Question about Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV
I have a 3 year old Sony Bravia 26" that has started to display two (2) colored, intermitant horizontal lines. One at the bottom of the screen and one in the middle. What does this indicate and has it been a known problem
  • donrham Aug 30, 2010
    The display is not one of distinct "lines" but rather a series of horizontal dashes in a multi colored display. It started with just one level at the middle of the screen and the same display occured at the bottom of the screen two days later. Each dash is like it's own minature display in color and actually pulsates.
    Thanks eagle338. Hope you are right. Previous expert said to junk it and buy a new one.
  • 4,889 Answers
Yes it is a known problem. You have a faulty t-con board(timing control). Don't worry as this is a rather inexpensive component and for a set of this size the replacement module costs only about 50-75$. If you want to try replacing it yourself then let me know and I will guide you with the same.
Posted on Aug 30, 2010
  • Sony Master
  • 11,800 Answers
No this isn't a problem that is well known on your tv.
If the lines are there , in the same configuration, constantly then the LCD panel is faulty and cannot be repaired - just junk it, replacing the panel would cost you more than a new tv.
If the lines are always in the same general position but change in position and look then the buffer memory from the image processor has failed - you must replace the entire mainboard - this is going to be expensive - around $300 - so it may not worth it. Your call.
Posted on Aug 29, 2010
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
NEED TO KNOW IS IT WORTH FIXING A CRACK SCREEN NO PICTURE COLOR LINES.
You have to take it into a shop and the cost will be more than a new set. You cannot buy a screen that big and install it yourself.
Feb 14, 2014 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
My Sony Bravia KDL 40WL 135 TV has been flashing strange colors for awhile; today screen is black with a thin blue line across the bottom. No sound. Any help appreciated.
The vertical output section circuit has the fault. Contact any experienced service technician. This is not a user repairable fault.
Aug 10, 2012 | Sony Televison & Video
I have purchased Sony Bravia LCD BX 42, which has a very thin horizontal line across the screen, how to fix the problem
my sony bravia BX42 has a color green horizontal line and it makes bigger and bigger until some color pink was appeared then I am worried if it will not turn to normal as it goes :(
Aug 29, 2011 | Sony BRAVIA KDL52XBR2 Television
I have a Bravia KDL-52w4500. Over the last month I have started to get more and more horizontal line across the screen. These do not go away. What can I do to fix this
unfortunatly, horizontal lines on an lcd tv, almost always mean a bad lcd panel. if it is out of warranty, it will be really cost prohibitive to replace the panel. if the set is only a year old or so call sony customer support and ask for a concession for the part.
Aug 18, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I purchased an Sony Bravia LCD 26 inch of KLV S200A series 3 years back. The LCD has now started developing problems like automatically the power goes off when any particular channel is being viewed and...
You have intermitant problems which may be caused by contact resistance or circuit overheating.After it cooled down the tv starts again. Leave TV on standby at all times.
Jan 03, 2011 | Sony BRAVIA KLV26S200 26 in. LCD TV
Hello, I have a Sony Viao VGNCS215J that is a year...
Sony has identified a limited number of VGN-CS series computers which may display a horizontal line on the LCD screen.
Click here for more details
May 20, 2010 | Sony VAIO VGN-CS215J/W Notebook
I have horizontal lines in my screen about every
The reasons for the fault may be due to:
  1. The Control PWB only causes this defect when the Backlight Control Signals are Output from the Control PWB.
  2. No LVDS signal may also result in this symptom.
Dec 04, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Horizontal lines in sony Bravia 26"
You need to replace IC8C01 and IC8C02 part# STK394-250. They are located on the main board (in the middle of the chassis) and are mounted on a large aluminum heat sink.
Jun 08, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony Bravia 42" Horizontal Lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Oct 19, 2017 | Sony Bravia KDL-42V4100 42 in. LCD TV
Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV Logo
139 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
