won't run cold water cycle
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
  • Hope that helps! Should you have any further questions, please feel free to post them here.
    P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
    Oct 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Water won't stop running
    It might have a small stone or something similar in the water soleniod valve or it might just be sticking open somewhat. I'd go ahead and change the cold water soleniod valve because it's not closing itself and shutting off the water flow.
    Jan 08, 2008 | Maytag Performa PAV2200
    Refrigerators Logo
    Top Maytag Refrigerators Experts
    John Tripp
    John Tripp
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
