I had the blinking power light problem with my magnavox 37mf321 flat screen. I replaced the 2200 uf capacitor and it worked great for about 6 months. Now the tv will not power up again. The green light turns on solid and the screen will flash randomly about every minute or so? More power supply problems? I did use a 2200 uf 50v rated at 85* instead of a 2200 uf 25v 105*. Could this be the problem?
  • spunwell Aug 29, 2010
    The green light was blinking before I replaced the capacitor. This time it is not blinking it stays on solid, does this still indicate power problems?
  • spunwell Aug 30, 2010
    The first answer addressed the blinking light problem which I mo longer have. My question is with the light being on solid and the blinking screen. Does this indicate a repairable problem, and where should I start looking for it?
  • 12,061 Answers
Yes for sure, you simply MUST NOT ever, use a Lower rated capacitor ever. I suspect, it may have failed again? Also the temperature rating is critical too, that's the 105 or 85, that's degrees C. It must be same or better. However what you replaced it with, should be OK, but the temp rating is way too low.
Also the capacitor is only the symptoms,NOT the cause. Capacitors DO NOT usually spontaneously fail. There MUST be a "Cause". It is this "Cause" that must be discovered, and Fixed, usually we have two things to repair when we have a fault. The Cause, and the damage done from that Cause.
With capacitors, it is usually AC "Ripple" that damages and eventually causes failure, that "Cause" for the "Ripple" must be found and Fixed, or it will simply cause the problem to resurface, after the new capacitor has been replaced.
It maybe leaky Diodes or bridge rectifier, other bad capacitors, other bad semiconductors, Vregs etc. As related this all must be fixed before fixing the symptom.
You MUST get a service manual, to be able to successful effect any repairs.
service manual link below.
http://www.eserviceinfo.com/equipment_mfg/MAGNAVOX_2.html
Posted on Aug 30, 2010
  • 19,396 Answers
Hi.
The blinking light is not telling you that the PSU is fried, and that you need to replace the capacitor. The blinking light is protect mode and is simply telling you that the PSU is getting forced to shut down because a wrong voltage had been detected by main chip on main controller board.
The 2200 micro farad cap is common cause for the problem , but it is not necessarily again the cause for the problem, and it may ahd not been the only faulty part in your set.
When problem is the capacitor you may usually notice that the capacitor is bulged, or leaking.
The original 25V capacitor can be replaced with a 50V 85 cap, that is more resistant to over voltage, the capacitor will work in the same way on the circuit, it will only blow less easily.
The minor chance that the cap blows, is the only difference. In this way the only property affected is the property of the cap of working like a fuse, preventing further damage. The 50V cap will work even better than the 25V cap to any other effect.
Replace again the cap, inspect other capacitors on power board and read Ohms on power board resistors to find out if they are OK.
The capacitor may have blown again because of problems related to power line stability, check wall plug grounding and use a surge protector.
If that does not work you will need to test in full PSU, main board and inverter in full. Here some general indications on testing procedure A full test on PSU and inverter
Posted on Aug 29, 2010
  • Ginko
    Ginko Aug 29, 2010
    The blinking light indicates that there is a problem, it does not address in any way the PSU, simply PSU capacitors is the most common occurrence, and often DIYer assume that the blinking light is addressing a power issue.
    The solid light instead indicates that the TV does not detect a fault. If there is no display this often means that either inverter or main controller board is fried. The first part to test is always PSU, by reading voltages. That is more difficult than many newbies can think, since voltages are often not active when there is a fault, and control lines must have low voltage on to keep single voltage outputs from PSU on.
Magnavox 37" model 37mf231d-37 wont tun on when i hit power button the screen lights up for a secongd and turns right back to black and the power button green light comes on and right back off I found
Your power supply is weak. If you think you can repair this I will tell you how. If you cannot do this,find someone who works electronics and share this repair. Two capacitors are bad. When pulling the back cover off, you may see one or two capacitors bulged. Even if they look good....replace these capacitors. The locations are numbered and, the capacitor having a value and temperature of 105 degrees.. Location of the first capacitor is 2074, value 25volts @ 2200 mf @ 105 degrees and will most certainly be bulged. The next capacitor may look fine....replace it. That capacitor location is 2066, value is 35 volts @ 1200mf @ 105 degrees. When you replace these, please be sure to get the polarity (positive leg and negative leg) of these capacitors seated correctly...this is a must. This will correct your TV. You will save lots of money, because you asked. Thanks for listening ..good luck...we will be here for your next repair.
Jan 02, 2013 | Toymax Magnavox 37MF231D 37 in. LCD TV
Blinking timer light and cannot turn on
How many times does the LED blink? Does it blink 6 times, pauses, and repeats? Or is it some other number of blinks? Or does it just blink continuously, once a second? (Note: on Mitsubishi's it is normal for the TV to blink rapidly for about 90 seconds after you plug the TV in, while the TV runs internal self-tests.) If the LED continues to blink continuously after 90 seconds, then the problem is on the DM board. There are 4 electrolytic capacitors, grouped together. I believe they are either 820 uF (mfd - microfarads) or 1000 uF at 16 Volts. If you check them, you will see that their tops are swollen (slightly rounded; not flat across). They will check okay with a capacitance meter or ESR meter, but don't believe your meter! Replace those 4 capacitors with either 820 or 1000 uF capacitors rated at either 16 or 25 volts. Make sure you use good, high-temperature (105 deg C) low-ESR capacitors. I recommend the "FM Series" capacitors from Digi-Key corporation, part number P12366-ND or P12379-ND. Less than $1.00 apiece. Good luck!
Dec 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have the same model 37MF321D/37 and the Blinking Light
I fixed it by replacing the two capacitors with 3300uf 25v instead of Magnavox's 3300uf 10v and a power swith that I ordered from http://www.encompassparts.com/. Also I did have a power supply put in from a repair place that cost $160.00. It is working perfect now and no blinking light.
Sep 20, 2009 | Philips Magnavox 42MF521D/37 Television
Magnavox 37MF321D/37 power light & screen flash, won't come on.
A full capacitor kit for the 37MF337 and 37MF321 models is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=21_77&products_id=216
The kit contains all 8 capacitors needed to rebuild the power supply board
Aug 27, 2009 | Philips Magnavox 42MF521D/37 Television
Magnavox lcd tv not turning on
Also changed swollen C2074 and C2081 and it now works perfectly! a bit daunting for a novice like myself but with a steady hand and decent 'put it back the way you took it apart' skills, all went well!
Mar 22, 2009 | Toymax Magnavox 37MF231D 37 in. LCD TV
Magnavox 32mf231d - Just a blinking green light, No Power
I had this problem, but saw other places that it was a cheesy capacitor on the power supply circuit board causing this. I opened it up and took the power supply board out and it was obvious which capacitor was bad...top was bulging and had black stuff on it. It was rated 2200 uF @ 25V...got a new one @ Radio Shack that was 2200 uF @ 35v. Soldered it in (I stink @ soldering, but gave it a shot and it was EZ). Watching the first weekend of college football w/o waiting on a flashing green light for up to an hour so the TV would start! I'm going to try to find the other websites that directed me to this to say THANK YOU...BTW my brother used to have fits with several Magnovox TV's and thier power supplies back in the old tube style TV days. I thought I didn't need to worry about this with an HD flatscreen, but was wrong. I will think twice before buying a Phillips/Magnavox/Funai/whatever else they are again. They have a long list of complaints and I believe a class action lawsuit to refer to about this problem. They should have stepped up and done something!
Mar 19, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
RCA L32WD22 Screen Blank, Green Light on
in the power supply you have six
Electrolytic capacitors you have to take the cover off the power supply to get to them. 3 of them will be 1000 uf @ 16v and the other 3 will be 1000 uf @ 35v the tops of them will probaly be bulged up replace those and that should solve your problem. you can replace all 6 with 1000 uf @35v and get them at radio shack for $1.79 each.
Jan 15, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Mitsubishi WD-62525 Red Status Light After Cap Replacement
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
Sep 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Magnavox 37" flat screen model no.37mf23id/37
Yes, he means 2200 microfarret (called uf from here on out). Another important concern when buying a replacement is the voltage. You need to get something that is at least 25v. I recommend a 35v or better. Another notable point is that this may not always fix the problem. As with mine, there was also a 1200uf (microfarret) 35v capacitor that was blown. You can tell this because they bulge at the top. I have both of these caps (2200uf 35v and 1200uf 35v) on order and they will be here tomorrow. If I do not post back here then they fixed the issue for me. I suspect that this will resolve the problem. Look for bulges on top of the caps. This is an indication that they are blown. Most all of you experiancing these symptoms will see the 2200uf cap bulging but you may also see others bulging too. If you do then you need to replace those too. No electrolitic capacitor should be bulging at the top so if its bulging its bad, and if its bad then your tv will definitely not work. Have fun.
Jul 18, 2008 | Televison & Video
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
Electro Med Services...
