My hi-fi refuses to play CDs! it comes up with a 'no disc' error when there really is a disc there.
  • Amyel May 10, 2008
    It's a Samsung MM-C8DAB. I'm not sure if I can get to that bit of the CD player as it's a drawer one.
    thank you for helping!
    Amy
  • 4,234 Answers
The "no disc" error message indicates that the unit failed to read the disc. There can be a number of reasons for this. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Many times that cleaning will resolve the problem. If not, please supply the make and model of the unit and I'll provide additional options.
Dan
Posted on May 08, 2008
Hello I have a Boston Acoustics Microsystem CD. I have had it for about 2 years, and it receives light use. In the last few months it has started refusing to play discs and I receive an E70 error...
Hi John,
Please let me know if you do find a remedy for your issue, as I believe or not have the exact same problem and I would greatly appreciate any input or information that you may have obtained.
Regards,
Sal
Feb 13, 2011 | Boston Acoustics E70 Center Speaker
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
Hi, My Sony Vaio DVD Windows Vista computer will play some DVDs without difficulty, others it refuses to play at all, and on others, it will play all of the movie except for five minutes in the middle....
Just due to dust on your dvd lens run dvd lens cleaner and after load full drivers of dvd which either given you on time of buying or you have to download from sony site
Feb 02, 2010 | Intervideo WinDVD 5 for PC
MY BOSS BV7970 DO NOT PLAY ANY BURN CDRW OR DVDS
Some players are picky with certain cdrw/dvdrw discs. You might have to experiment with different brands/types for your discs. I used to have a cd player (teac) which would just refuse certain brands cd-r discs but play others just fine. I know it sounds odd, but once I noticed which ones work and which ones don't I never looked back.
Also, have the "problematic" discs been recorded on just one recorder? Have you tried playing discs recorded on a different recorder?
Also - I'm sure you've already tried it-it's always a good idea to clean the laser just in case.
Hope this helps+
Good luck,
Raf
Nov 13, 2009 | Boss BV7970 CD Player
Hi. Own A Kenwood RXD 653 midi hi fi that's around 8 years old.The problem is it has,mainly,stopped playing cds.Its a 3 disc changer and when i try to play any cds I can hear the disc spinning but the...
It is the laser, If the cd mech is in the top of this one you may just need to clean the lens manually. Cleaning discs are not all that reliable. You can do this by taking the top off and looking at the area where the disc gets clamped to play. The laser has the small glass lens. That is the part you need to clean. Take a Q-tip and wet it very lightly with some windex or some alcohol. Make it so that the Q-tip is just barely wet. Then just lightly rub the lens without pushing on it hard at all. Just nice and easy over the glass lens. Then dyr it off with the dry end just like you did with the wet end. That's it. close it back up again and turn it on and see if it plays. If it still does not play you need a new laser. No other fix for it.
Jul 03, 2008 | Kenwood Audio Players & Recorders
CD player won't play CDs burned on new computer
hi penguinxy.
try get a original cds if it works fine.the next time you burn cd try burn at 8x or low may be your cd lens is not detecting cds burnt at high speed.hope this helps..
May 10, 2008 | Jensen CD-2010X CD Player
DVD problem
It could be a couple things...
#1. Over time, dust and deposits can accumulate on the laser that reads the disc. In many cases, DVD players with this problem can still read CDs. You could try a DVD laser cleaner, which is usually a disc that has a tiny brush glued onto it. Run the cleaning disc 2 or 3 times, and try it again. Try both CDs and DVDs, since CDs are easier to read than a DVD.
2. After a DVD player has been used for awhile, another common problem is that the laser in the DVD player becomes misaligned, inhibiting its ability to read DVDs. In many cases, DVD players with this problem will still be able to read a CD. I'd try a cleaning disc first, since the only way to fix this problem is to bring the unit to a service center for repair.
Let me know what happens after you get the DVD laser cleaner and run it. Hope this helps.
May 07, 2008 | Televison & Video
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Jun 23, 2007 | Kenwood KDC-CMP59FM 10-Disc CD Changer
Changer refuses to eject or play CDs, keeps saying reset
Hello, in order to repair CD changer you have to be equiped with special tools and knowledge. This repair is only possibble in Authorized Sony Service or at the shop with best references for this kind of job. Best regards, Arpi
Apr 13, 2007 | Sony CDX-656 10-Disc CD Changer
DVD display indicates "no disc"
Try a lens cleaner cd, as when the lens gets misaligned or if it's quite old, it will find it harder to read a DVD as the tracks are much closer together than that of a VCD as they are cd's and their tracks are wider apart and easier to read.
Jan 11, 2007 | Sony Multi-System Mini Hi-Fi system /DVD...
96 people viewed this question
 Grubhead
Grubhead
