Question about Panasonic PT-47WX53 47" Rear Projection HDTV
R517 Burnt D" board
After checking the schematic on the D" board' Replaced R517 with the proper 10 k reistor checked d509 found it open no back to back reistance replaced it with a 1 KV. fast switching diode , found C524 measured .24 uf with my capacitor meter and replaced it with the required value of .22 uf 100 volts.
Powered up the tv and it shut down' with the resistor heating up, I removed the output lead from the flyback to the flyback divider .
The unit stayed on and I was able to measured 20kv with my high voltage meter, at the output from the flyback, and it was naturally to low.
My question is do I require the flyback as well as the flyback divider or just the flyback ?
70 year old retired bench tech from the days of tubes
  • Walter71140 May 07, 2008
    If you can help me please contact me at see71140@hotmail.com
    Thank you Sincerly
    Walter71140
  • Walter71140 May 08, 2008
    Thank you Slinteriors" on a small pension that will save me the extra cost in repairing my sons Tv. in which I will not charge him anyway.
    May your kindness be rewarded in many ways through your life,.
    Sincerly Walter,.
  • Panasonic Master
  • 8,617 Answers
You will need the flyback as thats way to low. The HV splitter will only direct the HV to each of the CRTs it doesnt change or regulate the HV in any way just directs (splits) it. Let me know if you need any more assistance.
Posted on May 08, 2008
R60A heater will not come on. Check cicuit board and found 2.7K reistor hot and smoking. Do I need a new circuit board?
Hi, yes I would say you do. I can't give you an answer on what caused this to go out, I do know the board will have to be replaced. I have seen boards with no apparent damage to them be faulty. Replace it and you will be up and running again.
Sincerely,
Shastalaker7
Dec 29, 2009 | Reddy R60A Utility Heater
TV powers up for literally a second then shuts down (PT-47WX49)
check R517 on the power supply board if burnt replace with 5% 1/4 watt 10K carbon resistor.
Dec 12, 2008 | Panasonic PT-47WX49 47" Rear Projection...
AKAI PDP4225M HAS RED LIGHT BUT WILL NOT POWER ON.
hi isolate ur power unit out replece ur resisitor & every other burnt items then check the schottky diodes in the secondary side &the electrolytic capacitors if bulgge or leak. if all this are ok , power then use voltmeter to test ur output voltages if ok , unplug your inverter  & power
Nov 10, 2008 | Akai LCT3201AD 32 in. LCD Television
Panasonic PT-53wx53 hdtv
Check the voltage across R517, should read about 12v if not replace C524 which is your AC gournd return and possibly D509 feed diode. I suspect that you get enough voltage to trigger the relay but just before B+ happens the 12v line drops well below the trigger voltage and the relay re-opens.
Bill
Oct 29, 2008 | Panasonic PT-53WX53 53" Rear Projection...
SAMSUNG HCM4215W Rear Projection HDTV shuts down
Low ohm resistors are open or poor solder connections on the bottom of a convergence IC.
You need to look at resistors in good light with magnifying glass. Bad ones may show as discolored or burnt.
The repair needs someone that has the schematic for the convergence cct, and can replace the burnt resistors or replace the whole convergence board.
http://calgaryconvergencerepair.weebly.com/index.html
If you are near Calgary, call me, if not, find someone that has done it before, preferably many times.
easyab
Aug 12, 2008 | Samsung HCM4216W 42" Rear Projection...
Protron PLTV-3250 fried
remove pwr board--inspect and you will find a heavy current diode which has eatin its solder pad area--if diode checks ok,repair it's connection.Install board and hook back up.Check for shorts in circuit.Cross fingers and plug her up------good luck
Jan 26, 2008 | Protron PLTV3250 32 in. LCD Television
Hitachi 46F500 46 in. is still bad
if you found the burnt resisters after you replaced the ic you probably burnt the ic out again,
Jan 24, 2008 | Hitachi 46F500 46" Rear Projection...
Akai PT4298HD No Power, Blinking timmer light
if you know aything about tvs which it appears you do check to see if you are getting voltage to the horizontal output ckt at the collector of the horizontal output transistor if you are probably you either have a horizontal drive or output problem if you are not check to see if you have either fuses or icps or pico fuses are open generally you will see about a 135 volts to yhe hoizontal output ckt.
Dec 15, 2007 | Akai PT4298HD Rear Projection Television
KOSS3102 parts
contact www.samsphotofact.com or repairworld .com they might have schematic for your system.good luck
Apr 23, 2007 | Koss KS3102 System
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
211 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
