Question about Keurig B60 Coffee Maker
How do you clean the machine do you just run water through it to clean the filter
White vinegar is recommended by the manufacturer, especially if you use tap water and it is considered hard water. Go on line and read the manual
Posted on Aug 29, 2010
How do I clean the filter on the Novotronic W 310 Miele washing machine
Cleaning the fluff filter and pump
Check the fluff filter initially after 3 - 4 washes to ascertain how often it is likely to require cleaning. With normal cleaning approx. 2 litres of water run out.
If the drain outlet is clogged, more water will be retained in the machine (up to 25 litres).
Caution: if laundry has been washed at a high temperature,
water draining out of the machine will still be hot!
Take the (yellow) filter flap opener from behind the detergent drawer facia panel. Open the flap.
Place a dish under the drain fixture. Turn the fluff filter lid round 2 - 3
times. Do not take it right out.
With large volumes of water when the dish is full, screw the fluff filter back into position and empty the dish before repeating the procedure.
Once the flow of water ceases, remove the fluff filter completely and
clean it.
Remove any foreign bodies (e.g. buttons, coins, etc.) and fluff.
Turn the impeller by hand to check that it is free to rotate. Any foreign objects causing an obstruction should be removed.
Clean the inside of the fluff filter housing. Remove any deposits of lime scale and detergent or foreign bodies from the thread of the filter housing and filter unit (as these objects can cause a leakage
of water). Put the fluff filter back and screw it in firmly.
Cleaning and care
To clean the water inlet filters
The washing machine has two filters to protect the inlet valves. These filters should be checked every 6 months or so, or more often if there are frequent interruptions to the water supply.
To clean the filter in the union in the open end of the inlet hose:
First turn off the stopcock.
Unscrew the threaded union connecting the free end of the inlet hose to the stopcock.
Remove the rubber seal from the recess. Using pointed pliers, take hold of the plastic filter bar, remove the filter and clean.
Put the filter and seal back in the reverse order and reconnect the
hose. Turn on the stopcock and check the connection is watertight.
Inspect the inlet hose which is subjected to high pressure while the machine is in operation. The hose should be replaced if there are small cracks in the surface, or if it has been otherwise damaged.
If replacing the inlet hose only use a hose able to withstand pressure up to 70 bar. Miele's own hoses meet this requirement.
To clean the filter in the water inlet valve:
Using pliers, carefully loosen the ribbed plastic nut on the inlet valve,
and unscrew.
Use water pump pliers to withdraw the plastic filter by the bar.
Clean, put back and secure.
The two filters must be put back in place after cleaning.
Mar 08, 2015 | Miele W310 Front Load Washer
Soloniod faulty
check the filters
at the intake the solinoids {water intake valves}
there is a small filter
you need to turn of the hot and cold water
like under the sink
take off both hozes hot and cold
then take out the filters at the machine intakes
and clean them
you can take out the filters
using flat nose plyers to gently pull them out
clean them out from brown crypto spyridion carcus
and other rubbish
you can leave the filters out and run thru the whole machine on like 30deg with a calgon tab
does help {not scotland no lime here }
then place the filters in the intakes again
or replace the valve if it leaks water after cleaning
then the spring in the valve of the valves solinoid coils isnt so good
and needs replaced
but can just be a blockage
above all if its a new machine you just got
perhaps it been in a low presure area so the valves will be
low presure hot and cold
usually its just the hot that is low presure
so you need to check the cold water is getting plenty on like 2 -3 bar presure...
Mar 05, 2015 | Washing Machines
HOW DO I STARTS MY WASHING MACHINE AGAIN CAUSE IT ALWAYS `IE` ERROR EVEN I ALREADY CLEAN THE FILTER,CHECK HOSE,THIS ERROR HAPPENS WHEN SOMEONE USE IT MANUAL WHEN NO WATER IN SERVICE,I MEAN HE MANUALLY
The IE or E1 error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve
If you are trying to use the machine manually, there needs to be enough water in the machine to tell the level sensor when to switch off the water inlet solenoid valve. Failing this, the machine will only show IE (Inlet Error) and refuse to work.
Feb 15, 2015 | LG WD-1070QDP 7 Kg Direct Drive Washer
Machine wont fill with water
Does it run through cycles without filing or does it do nothing? If nothing lilely the timer otherwise the water fill valve id defective
Oct 12, 2014 | Washing Machines
Clean filter washing macine
With any washing machine the filter is located at the bottom front and under flap unscrew plug.Beware water will come out.
Sep 27, 2014 | Amana Washing Machines
I have problem with water flooding from machine I have put unblocker cleaner down waste water down pipe so must be filter on machine on previous machine they have a filter on the front you can clean
Hi
Not sure about your machine, we have a front loader. I guess you are talking about the same thing.
There is a filter in the front bottom, to collect pins, coins etc.
If this is not replaced correctly it will leak.
To service this filter unscrew it, clean it and the objects from it, then rescrew it back into the machine.
To test, without running the machine, simply pour some water into the detergent tray at the top. If water comes out the filter - it is not sealed. simply remove and try again.
Hope this solves the problem
Jan 12, 2013 | Washing Machines
Do I need water filters?
depending on how bad your water is..if you are on well water..you may want to filter your water..
Their is no filter, in the unit...But you will have to do a vinegar/water clean out...i put 1/2 cup white vinegar with full tank of water..keep running machine until empty, then run a full tank of clean water..
taste water..so no bad taste
Dec 18, 2010 | Keurig B70 Coffee Maker
Cuisinart dcc-1150 coffeemaker
To replace water filter: Pull water filter holder out of reservoir, snap open, insert new charcoal water filters (can be ordered from Cuisinart or purchased froma store like william-Sonoma)
To clean machine: Run 2 cups water and 2 cups distilled white vinegar through machine like you would normal coffee.
To get rid of annoying self-clean lite: unplug machine from wall outlet for 20 minutes or longer.
-Tha Mp3 Doctor
Oct 24, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Water not filling up properly
More than likely, you have a problem with the filter screen in the hot water valve behind the machine.  Turn the hot water off and remove the hose connection to washer.  Check the filter screen inside the water valve to make sure that there is no debris blocking it.  You can pull the screen out and rinse through with water.  Also, hold the screen up into the light to see if you can see through the screen clearly.  You may want to use an old toothbrush to clean it out.  Reassembly the filter screen back into the water valve.
Get a small bucket and run the water through to clear out any debris in the water line.  Reconnect the water hose to the washer and try starting the machine.  If you still have water issues, then a qualified LG technician is needed to find the problem.
May 01, 2008 | LG WD-16110FD Front Load Washer
Quisinart DCC 1100 Series Coffeemaker
Hello sjones29,
This should be an easy fix. In one of the corners, under the top of the lid, you will find a water filter stick with a carbon filter that is likely clogged. Pull it out and remove the filter. Shine a light into the cavity of the unit and clean out the debris that may be in there. Replace the filter holder. (You can buy more filters on Amazon inexpensively). Filters are good for about 60 days. Then do a run through of water/vinegar solution. It should be 2 parts water and 1 part water. When done, run through a pot of fresh water to rinse. This should stop the light from blinking and make it so you can enjoy some great coffee.
Hope this helps and good luck! I appreciate positive feedback. :o) Thanks. NormanZ
Feb 24, 2008 | Cuisinart Brew Central 12-cup Coffee Maker
Keurig B60 Coffee Maker Logo
37 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
