Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
On my Cabrio, the washer goes through all of the cycles fine until it gets to the final spin. No matter the size of the load, I get a "ul" code. I can move the items in the washer around but it contines to do this. It happens when the washer goes into it's final spin cycle with about 12-14 minutes left. I did open the top of the washer and noticed the grease on the four white semi-circular balls that support the basket was basically nill. I did regrease these but to no avail. Any help would be greatly appreciated.
  • johnson_gale Aug 29, 2010
    Yes I am here for the repair. My question had to do with "ul" code so the response I received was not helpful. I assumed people would want an honest response.
    Sure, i would love the repair manual. But I have to ask, what does the lid switch have to do with it.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. ULis displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
  • 3 more comments
    No, this does not fix the problem.
  • Rylee Smith
    Rylee Smith Aug 29, 2010
    Then it seems that the issue is with with the lid switch of the washer. I dont think the rating is valid please change it and let me know if you require its repair manual.
  • Rylee Smith
    Do you even want to repair this yourself or you are just here for this fake/NOT HELPFUL rating...Please post back if you want to repair it yourself as the lid switch seems to be bad and should be replaced.
  • Rylee Smith
  • Rylee Smith
    Rylee Smith Aug 30, 2010
    Sorry, but the response was an honest one. You can click on this link for the repair manual aAnd also as you have already tried to regrease the circular balls then the issue seems to be with these suspension rods going bad & should be replaced, it comes in a pack of four and you can buy them from this link. Please do change the rating of this solution as still dont think its should be rated as NOT HELPFUL and post a comment for further assistance.
    Thanks
    Rylee
Whirpool Cabrio washer - UL code, but I redistributed load & clothes still wet. What could causes wet clothes after spin cycle?
the washer has 2 speeds on spin cycle apparently your did not shift to high spin or final spin l
Apr 21, 2018 | Washing Machines
Ul code almost every load
I THINK THERE MIGHT BE SOMETHING IN PUMP
Jun 17, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio spins off center and stop with ul code
Ul-Unbalanced Load
uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
the load.
May 28, 2012 | Whirlpool Washing Machines
No matter what I do my cabrio washer get ul code. I have cleaned and regreased all pivit points as recomended
uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to re-balance the load.
If the mini-cycle is unsuccessful, ul will flash until the door lid is opened, allowing the customer to view and redistribute
the load. Not sure why you would lube anything for this fault code. What may be the problem is the struts that steady the washer drum, they are in effect shock absorbers, they are likely the source of the code.
Jan 27, 2012 | Whirlpool Washing Machines
Wtw6600 washer has UL code and has trouble agitating and spinning.
The UL code means Unbalanced Load. Open the lid and move your clothes around so they are distributed evenly. Your spin cycle will then work normally.
Apr 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
UL keeps coming on the screen, will spin for 1 or 2 minutes and then UL shows up again
Hi, UL means Unbalanced load in Whirlpool Cabrio....
UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load....
Oct 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ul code about 10 to 15 seconds into spin cycle machine is level code comes up even if i run it empty
Hi
Thanks for using FixYa. UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The time display section indicated a code UL instead of the time left on the washing cycle. What does this code mean
keep getting a ul code and machine barrel knocks back and forth in the washer on spin cycle until the ul comes up. Cannot get it to quit. What is the problem?
Thanks
Aug 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Every load Ul code in spin
HI,. this codes represents a control board fault. you will need to replace the Machine and motor control board.
This board is a all in one unit. it controls the basic logic points and the motor as well. It is damaged.
Aug 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
349 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
