Question about Canon PIXMA MX330 Multifunction InkJet Color Printer
How do I change the ink on the Cannon MX330? I cant find where the cartridge is
    Problem Solver:
I am writing this to enquire in regards to Canon Pixma MX320. I bought a Canon Pixma MX320 about 3 weeks ago, and I have brought it over to overseas. I am wondering if it is possible to change from the general ink cartridge that this particular printer use, which is PG510 and CL511 to another similar ink cartridge, which is PG810 and CL811. This is because, where I am living right now, doesn't have the particular Canon Pixma MX320, but instead Canon Pixma MX328 and MX338. The Canon Pixma MX328 and MX338 uses the PG810 and CL811. So, is it possible to substitute from PG510 to PG810 and CL511 to CL811 for Canon Pixma MX320? Thank you for your help.
Posted on Aug 30, 2010
Canon mx330 how to change ink cartridges
Use the thumb drill to literally drill a hole into the side of the old cartridge. Make sure to chose a location that's closer to the top of the ink cartridge to avoid over spillage when you add the new ink. Once you have the hole just squeeze in some ink of corresponding color into the hole. Not a huge amount, but enough to get some use out of it before the next refill. I highly recommend covering the hole afterward with a sticker or something so that you don't dry out the cartride. Reinsert the cartridge into the printer and use. (: All set!
*Note: You may have to reset the count on the cartridge to avoid getting messages that the ink need to be changed. From here on in, use your eyes to determine if the cartridge needs a refill (:
Dec 07, 2014 | Apple Nano 69472169 4X130Ml Premium Refill...
WHAT CAN I DO TO MAKE THE REFILL CANNON MX330 WORK, PRINTER HAS RUN OUT OF INK PROMPT ON SCREEN
Press STOP/RESUME button on printer for about 6 seconds. This disables the ink monitor and printer should work again. You will have to repeat this for the second cartridge - when it indicates empty too.
Aug 24, 2014 | Office Equipment & Supplies
CANNON MX330 REFILL CARTRIDGE HOW CAN I MAKE IT WORK
Hold STOP/RESUME button on printer for 6 seconds
Cannon mx330 does not recognize my ink cartridges. Any solutions?
First you have to make sure that you are using the correct ink cartridges. If they are the correct cartridges, simply take the out and re-insert then tightly.
Aug 27, 2011 | Computers & Internet
I have a cannon printer mx330, i do not know where to find the cartridge, because it is out ink
The cartridge carrier can be accessed by lifting the top front (**** shell) of the printer.
You can download a manual for your MX330 from
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx330#BrochuresAndManuals
See page labeled "replacing the fine cartridge".
Let me know if you have any other questions. Thanks.
Please make sure to rate this solution.
Jun 02, 2011 | Office Equipment & Supplies
Cant get my canon mx330 printer to work
Multifunction devices usually require two separate inks to acquire functionalities. For example, an empty ink cartridge especially the color ink may still produce copies without multi ink features. However, any attempts to dismaunt the ink cartridges would require restorations from the computer settings. First, inspect the printer for empty accessories that require replacements. After acquiring and replacing ink cartridges makes way for the next processes. Second, connecting the printer that has been restablished would produce display results requesting printer copy allignments. Attempt to print a document to produce the results for alligments. Goodluck
Jan 12, 2011 | Canon PIXMA MX330 Multifunction InkJet...
Where is the ink cartridge located in the canon pixma mx330 printer?
in the video link below there will be the answer at 7:28 in the video, fastforward to your spot and pause for your paste...
http://www.youtube.com/watch?v=x7yY8Y54z3A
Goodluck..
Mx330 MX340 All MX300 series are pretty much the same...
Aug 16, 2010 | Canon PIXMA MX330 Multifunction InkJet...
I have a new Cannon MX330 printer. I have always had an HP. where do I access the old cartridge so I can replace it-do you have a diagram?
Just click on the link. It will lead you directly to the page where you will be instruct on how to access the ink cartridge.
http://www.retrevo.com/pdf/23360ci977/6/Install+the+FINE+Cartridges#q=Canon+MX330
It will also let you view the whole content of the user manual
Aug 05, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Where is the ink cartridge...I need to change it
Open front door, then open the second door behind it, then find ink tray, slide it to middle of printer, then pull up on front, pull up and lift out cartridge
Nov 12, 2009 | Canon PIXMA MX330 Multifunction InkJet...
How do i change the ink on canon mx330?
They are not in the middle as shown in the manual. I still can't find them. God! this printer is only that big and I spent three days looking at every possible corners and gaps and still can't see where the ink cartridges are. Will not buy this Canon printer again.
Nov 02, 2009 | Canon PIXMA MX330 Multifunction InkJet...
Canon PIXMA MX330 Multifunction InkJet Color Printer Logo
851 people viewed this question
old marine
old marine
