Question about Samsung CLP 300 Laser Printer
My printer reads replace imaging unit is there any thing that iI can do so it will print
    Sergeant:
  • 223 Answers
Good day, had this problem many times. Try the following.
  • Turn the printer off by pushing the power button in until the LED light turns off. Make sure the printer is off before proceeding.
  • Remove the power cord from the back of the printer. Leave the printer unplugged for at least five to 10 minutes
  • Plug the printer back in. Press and hold the stop button for two to three seconds until the demo page begins to print
  • Posted on Aug 29, 2010
    • Trevor Groves
      Trevor Groves Aug 29, 2010
      Did this work?Please use the solution rating "thumbs" if your problem has been solved, or make another comment if your still having trouble. Thanks! Gurvy
    Printer has all full cartridges, not printing clearly
    Does this machine have drum units, image units and toner units? what combination? Replacing the toner cartridge will not fix the issue with the drum or image unit.
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
    Nov 20, 2015 | Office Equipment & Supplies
    Black copy usually is too light to read except for an inch on left edge, put in brand new black toner, same problem
    It could be that your imaging unit has a problem with the developer blades. If your printer looks faded like this: slamfix_53.jpg The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
    May 20, 2011 | Samsung CLX-3160 All-In-One Laser Printer
    Using CD Designer I try to print my disc on my Everest II printer and it appears to be printing and then the tray opens and the disc is blank - "no image printed on the disc" I do not get any...
    Check the ribbons. If your CD image is still on the color ribbon your print head is probably bad. If the image is on the transfer ribbon replace the heat roller.
    Apr 17, 2011 | Rimage Everest II Printer
    When printing, there is a band, right in the center of the print, that is very faded. Do I need to replace the imaging unit?
    If your printer is printing with faded vertical banding like this.
    slamfix_28.jpg The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
    Jan 21, 2011 | Samsung CLX 3160fn All-In-One Printer
    When I print the page is very black and hard to read...It has progressively gotten worse. Also, many times there is a duplicate image in a different place on the page. Something going on with the toner? ...
    The first thing to do with double image is to replace the cartridge!
    If you want to make sure that it is the cartridge, you can print a page, stop the printer in the middle of the run, open the printer, take out the cartridge, look inside the printer at the page, do not remove the paper yet, if the double image and dark page is there, your problem is from the cartridge, if the page is clean and nice as it should be your problem with the fuser unit and it needs replacment. Good luck.
    Nov 23, 2010 | Office Equipment & Supplies
    I have Minolta 2300W Laser Printer and it folds the first page only about 3 to 4 inches down makes a nice one inch fold but take that out and print again...next page fine.....now printing with two wide...
    The is blocked by dust on the side of the paper on the image unit that would have color associated with the print. Remove all the image units and clean all the laser glass. Replace those image units also if streaking as for the paper ensure correct paper side and media type.
    Jul 12, 2010 | Minolta magicolor 2300W Laser Printer
    The black print jobs have a shadow about 3 inches down the page
    I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
    Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
    Error message: cyan imaging unit is either missing or unseated
    The problem is with the top cover assembly. It could be a few things. I would first try the toner sensor flags(the magnet may not be strong enough to read properly). Also replace the toner cartidge because it's magnet may also have gotten weak. Third, I would try the Toner sensor board.
    I have had this problem with many printers and normally it is just the flags because of the weak magnets.
    Feb 10, 2009 | Xerox Phaser 7400/DXF Laser Printer
    Xerox Phaser 7700DN color printer
    I would be willing to be it's one of two things.
    Most common is a jammed gear on the imaging units. Remove all imaging units CMKY. The turn on machine. If the noise is gone, start replacing imaging unit one at a time tile noise reappears. Replace defective imaging unit.
    If that doesn't work remove the accumulator belt from the right side of the machine and then turn machine on, see if noise is gone. If so replace accumulator belt.
    May 16, 2008 | Xerox Phaser 7700DN Laser Printer
    Samsung CLP 300 Laser Printer Logo
    131 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    Victorman
    Victorman
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
