Question about Microsoft Windows Vista Ultimate Edition
When I initiate the game " My kingdom for the princess" a dialog box appears " cannot init direct 3D ". I have the version installed dx 10 and already I have throw the diagnosis "dxdiag" and everything is correct
    Sergeant:
  • 223 Answers
You likely need to update your drivers for your video card. surf to your video cards manufactures web site and download the latest and greatest software/drivers for your video card model. run, install , restart and try again. This will likely solve your directx issue. cheers
Posted on Aug 29, 2010
  • Trevor Groves
    Trevor Groves Aug 29, 2010
    Please use the solution rating "thumbs" if your problem has been solved, or make another comment if your still having trouble. Thanks! Gurvy
I Need To Get Shader Model 3.0 But Not Sure How Or Where To Get It.
Shader Model may be part of the video card. Hence, it does not support the game.
Jan 09, 2013 | Samsung R519-53S Notebook
How to turn on a dhcp on a rca model dcm425 cable modem?
Enabling DHCP at the Client To enable the Windows NT DHCP client, you must log on as administrator at the Windows NT client.
Normally, you enable DHCP as part of the installation procedure for Microsoft TCP/IP, however, you can use this procedure if you have manually configured TCP/IP:
  1. Run Control Panel and choose Network.
    The Network Settings dialog box appears.
  2. Under Installed Network Software, select TCP/IP Protocol and then choose configure.
    The TCP/IP configuration dialog box appears.
  3. Select Enable Automatic DHCP Configuration.
    A Microsoft (MS) TCP/IP message appears, indicating that the DHCP Protocol attempts to configure the server automatically during system initialization.
  4. Choose Yes.
    A MS TCP/IP Configuration dialog box appears, displaying current TCP/IP configuration parameters. The IP Address and Subnet Mask boxes are not available (grayed out) and the manually configured values are no longer displayed.
  5. Choose OK to return to the Network Settings dialog box.
  6. Choose OK again.
  7. Shut down and restart the computer.
To enable DHCP on a Windows for Workgroups client if TCP/IP is not installed yet:
  1. Use Network Setup to install the MS TCP/IP-32 3.11 protocol.
  2. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose Continue.
  3. Restart the computer to initialize TCP/IP using DHCP.
To enable DHCP on a Windows for Workgroups client if TCP/IP is installed:
  1. To access the Network Drivers dialog box, run Network Setup.
  2. Select Microsoft TCP/IP-32 3.11, and then choose Setup.
  3. In the MS TCP/IP Configuration dialog box, select the Enable Automatic DHCP Configuration check box, and choose continue.
    A message box appears indicating that the configuration of DHCP overrides any values established locally.
  4. Choose Yes.
  5. To initialize TCP/IP using DHCP information, restart the computer.
Dec 19, 2010 | RCA Computers & Internet
The Update Assistant keeps opening a dialog box stating that it has no access to the router. But whenever I try to do anything in the dialog box--click a button or close the dialog--an Internet Explorer...
1.Press Windows logo key + R, type winver and hit Enter key.( Check the version details of Windows 10 installed on your computer).
2.Shutdown your device ,restart it back and then initiate the upgrade to see if goes correctly this time.
If any third party Antivirus or Online security software is installed, then try to disable it for a moment then try to initiate the upgrade to see if it goes correctly.
In case problem still persist, then try to upgrade it in Clean Boot state.
1. Press Windows Key, type msconfig in the search box, and hit Enter.
2. On the Services tab of the System Configuration dialog box, tap or click to select the Hide all Microsoft services check box, and then tap or click Disable all.
3. On the Startup tab of the System Configuration dialog box, tap or click Open Task Manager.
4. On the Startup tab in Task Manager, for each startup item, select the item and then click Disable.
5. Close Task Manager.
6. On the Startup tab of the System Configuration dialog box, tap or click OK, and then restart the computer.
Apr 08, 2017 | NetGear WNDR3300 - RangeMax Dual Band...
Cannot initialize 3D engine
the problem on the Chessmaster 10th Cannot initialize 3D engine is that the game support only 1024x768 on screen resolution. Do that and works fine. Peace for all.
Jan 06, 2010 | Ubi Soft Chessmaster 10th Edition
How to roll back an accidentaly downloaded windows media palyer SPANISH version
Rolling back to a previous version of the PlayerWindows Media Player is a feature of the Windows operating system and cannot be removed entirely. However, in Windows XP, you can roll back to the version of the Player that was previously on your computer.
You must be logged on as an administrator or a member of the Administrators group to perform the following procedure.
  1. Disconnect any portable music or video devices that might be attached to your computer.
  2. Click Start, and then click Control Panel.
  3. In the Category View of Control Panel, click Add or Remove Programs, and then click Remove a program.
  4. Click Windows Media Player 11, and then click Remove.If Windows Media Player 11 is not displayed in the list of currently installed programs, then try the following:
    1. At the top of the list, select the Show updates check box.
    2. In the Windows XP - Software Updates section, click Windows Media Player 11, and then click Change/Remove.
  5. In each of the two confirmation dialog boxes that appear, click OK.
  6. When the rollback process is complete (it might take several minutes), click Restart.
  7. Click Start, and then click Control Panel.
  8. In the Category View of Control Panel, click Add or Remove Programs, and then click Remove a program.
  9. Click Windows Media Format 11 Runtime, and then click Remove.If Windows Media Format 11 Runtime is not displayed in the list of currently installed programs, then try the following:
    2. In the Windows XP - Software Updates section, click Windows Media Format 11 Runtime, and then click Change/Remove.If you installed a non-US English version of Windows Media Player 11, the instructions in the dialog boxes that are mentioned in steps 9, 10, and 11 might appear in English.
  10. In the first confirmation dialog box that appears, click OK.
  11. In the second confirmation dialog box that appears, select the Do you want to continue with the rollback? check box, and then click OK.
  12. When the rollback process is complete (it might take several minutes to complete), click Restart.
  13. Click Start, and then click Control Panel.
  14. In the Category View of Control Panel, click Add or Remove Programs, and then click Remove a program.
  15. Click Microsoft User-Mode Driver Framework Feature Pack 1.0.0, and then click Remove.
  16. Follow the instructions that appear in the Software Update Removal Wizard. If the Wudf01000 confirmation dialog box appears, click Yes to continue. When the software removal process is complete (it might take several minutes to complete), click Finish.
May 02, 2009 | Computers & Internet
Games not working
you can find direct x files on searching net and in some games they provide with dx setup
Jan 22, 2009 | Activision Operation Air Assault 2 for...
Having trouble playing game
You might need to update you version of DirectX by going to the microsoft site, or make sure that the 3D accelleration is enable in DXDIAG.
If using XP go to Start>Run (on the right hand side) and type in dxdiag then press enter. When the program opens click on the display tab and check that the 3D accellarator is enabled. Also carry out the tests within the display tab to make sure that there are no other errors. Check the game for the version of DX that it need against the version that you have, your version will be displayed when the dxdiag program opens. I hope this helps
Dec 08, 2008 | Eidos Interactive Video Game Consoles &...
Games
You can got to start>run> type in the box "dxdiag". This runs the directx diagnostic tool. Towards the bottom of this window it will display a version number the latest being 9.0C. If your version is not current you can update directx thru windows updates or you can download it from http://www.softwarepatch.com/windows/directx.html
If your version is current I would suggest updating your graphics card driver.
hope this helps
http://pchelpforanyone.blogspot.com
Mar 07, 2008 | Computers & Internet
Flickering games red jumpy video
Do you have the latest version of direct x installed? Direct x sometimes can cause problems with games using 3d acceleration, as some versions of direct x are not fully compatible with the video card and/or the video card drivers.
Nov 29, 2006 | XFX GeForce FX 5200, Graphic Card
Cannot install Quickverse 7 version from year 2000 because of Microsoft DAO.
Hi, I had the same problem and fixed it, (loaded my quick verse bible software by loading the software in SAFE-MODE. This mode stops the dao that is running. (probably micorsoft office at start up). This solution worked perfect....God bless
Sep 06, 2006 | Parsons QuickVerse 7 Essentials (fe11044)...
Microsoft Windows Vista Ultimate Edition Logo
109 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
