Question about Whirlpool GS5SHAXN Side by Side Refrigerator
I have a Whirlpool GS5SHAXNL00. The light in our refrigerator went out at the same time we lost the ref /freezer control indicator lights when my son opened the fridge last nite. He said he heard a "pop" sound but no further unusual sounds from it now. . Everything seem to still be working, fan/compressor/freezer lights/ ice maker. When I removed the refridgerator bulb (tested good in another outlet) the RC/FC indicators come back on. Temps seem to be good as I put in a thermometer to keep track. Suggestions as to what's wrong and how to fix it would be appreciated. Thank you for your assistance with this issue.
  • 944 Answers
The control board of your Refrigerator is the problem.Actually it is the one which controls the indicator lights.Since you say you heard a pop sound.The control board transistors has been burst or some times damaged wiring connections to the cause a short circuit.Please check for any burnt out wires through bulb to the control board.
The control board looks like this.If it is wiring problem solder it correctly and check for the replacement of damaged wires.
If board is the problem go for replacement.If you don't have hands on in it.take it to the nearest service center.
post a comment for further assistance
thank you for using fixya have a nice day:-)
Posted on Aug 29, 2010
My whirlpool fridge is getting warmer
there is a dampener control that lets air over to ref section, put your hand at the area to see if air is coming over from freezer.
if not look in freezer in back to see if it is all frozen, if so call tech.
if not push light button in freezer side with door open and liston for fan if fan does not run that is your problem.
May 03, 2014 | Whirlpool Refrigerators
I have a GS5SHAXNL00 Whirlpool Conquest refrigerator. This morning I opened the door to the unit and the light is flickering very faintly and there was a rattle sound coming from the bottom. When I press...
You have a faulty control board that will need t be replaced. Here is the board to order. The board is located on rear bottom of the unit.
The part comes with a 365 day, any part, any reason return policy.
Nov 24, 2012 | Whirlpool Refrigerators
Whirlpool gs5sbaxnl00 lights do not come on
If you do not already have the free Adobe reader Click Here=> Get Adobe Acrobat Reader I think your model number is a GS5SHAXNL00 and these parts will be close enough so click here for your models=> GS5SHAXNL00 Parts Manual PDF On page 16 of your PDF you will see part number 2303805 listed next to the number 6. Number 6 is the part location and the part is=> 2303805 Circuit Board or Timer You can also find the part here=> 2303805 Sounds like your control board is malfunctioning and I need to know if temperatures are stable in freezer and fresh food compartment. Also look inside freezer at the rear wall to make sure there is no frost building on the rear wall that would also indicate a defrost problem caused by this control board malfunctioning. I will be here to answer and assist you if you want answers but with lights not working and buzzer sounding is an indication that number one this control board may be bad. Let me know what you find and if helpful please rate this solution, Thanks, Sea Breeze
You also can find a user manual by clicking here=> Whirlpool Product Literature; Manuals, Guides and Instructions
Nov 15, 2011 | Refrigerators
Refrigerator lights both not working. Freezer / Fridge LED Control numbers not lighting up. Still works fine. Freezer lights work fine. Whirlpool Gold Model GS5SHAXNL00.
Sorry to read about your problem, I hope this helps you out.
you lost a control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Refridge. light went out. Bulb is good. Indicator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ref GS5SHAXNL00 NEW ICE MAKER NOT
Check your water pump to see if it's working.
Also you might miss some connection when you replaced the new one so double check all your connection
Nov 30, 2017 | KitchenAid KSRG25FK Side by Side...
Placing a refrigerator in the garage
IF YOUR GARAGE TEMP GOES BELOW 35 THE REF MAY NOT WORK WELL BECAUSE MOST REF HAVE THE THERMOSTAT AS THE REF CONTROL. THE TEMP IN THE BOX IS SENSED AT THAT POINT AND SHUTS OFF, THE REF SEEM TO WORK BUT THE FREEZER WILL WARM UP.
IF YOU WANT TO USE A REF IN THE GARAGE, FIND ONE THAT HAS THE THERMOSTAT CONTROL AS THE FREZER CONTROL. LOOK AT THE CONTROLS, THE ONE THAT HAS AN OFF POSITION IS THE CONTROL THAT IS THE THERMOSTAT. SO, THE FREZER CONTROL SHOULD SAY "OFF" SOME NEWER REF WITH FULL ELECTROINIC CONTROLS MAY WORK AS THEY HAVE INDIVIDUAL SENSORS FOR BOTH THE REF AND FREEZER SECTIONS.
Jul 14, 2008 | Whirlpool EL7ATRR Refrigerator
Water Filter Indicator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
Whirlpool GS5SHAXN Side by Side Refrigerator Logo
249 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
