Question about GE DBXR463EDWW Electric Dryer
Hello. I have GE electric dryer DBXR463EG6WW. The starter switch does not work. I am getting power to the dryer. The light goes on when the front door is open, so not a power problem
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
My ge dryer model DRS483ED1WW won't turn on all it does is buzz when I try. I have changed starter switch that didn't work
does the drum and motor turn by hand freely. but i think its possibly the bushes in the motor. just have a look at motor and see if theres black carbon dust on it, you will get this on a motor anyway but not in excess
Jan 06, 2012 | GE DBSR453EBWW Electric Dryer
Hello all I have a GE DCLR333ETOWW Electric dryer. When we got it the start button was missing so I had the Blue and Brown Wires sticking out and we would just touch them together for a second and the...
first things first. Electric dryers are 220v on a double breaker in your breaker box. (120v for the motor,120v for the heater element). When your dryer sparked, it probably tripped the breaker. Note: you REALLY need to buy a switch an get those exposed wires back inside of the dryer where they belong...just sayin'
Apr 30, 2017 | GE Dryers
My ge profile dryer won't start.I checked the breakers and they were ok. Any other suggestions?
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 08, 2010 | GE Profile Harmony DPGT750EC Electric...
How do you remove the back plate of a GE profile Harmony. I have the screws out, the top off. Does the back plate slide up? Do the sides have to come off with the back? Or what?Please. Thanks
the back plate does not come off.
to get to the motors, belt, sensors...
remove the screws to the inner top cover(under outer cover) and the plastic strips- slide strips front or back to remove.
remove the screws to the front panel- 2 top front, 4 inside door.
as you pull the front off, unhook the light and the door switch
remove the scres to the front drum plate.
reach under drum and unhook belt-take note how it goes around motor and tensioner.
lift drum out and observe everything else.
Jul 30, 2009 | GE Profile Harmony DPGT750EC Electric...
GE ELECTRIC DRYER - WILL NOT COME ON.
Very often the problem is the resetable thermostat, if you open the top you'll find it on the back inside, you can test with an ohm meter or just bypass it to test it.
Mar 01, 2009 | GE WSXH208A Front Load Washer
Dryer has power won't start cycle Hi - The light goes on inside the dryer, but when I close the door and select start nothing happens.
If that doesn't do it, (door switch), then check underneath the top and look for the thermal overload switch. Bypass it and see if it runs. If not, then start back at the wiring at the receptacle and then follow to the terminal block located in the back of the dryer. You could be getting power to the receptacle but it may stop there because of a loose wire. You could have lost a leg of power.
Feb 04, 2009 | GE DBSR453EBWW Electric Dryer
GE DPGT750 not heating
check your email this manual will take you step by step thru the repair
Jul 02, 2008 | GE Profile Harmony DPGT750EC Electric...
GE DBXR463EDWW Electric Dryer Logo
425 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
