Question about GE WDSR2080D Top Load Washer
AGITATOR THE AGITATOR IS NOT MOVING BUT THE WATER GETS DRAINED.SO CAN I FIX IT AT HOME OR DO I NEED TO CALL THE REPAIRMAN.
  • joeymellow67 Oct 15, 2008
    my ge washer will fill with water and then will not go to the wash cycle. It will be totally silent. Is this an electrical problem with either the pressure switch or the timer? The belt is fine and washer does spin without noise on rinse cycle. Motor, clutch and transmission appear to be working fine with no signs of wear or oil leaks.
  • 975 Answers
Water gets drained when it passes the washing cycle on the knob ? do you hear the motor humming ? like it wants to start? if no sound from motor then check the sensor switch located under the top of washer where door closes, it could be loose or defective, if you hear sound coming from motor , check the belt ,if belt OK, then MOTOR need to be replace, hope this info helps , AJ
Posted on May 07, 2008
Kenmore 110.24622300 won't spin, agitate or drain but fills
There is a coupling between the motor and the transmission for the agitator that is made of plastic and rubber. The plastic gets brittle and cracks, so it will not agitate anymore. The hum you hear is probably the motor spinning without driving anything. The pump to drain the water is also driven by the same motor. If you go online you can find instructions for how to replace the coupling. You can order them from Amazon, I found one for mine for less than $5.00. This is the most likely suspect. If you are mechanically inclined, you can replace it yourself. If not, a repairman can do it relatively quickly, but there will be a hefty charge for a service call and the labor rate it high.
Dec 12, 2013 | Washing Machines
Drain line clogged on Whirlpool model ET1CHMXKB09. How do I access the drain line?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with most old washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
TOOLS NEEDED TO SOLVE PROBLEM ARE BELOW.
Bucket and rags,Screwdriver,
New drive belt (if necessary),
New drive motor (if necessary).
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Thanks.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Jun 01, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 110.25842400 fills with water and doesn't do anything else. Can't get it to spin, agitate or drain.
check to make sure your lid switch is clicking. Some Kenmore clothes washers will not spin or agitate if the lid switch is not working. Hope that helps.
XCEL Energy Repairman
Apr 27, 2009 | Kenmore Washing Machines
Whirlpool Ultimate Care II LSQ8543JQ0 WON'T SPIN
really sounds like a coupler issue. May look fine but if one of the teeth are busted it will do this. You can get a tutorial for fixing this here. http://www.shop.washermd.com/category.sc?categoryId=4
Jan 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 70 series
Okay...I'm a little confused on your symptoms. You initially said it fills, but doesn't agitate or spin, but drains.
Then, you finished with the washer filling, no agitate or spin, but now doesn't drain.
Which one is it?
The symptoms you describe are usually associated with the following:
1. Fills, may or may not agitate, won't spin or drain - lid switch.
2. Fills, may or may not agitate, won't spin, but still drains - motor coupling.
3. Fills, may or may not agitate, won't spin or spins slow - gear case.
4. Fills, agitates, spins, but does not drain – water pump.
NOTE: These are the more common failure items with these symptoms.
Double check the lid switch by opening and closing the lid. You should hear a clicking noise to indicate the switch is working. The switch is located under the top panel along the wash tub rim on the right-hand side. If not, check to make sure the lid strike (small plastic piece on the lid itself) is in place. This activates the lid switch when the lid is closed. Also, check the mounting screws along the rim (there are two of them) to see if they are tight.
If the motor coupling were bad, the washer would still drain, but there would be a rattling sound as the washer tries to spin or agitate.
If you need replacement parts, go to searspartsdirect.com and type in your model number in the "Search by Model Number" window. The lid switch can be found under the "Top and Cabinet" heading as item number 11 (part #3949238). Instructions on how to replace are located at the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you wish to replace the motor coupling, the part can be found under the “Brake/Clutch/Gearcase/Motor/Pump” heading as item number 13 (part #285753A). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Now, there’s a couple of ways to drain the washer. If it’s a simple lid switch problem, you don’t need to drain the washer to replace the switch. With a broken switch repaired, the washer will run and drain by itself. However, if you wish to drain the tub you can use a shop vac to pull a vacuum on the drain hose. This may take a few times depending on the size of the shop vac. These wash tubs typically have about a 35 gallon capacity. If you do not own a shop vac, you can by-pass the lid switch by jumpering the two BLACK wires at the lid switch connector that is connected to the console. CAUTION: Make sure you UNPLUG the washer before jumpering, then plug back in.
I hope this information is helpful to you. If I’m wrong about the symptoms, please post back and update me on what the washer is or is not doing, so I can assist you further.
May 15, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Agitator
Hi , need to service by a profesional repairman near you,some parts to replace like bushing .
Jan 22, 2008 | Washing Machines
GE WDSR2080D Top Load Washer Logo
70 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
