Question about Speedo 7410061 MP3 Player
My Speedo Aquabeat is not recognized by my PC when I plug in by USB to my Sony laptop...
I had the same problem and i was told to try plugging it into another USB port on my PC and that worked. however, i was using a PC and not a laptop, not sure whether that will make a difference. good luck.
Posted on Sep 05, 2010
I have just brought a imac computer, how do I get the program required to use my speedo aqua beat
website says the software is not compatible with mac, but it states that when you connect the device to your mac a folder should show up on the desktop and you can just drag songs into that folder
http://help.speedo.com/app/answers/detail/a_id/75/~/how-do-i-use-the-speedo-aquabeat-playlist-editor-software%3F
Aug 12, 2011 | Speedo Aquabeat MP3 Player i
Hi my aquabeat is showing as removable disk j instead of speedo multi media disk i can't add music please help thaks karen
I have the same issue. I tried to reset it, but unsuccessfully.
It does charge, but windows is not recognizing it anymore and I can't play the tracks.
Jul 24, 2011 | Speedo 7410061 MP3 Player
Speedo MP3 pink 1 gig. When I plug into my Mac (yes, Mac hooked to power source; yes, plugged directly into the Mac's USB) I continually get a message saying I've ejected incorrectly. Then shortly...
It probably means your usb connection is loose. You can try another usb port on your mac, if that is better then the usb port you usually use is bent or has a loose connection, if not the problem is likely the MP3 player's usb.
You could try putting a small amount of weight on the MP3 Player while its plugged in to improve connection. While it is plugged in, use your finger to lightly move the device up or down and hold gently. If the connection improves, use a small weight to hold device in that spot. If you are pushing down put a small box on top of the device, if you are pushing up, gently wedge something underneath drive.
Hope this helps.
Sep 20, 2017 | Speedo Aquabeat (2 GB) MP3 Player
Mp3 player does not seem to fully charge
Try pressing the reset button on the bottom of the unit and restarting your computer then plugging the usb cord. If still not working try charging from an external usb charger that matches the voltage specs for the aquabeat model you have and letting it charge over night.
May 20, 2010 | Speedo 7410061 MP3 Player
Speedo aquabeat 3g mp3 player is not charging. The LED light turns to green, but when I unplug it it won't work.
You are plugging the headphones into the unit and then trying to power up the unit, correct? The Aquabeat will not power up unless the headphones are connected to the unit and disconnecting them will shut the unit off.
Feb 19, 2010 | Speedo Aquabeat MP3 Player i
Speedo Aquabeat is not recognized by my Macbook Pro
I plugged my aquabeat into my mac. It mounted and I deleted all the files onto it. Then, I copied a bunch of mp3 files onto it. The device registered as full and wouldn't let me add any more files even though the info window said there was 250 MB available but this was wrong or misinterpreted by the device. I couldn't make it work. I found there was insufficient capacity for the operational files to be built on the device. I deleted one of the mp3 files to free up space then ejected it which caused it to be unmountable on the mac - it wouldn't turn on at all. I pressed the reset button and it all came to life and now it works as advertised. The device needs to create a bunch of work files for it to start. I believe that it really was out of space and could not create the work files. When I deleted the mp3 it freed up enough space so the work files could be created, but it was frozen. The reset caused the work files to be created and all was well.
Aug 22, 2009 | Speedo 7410061 MP3 Player
Speedo aquabeat not playing
have you checked the volume level to make sure that it was not lowered by mistake? Just a thought.
Aug 01, 2009 | Speedo 7410061 MP3 Player
PC will not recognize the MP3 player
Check if the proper drivers are installed.If not install them.Or check if the computer is infecte by an antivirus.Sometimes viruses do not allowp hardwares to be detected.
Jul 09, 2009 | Speedo Aquabeat MP3 Player i
Speedo 7410061  MP3 Player Logo
977 people viewed this question
Top Speedo Audio Players & Recorders Experts
aliasger yq
Amelia starnes
Amelia starnes
Level 1 Expert
John Craig
John Craig
Level 1 Expert
Are you a Speedo Audio Player and Recorder Expert? Answer questions, earn points and help others
