Question about Craftsman Garden
Will a hole in the primer button cause the lawn mower to shut off after it's started for only a few seconds?
  • 183 Answers
Not typically. Remember some primers have a hole in them to function as a vent for the carb.
Short runs (2 to 3 seconds) are usually caused by a blockage in the carb's main or idle jet.
I hope this helps.
Posted on Aug 29, 2010
Craftsman 550
Priming may not be the problem. First try putting some duct tape over the hole in the primer button. then try priming and subsequently starting it. This could indicate a need for a new air filter...I know it doesn't make sense, but it will probably be the answer to your problem. It was with mine although a different type of mower.
Jul 21, 2014 | Mtd 22" Yard Machine Push Mower
My washer will start but only run for a few seconds......unless you hold the primer bulb in
The primer bulb has a pin hole in it:
This is what you need:
http://www.mymowerparts.com/partdetail/1079/14606.php
All local lawn mower repair / parts sources have this part in stock. This is a common issue with primer bulbs that you have to hold the bulb in so that it will run. When you do that your stopping it from drawing air through the hole in the primer bulb so it operates normally. Replace the primer bulb and it will be fine.
Thanks for choosing FixYa,
Kelly.
Aug 14, 2011 | Briggs & Stratton Gas Pressure Washer...
Crazy question but where is the primer button on the yard machine 139cc 21" lawn mower???????
The primer button is usually on the carburator of your machine. Most of the time on the side of the carburator , but sometimes on the front of the carburator. GOOD LUCK.
May 29, 2011 | Yard Machines 11A54MC006 21Inch 139cc MTD...
Lawn mower ran out of gas, after refilling it will start, run for a few seconds and cuts off. There is no primer button for this model.
It would be best to take this machine into a dealer like www.arcolawn.com and have the thermostat checked out. There were some early autochoke thermostats that would stick and cause problems.Best wishesJoewww.barter-joes.com
May 18, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
What would cause the lawn mower to stop running when not out of gas? If you give it a few seconds and restart it it will run again for awhile then stops. I have noticed if I pump the primer a couple of...
Try using non-ethanol gas. It's death on small engines. Starter fluid gives it a boost if higher octane. Have a reputable repair place clean out the gunk, then use good gas. Best of luck finding non-ethanol. Boating marinas carry it.
Jul 20, 2010 | Mtd 22" Yard Machine Push Mower
Troy bilt mower. starts but shuts off within seconds.
sounds like you have a primer bulb if you take the bolt that holds the float bowl off and take a tip cleaner that they use for welding tips and clean the holes out of the side and the top it should let the fuel in again that will save you a trip to a service repair shop
Nov 22, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Craftsman 5HP Mower does not start
try changing your primer bulb
May 31, 2009 | Craftsman Garden
Garden Logo
135 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
