We have a 37 inch lcd tv that now hums in the volume and you have to have it on 70- 80 volume tv is only 1 year in half
    Scholar:
  • 131 Answers
Hi humming noises in lcd. I have been finding bad capacitors in audio board. I fix alot of these tvs and lately we have gotten a lot in with humming noises.My estimates have been around 225.00
thanks doctor video leading edge electronics 1987
Posted on May 08, 2008
37" Philips LCD no sound.
Maybe the antenna that you are using is not picking up sound from the channels. It could also be the cable. If it makes a humming noise, it means that the speakers are getting electric current and that they SHOULD be okay. It also could be your tuner. Maybe check it all out at some tech place like best buy. Those guys can help
Aug 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Volume making humming noise when on
there is a bad ground.
the hum you are hearing is ac getting into the audio.check all the rca plugs on the set are plugged in all the way.do not run them close to a power bar either.
sometimes a second unit with it's own volume is hooked up to the tv and then the tv volume is up too high because the other box is turned down.if there is a unit hooked up,turn it's volume up ,and the volume on the tv down,otherwise the tv will amplify the residual noise.cheers,ed
Jul 04, 2009 | Proscan 32LB30H LCD TV
There is NO SOUND from the LC3760N 37 inches TV after I turn it on. I tried these buttons: increase volume button, decrease volume button, and the mute button. The TV was working last nigth; I don't know...
The problem was caused by a loose conexion. One of the cables that goes from the DirecTV box to the TV was loose. The problem was FIXED by pushing the cables to make sure there was a good conexion.
Jun 10, 2009 | HP LC3760N 37 in. LCD HDTV
My lcd tv makes a humming noise
My 37 inch vizio did the same thing. go to your menu screen on the tv and go sound. My tv has an option to turn speakers on/off. Once I turned my speakers off and the back on again everything worked great. hope I helped! if I did please let me know! youtube.com/xniax1
Mar 21, 2009 | Vizio VW37L 37 in. LCD HDTV
Blue screen on my haier 37 inch tv
my tv just went to a blue screen one day. I can turn it on and then it will just remain on the blue screen. Any button (except the volume) I push on the remote comes up on the screen "no signal". What would you suggest? I have been reading about replacing a fuse or board? Most of those are on the 42 inch version---I have teh 37 inch version.
Feb 02, 2009 | Haier HL37S 37 in. LCD HDTV
Hum in sound
the tv is picking up a 60 cycle hum from the bond wire.they did not filter the main audio board.to fix it buy a 3 wire to 2 wire ac plug without the bond wire. plug it into the wall socket an it should fix the hum. it fixed mine an now no hum. fletchb321.
Jul 24, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Broken screen on a 37 inch hd lcd
That may have been an expensive tantrum - I doubt if it will be repaired as a warranty item and the typical cost of replacement makes it a costly lesson.
I doubt if the LCD panel is priced under $6-700.
Jul 01, 2008 | Olevia LT32HVM 32 in. LCD Television
Aquos 13b4u
Most likely a cable box problem. You would see a consistent problem with a TV failure.
Dec 14, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
