Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Dream maker spa... has leak but can not find where. found a crack in two returns but the book nor the manufacturer mentions problems with the returns. The equipment box is wet so the leak is internal and stopped after past the valve return level. spa has been off as it read OH and then went to SN. dont know what else to do.
    Top Expert:
  • Dream Maker ... Master
  • 6,465 Answers
Check the hard plastic couplers and bad recirculation pump and pressure switch
Posted on Sep 20, 2017
5 Suggested Answers
SOURCE: I have a Dream Maker x-spa Dition 4 person spa. i
hi i am having the same problem have you managed to fix it and how any help would be much appreciated thanks joe joeathome2009@hotmail.com
Posted on Aug 06, 2010
  • 990 Answers
SOURCE: Dream Maker x-500 5 person
If it's loosing water this should be a structure warranty. I have two of these and had to drain the spa and shine a light in the spa and take pictures from underneath. Then the light will show off the cracks well. If your the original owner just keep at Dream maker, they should give you a new one.
Posted on Dec 11, 2010
adamh294
  • 310 Answers
SOURCE: motor will not come on.
OH stands for Over Heat situation.
If the motor is not working at all, you are getting the OH code because of that. The OH happens when there is not enough circulation in the hot tub which causes the water near the heater to overheat the sensor located in that area. It sounds like either the pump has failed, the wiring has shorted to the motor, or the control board is not telling the pump to come on.
Its probably a bad motor since the heater is obviously activating, which it wouldnt if the pumps motor was getting no power. Replace motor and all should be well again.
Posted on Apr 14, 2011
Testimonial: "very helpful. @We did not have the sensor connected properly in the panel board. Now it seems to be working fine. Thanks to you."
mc1bean
  • 3053 Answers
SOURCE: I have a Dream maker
Visit your local building supply , they have fiberglass repair kits that are really easy to use and fill.
Posted on May 08, 2011
6 month old jacuzzi hot tub has started leaking intermittently , any help here to solve this problem
remove front panel visually inspect pumps to see if leaking if ok check by control box remove cover inspect where plumbing runs through keep eliminating thing until you find it
Sep 02, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas leak
This means one of your top jets is leaking. Firstly try Fix A Leak this will stop any leak up to an 1/8". If this does not help there will be more difficult work in store.
Each jet sits in a jet body, these jet bodies are behind the tubs shell, you'll need to get in behind them to see which one is leaking. This can be difficult as they are often covered in insulation foam.
Sep 05, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a Dream maker spa. It has a small crack. what can I do to patch it?
May 08, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker x-500 5 person developed cracks in the shell of the 2 corner seats, nearest the access panel. It appears the seat supports molded to the base of the spa are pushing the seat bottoms upwards,...
Dec 11, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
What size shaft seal is in a dream maker eclipse spa? I need a new one to replace my leaking seal.
Your spa should have the aquaflo pump which uses a PS-200 seal.moz-screenshot-1.png
http://www.ussealmfg.com/pdfs/ChooseThe%20RightSeal.pdf
Oct 26, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
My spa leaks water to just below the adjustable jet nozzles.
Good luck, I'm in the process of chipping away at the foam 3 days so far, still have not found leak, Tried everything dyed water, but with the way they do the STUPID foam the water could be dripping 3ft away from leak... **** poor design and the can foam to fill it back up is gonna cost a small fortune,,
Dec 10, 2008 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
328 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
