Sounds silly but try another HDMI cable, they are not all the same, be sure the TV is set to the proper HDMI port before proceeding. Then give er a go. The computer needs to detect the HDMI cable properly before it can initialize it, if its not set the right port(on the TV first) the computer cannot identify the signal type and can throw an error. Hope that helps, just a couple ideas off the top.
Please use the solution rating if your problem has been solved, or make a note if your still having trouble. Thanks! Gurvy
Thanks for the reply! What you say makes good sense. I should have explained better . . . The HDMI connection/signal works well. It recognizes the signal and transfers my display to the TV and all is well (I could get spoiled with a 37" monitor). When the BD DVD spins up and launches the PowerDVD DX app, it actually starts playing the BD DVD but into the first "preview", the error message comes up. I have never had this happen before, but have not used this setup in over 6 months. I'm going to try and reinstall the PowerDVD DX software and redo the updates and see what happens. Thanks again for your interest.
