Question about Lexmark Z1300 InkJet Photo Printer
I didn't have a disc so i downloaded one and it worked fine until my granddaughter unhooked it and took it to her house then she brought it back and i hooked it back to my computer but it won't pick it back up
  • 4,281 Answers
For that you need to uninstall all usb drivers from device manager then it automatic install all usb drivers.For that right click on my computer icon then click on property then click on hardware->device manager then you can see all drivers list uninstall all usb drivers 1 by 1 then it will automatic install all usb drivers. then uninstall printer driver from control panel->add remove program then download driver from below link and install.Also make sure usb cable is working fine. Click here Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 29, 2010
I PUT IN THE DISC AND IT DOES NOT READ DISPLAY NO DISC
Try another disk, see if it plays. Try the one that won't work in another blu-ray player if possible. I tried to watch a disk I got at a redbox rental, it fouled 2 dvd players, but took it to a friend's house and it played just fine. When I went to return it, it wouldn't go back into the redbox machine. I had to try at another redbox machine and it took it. So could just be a problem with that disk.
Jan 22, 2011 | Sony BDP-S300 Blu-Ray Disc Player
IP address issue for PS3
reset the modem and router it is not issuing the ps3 a new ip ...reset should solve the issue
Mar 10, 2010 | Sony Playstation 3 (PS3) Console
My toyota sienna,2000 city horn sometimes doesn't work. What could be the problem?
I had two or three mechanics look at it but I ended fixing it myself at no cost but time. The clock spring is unlikely the culprit as it is housed and there is not much too it to wear out since it's a ribbon (as in computer) at a high cost of $300. The ground circuit is broken by dirt and grime by now. Unfortunately you have to remove the airbag and steering wheel. 1). Dive the car straight and park to set the steering true straight. 2). remove the Red positive cable from the battery. 3). Loosen throughly the two Torx screws that hold the airbag in place. If you have radio controls, remove that first. Tip: If it doesn't loosen, apply outward pressure to the assembly so the screw will take and unscrew. The airbags has horizontal clips, so, jiggle side to side and lift one side up and it should remove. Unhook the cable. 4). Unhook all cabling and remove the steering wheel. I use a liquid wrench type lube and looened the nut and jiggled the wheel off without a puller. The nut keeps it from hitting you. 5). Remove coil spring. 6). Remove the clamshell housing (couple/few screws). 7). Place newspapers on the floor and under the steering and spray the heck out of the bearings as well as the u-joint towards the floor with carb cleaner, then WD-40. I used an entire can of carb cleaner just to make sure. 8). Put it back together but before screwing in the clock spring, make sure you wind it till it stops then back off 2.5 turns so there is play for wind and unwind as the steering is about 4 turns total. I actually didn't do this (thinking I didn't move it) but my wife took the car and forced the steering breaking the ribbon. So actually, it cost me $300 to replace the clockspring that was perfectly fine. I took it apart and attempted to re solder but the horn kept going off by itself, and there is the danger of the airbag going off too. Not worth it. My steering wheel was never centered right, so I kept driving around the block without the airbag, until the steering wheel was centered before putting everything together.
Oct 19, 2009 | 2000 Toyota Sienna
Haier Air conditioner problems - e1 message
try turning it off holding buttons each individually in for 3 secs then in an hour plug back in ... the rep from Haier gave me this advice ... just waiting my hour now ... i also hear that the remote works for sure ...
Jul 15, 2008 | Sharp AF-S100FX Air Conditioner
Jvc model mx-c33 home stereo
Did this problem start as soon as you moved it or did it take a couple of weeks? also did it get dropped during the move?
Feb 05, 2008 | Audio Players & Recorders
Disc err
Same problem was working fine dec 31st at friends house took it home and now it won't read cd's
Jan 02, 2008 | Nintendo Wii Console
Presidian dvd recorder pdr 3222
Have had the same problem with my Presidian3222 for the last year, if I recorded something it would come back as invalid disc or blank disc or would not close disc out right, got so damn mad almost took a hammer to it last night, unplugged it like clicky said, did no good, thought cable co may have been sending single to screw up recording, but today took camcorder and tried to record something, same thing which seemed to let the cable co off the hook.
the following seemed to have fixed the problem, first open the player then unplug it, close the drawer 1/2 way, then I took compressed air and blew inside the player to clean the laser after that I have been able to record 3 movies and close the disc properly and finalize the disc properly, I even had 50 new disc made by sony that recorded kept saying were invalid, reads them fine now, I hope this helps everyone, because I was on the edge of putting this thing in the trash last night.
R.J.
Nov 26, 2007 | Dual Presidian DVD Recorder
Sanyo 24" TV
as you say that tv works fine at the place of tv tech so it sounds me that you please tell electrician to check for ground connectionat your house. if it is ok then in future you will not any problem.
Sep 28, 2007 | Televison & Video
Lexmark Z1300 InkJet Photo Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
