1. you need to remove the power cover (if you see the power button, that what i mean).
2. after you remove that cover, you will see 2 screw that hold the keyboard. Remove both screws.
3. Remove keyboard and replace it with new keyboard.
To remove keyboard. remove 3 screws on the back below LCD. Lay LCD backwards and with a small flat head screwdriver, lift up. There should be 2 screws connected to keyboard, remove and remove keyboard.
hi to change the key board there is 1 screw on the bottom of the laptop take that out little picture of key board next to it .then were the k pad is the strip ware the power button un clips ,do this carefully 0nce off there is 2 screws to take off lift up key pad to see ribbon on main board and un clip .then just do it all in reverse it is easy just take your time .
when i try to download effects it says that its not valid for winlocker 32 and that it doesn't have...
(More)
when i try to download effects it says that its not valid for winlocker 32 and that it doesn't have a publisher.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
