Question about Sony Cyber-Shot DSC-H1 Digital Camera
Sony DSC H-1 battery life is way too short, not a battery problem. I found that there is a 1.9 volt draw on the batteries when the camera is turned OFF. Can I do a repair or is this a factory repair, which I DON'T trust ?
  • 1 more comment
  • srkoke Aug 30, 2010
    Not trying to be a wise guy but there's nothing in the manual about removing batteries. I have had this camera for several years and never had this problem until about a month ago and now when I replace the batteries I have to reset the date and time every time, I really think there's something wrong, Thanks for your input, Karl
    Now that makes sense, the next question is how do you change that battery and where is it ? Thanks again, Karl
    Great info, solved the problem
  • Sony Master
  • 4,924 Answers
On the manual it is specified that the batteries should be took out of the camera when it is not used..cause the batteries are discharged even when the camera it is powered off..So this is a normal issue found in most of modern cameras..that has internal memory and other issue that dry out the battery when it is stopped..
The way to handle is to remove it when you do not use it ...
I do not have rechargeable batteries on my camera ..(Panasonic)..and it is the same specified in the manual to remove them when not used..Once I forgot to do that ...and it emptied them over night ...(new ones) almost less than 10 hours..
So the issue is to remove the battery when not used..
Posted on Aug 29, 2010
  • 3 more comments
  • Catalin Turcu
    Catalin Turcu Aug 30, 2010
    if you have to set the date and time each time you open it ..it means that your camera is equipped with an internal battery for holding the settings ..and not with an independent flash memory and in your case the internal battery is gone ..and this is the issue that makes it drain the batteries when it is off...it practically substitutes the internal battery that is empty ..with power from the main one ..
    this is the reason you have to remake the settings each time you shut it down and remove batteries..That internal one had the function to hold that kinda informations into memory ..
    I never consulted the manual in the first time ..I just assumed is the same cause most cameras are like that ...cause they do not came with an internal battery ..but with a flash like chip to hold the settings ..when you leave the batteries inside they drain them ..
    if yours used to hold the settings ..and now you have to put them back each time ..it means that the internal battery is gone..and need to be changed..It functions just like the BIOS battery on computes..
  • Catalin Turcu
    I never opened this model before..but usually internal batteries are something like a electronic clock battery ..and they are on the main boar d..so you have to open ...remove it ..and take it with you on the shop to replace the exact model...or open the camera take it off..and look on the net .for the same model ..
  • Catalin Turcu
    this is an example from a similar model (not he exact one ..) and how the battery looks like and what to look for ..
    Thanks so much, you saved me $100., that's what Sony wants for the repair, crooks, Karl
I cant get my camera to turn on. thanks for your
Fist charger your SONY Cyber-shot DSC-W120 battery and clean the connect place of the battery and camera. Please make sure that the battery has been charged by the Sony Cyber-shot DSC-W120 charger. Li-ion batteries life is about 2-3 years, and if you have stored your battery with no power for a long time, the battery maybe has been damaged. When store Li-ion batteries you should charged it at about 40% first.
May 06, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Battery life is too short.
its old or defected
buy a new one
try those chineese websites
buy more than 1
Apr 21, 2010 | Sony Cyber-Shot DSC-S500 Digital Camera
Sony DSC P92 appears to be consuming power rapidly
What type of batteries are you using?
If you are using zinc carbon types, then a short life is to be expected.
If manganese types are fitted the it seem a little strange.
Is it still under warranty? If it is, then you should discuss your problem with the supplier.
Lithium batteries have more power but cost more.
Jan 23, 2010 | Sony Cyber-Shot DSC-P92 Digital Camera
Short battery life
its not the charger its time for a new battery
Dec 17, 2009 | Sony Cyber-shot DSC-T700 Digital Camera
Sony dsc-p92, the batteries don't last very long
if you work on zoom. / flash & preview too often, they will eat into your battery life much more than just regular use. Also, if the batteries are old (more than 1 year) - high chances that they are at the end of their life span by now.
Dec 17, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Sony Cyber-Shot DSC-P72
It could be that the battery isn't holding a charge anymore if you are using rechargeable batteries in you camera. Most of them have a short life to them. If you can get a hold of another one, see if that solves that problem.
Aug 28, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony cybershot dsc-n1 took 6000 pics and stopped working Screen went white before died with lense extended no sign of power next cybershot DSC-N2 took 15,000 pic and died just refuses to turn on. no power...
no non of sony cameras come with any life pan
ya they are telling something baout life cycle
but i have cybershot with 29000 pic and my friend is having about 20000 so if your cameras is in warrenty period then go to sony service station they will fix it
or if you r out of warranty period then go for repairing your camera probebly changing CCD of your camera will fix this problem
Mar 26, 2008 | Cameras
Extremely short battery life
do you use alkeline batteries? if yes then they would end in 20-25 shots. Instead, use rechargable batteries of 2500 mah which will last long, very long. On my Cybershot H1, they give aproximate 350 shots with single recharge.
Go for Sony Original Batteries or Uniross brand also works fine.
2300 mah/ 2500 Mah any will work.. :-)
Nov 25, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Sony camera turning itself off...
You can't use regular alkaline batteries in this camera. Alkaline batteries only supply 1.5 volts. The camera uses 2 in series for a total of 3.0 volts from alkaline. However, the camera requires 4.2 volts to operate correctly. This camera has high power requirements, so you'll need high end lithium or nickel hydride batteries that can supply the higher voltage and current this camera requires. It's a power hog, and regular alkaline batteries are too weak to run it. The menus will work on alkaline, but once you try to turn the camera on in capture mode to take a shot, the current requirements to operate the camera motor, LCD, zoom, memory stick, etc, all it once is too great a draw for alkaline to handle. Either use the external power supply, or get Lithium batteries. Make sure the batteries you get are 2.4 volts and not 1.5 volts. Get the ones with the highest current rating you can find.
Aug 31, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Sony Cyber-Shot DSC-H1 Digital Camera Logo
291 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
