Question about AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner
My Aqua Vac Tiger Shark is sqeaking. I think the wheel tube bearing assembly is broken. How do I replace this part?
    President:
  • AquaVac Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Either side's drive system is composed of two guide bearings, a drive pulley and both wheel tubes. You need to replace whichever one(s) are failing. Remove the seven screws inside the unit that hold the side plate on as well as the handle screw. Pull the side plate and replace parts as needed. Reassemble in reverse order. For a price on the part(s) please contact us thru www.arrowpools.net. We stock most Tiger Shark parts.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Sep 05, 2010
How can i replace the power cord on my tiger shark
there are special tools required to remove the power cord. i would send you a link to the manual but they are no longer active. the process itself is very simple but removal of the cord from the motor is tricky without those tools.
Jul 06, 2014 | Aqua Vac Tiger Shark
Why does my tiger shark motor run and peller spins but wheels do not turn
if the wheels are not turning, there is a good chance the drive belt is damaged. this can be repaired
Jun 14, 2014 | Aqua Vac Tiger Shark
Tiger Shark moves slow
no tension need to replace tracks
Jun 25, 2012 | Aqua Vac Tiger Shark
My tiger shark does not work!! I have power to the transformer and shark, but it won't move. I just spent $400.00 at my pool store to get it fixed, they put new wheels, filters, and a new cord and...
The motor pack...
Was the store able to scan the motor to pull out operational info? Was it water tested prior to being returned to you? Perhaps the store will make accomodations to get it returned and repaired correctly?
John
Jul 23, 2011 | Aqua Vac Tiger Shark
I have a tiger shark one and half years old. it turns on, can hear the motor going and it will move and clean regularily anywhere from 20 sec to 5 minutes. but then will get stuck in one spot. the motor...
The motor pack is having trouble and will need to be replaced (most likely). For help finding a service center that can perform the inspection and repairs check Hayward's site at http://www.haywardnet.com/locator/ and fill in the information requested. Be sure to select product repair or service and robotic cleaners to limit the response to those able to fix these cleaners. We are in S.E. Michigan and are one of the centers for Tiger Shark cleaners.
John
Oct 10, 2010 | Aqua Vac Tiger Shark
My tiger shark pool cleaner spends a lot of time at the top of the water line. How can I adjust it so it does not climb so far?
the tiger shark is designed to climb but you can adjust the weights to keep it down. check out http://www.aquavacsystems.com/Weights-and-Floats_ep_31-1.html
for more info and specs of your unit. good luck
The Pool Tech
Jul 02, 2010 | Aqua Vac Tiger Shark
How can I keep my Tiger Shark from sticking to the main drains in my inground pool.
Decrease suction on main drain and increase suction to cleaner.
Jan 15, 2010 | Aqua Vac Tiger Shark
Plugged in and turned on but doesn't move
look at the rubber belt wrapping the wheels, there are some little rubber numbs along the belt in order to grap the wheels and make them move. If some of the numbs are broken, the grab is too week to move the wheels. I guess, replace the belt is the only solution
Aug 11, 2009 | Aqua Vac Tiger Shark
AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner Logo
394 people viewed this question
Top AquaVac Pool & Spa Experts
Thomas Perkins
Thomas Perkins
Steve Slater
lioneltrain5
Level 1 Expert
Are you an AquaVac Pool and Spa Expert? Answer questions, earn points and help others
