Question about Kenwood KAC-6104D D Class Mono Power Amplifier
The amp worked fine for about a year then one day the bass would not play through my subs properly sounding like a cd skipping only with the bass i would turn volume down and it would work fine until a high bass section of a song then the problem re occurs. finally my amp would only turn on for less than a second when i turned the car on. i checked all amp and sub connections everything is perfect. what could be the problem
    Master:
  • 347 Answers
When you hooked up your amp, did you hook it directly to the head unit so that it didn't come on with the car? Did you find the inline fuse in the amp positive cable? Few things to check..
Posted on Jul 13, 2017
  • 11 Answers
SOURCE: fan stays on, light turns off
try using a better ground. while new cars are great, they also have more paint and plastic in the works...so finding a good ground for your amp to run off of isnt always easy. you can try running a gbround cable straight to the negative terminal of your battery to test the amp, poor grounding is the most comon cause of amp failure. ps,the fan may be staying on as a protective service, as if your amp loses ground whenpowered up it will keep the cicuit boardfrom heating up on voltage surges.
Posted on Sep 06, 2007
  • 631 Answers
SOURCE: LIGHTS ON BUT NO BASS
Is the master/slave switch set to master? Have you tried feeding the signal into a different amp to make sure that there is signal reaching the amp?
Posted on Sep 19, 2007
  • 11 Answers
SOURCE: Car Audio (amp over heating)
by chance is the sub a dual voice coil sub if so you can change the inpedance going to the amp.also if you don't have at lest 4gauge wire for power+ground you ground wire is as important or more than your power wire it is a somtimes a common over sight make sure the ground is as short as possible and in good contact with the vehicle frame
Posted on Jan 20, 2008
  • 323 Answers
SOURCE: KAC-9102d no sound, Amp powers on but no sound to the subs.
If the sub isn't working, you won't get a pop. All you need is a small speaker. Don't need a sub, you just want to test the sound. I recently blew 2 subs, no smoke, no smell, no sign of being blown. Absolutely nothing from the subs.... In the past my sub locked up. You can take your sub out of the box and hook the + and - to the battery to see if you can get the sub to pop there. I believe a small box will push a sub into a deep excursion to the center of the cone. I have 2 lanzar VW12D's that just quit. I hooked a 6 x 9 up to my amp and low and behold I had sound! Try that and see what you get...
Posted on Feb 12, 2009
  • 23 Answers
SOURCE: amp turns on but no sound from subs?
Check to see if your deck has a sub on/off option in the menu or settings if it don't you may have blown amp chanells or bad RCA preouts on deck or bad RCA in on amp
Posted on Feb 18, 2010
Testimonial: "You are correct it seems to me that it has something to do with the RCA inputs on the amp or it also could be blown amp channels, the amp is bad. "
My subs are skipping notes and only play low notes decently and only play when the volume is at full blast. The amp wiring is fine and the radio wiring seems alright. No idea why it is
First of all the bass needs to be tuned down on stereo you shouldn't need to turn volume fill blast then you set your amp so your subs sound good hope you have a cross over. Never tune the gain on your amp past 3/4 ether play with you air flow to that some times works I found that if you do this your bass gets louder less risk blow
Mar 02, 2013 | Car Audio & Video
Fader/sub/speaker not working properly
I'm not an expert but often people connect subs to normal speaker wires in back of the radio. You need a dedicated subwoofer line so high frequency sound doesn't go to the subs. Only bass. Sounds like it wasn't wired properly.
Aug 26, 2017 | Pioneer DEH-P6000UB Car CD/ MP3 Player
My amp won't play bass everything is hooked up
I have a similar problem with my 2012 civic, I hooked up my 1800w kenwood mp to my 2 12" w6s and 1 song plays and sounds great, the rest of my songs have no bass from the subs, just the car speakers sound normal so I dont know what the hell thats all about. I thought it was a wiring issue but I can play the one song all day and it sounds perfect so any suggestions? thanks in advance
Jan 29, 2012 | Sony Car Audio & Video
My subs don't bump to the beat, they just go THUMP THUMP THUMP...
It sounds like you need to ask for pro help mate, mybe the amp just needs setting properly, Is the amp on bypass for bass, or does the amp run the complete system
Jun 13, 2009 | Cadence TXA 750D High Power Mono Amplifier...
Audiobahn 1800 watt amp has an error of LO and isn't working righ
you are not getting your amp enough volts try checking your ground or power cable
May 19, 2009 | AudioBahn A18001DQ Car Audio Amplifier
When volume turned up subs pop then immediatly produce no sound
u might have to turned your amp so u can play both subs your amp might be to small to run both subs at the same time an u gotta play around with the settings on your cd player so when u blasted your subs it has that nice bass to it not that poping sound.
Apr 04, 2009 | Jl Audio 13W7 Car Subwoofer
Kenwood KDC-MP538U - no sound.
My issue was that I didn't have the blue "amp" wire hooked up and I had a factory amp.
Jan 06, 2009 | Kenwood KDC-MP538U Car CD/ MP3 Player
Jensen VM9311TS wont play cd
you are probably mising to power on the factory amp from the vehicle
Nov 04, 2008 | Jensen VM9020TS Car DVD Player
Subwoofer Output Not Working...
The first thing to try is disconnecting ONE of the two subs. See if you get more bass with a single sub than with both. If you do, re-connect the second subwoofer, but reverse the (+) and (-) wires.
Jun 19, 2007 | Panasonic MXE CQ-C7401U CD Player
Amp and sub bass playing through all speakers
You need to go into the setup menu and find out if the radio has a sub low-pass filter that redirects the bass to the pre-out for the subs, and away from the main speakers. Fiddle in the audio menu.
Apr 15, 2007 | Xtreme Sound WMS336 CD Player
Kenwood KAC-6104D D Class Mono Power Amplifier Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
