Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a 137e not enough oil on the bar. I took the clutch cover off, removed the bar and chain, started it and see only small spurts of oil. I checked the filter in the bar oil tank and it is clean. I do not see any adjustment screw, I do see a small ball on the plastic clutch base. what esle can i check??
    Scholar:
  • 144 Answers
Could be the oil pickup or pump assembly. Pump assembly can be found at Partsbuggy.com here.
Posted on Dec 14, 2010
Chainsaw starts ok. When I try to cut it will stop half way. When I hit throttle it the chain will move and then it slows down and stops. Any sugestions?
Make sure the bar and chain is being properly lubricated by running the saw at speed with the tip near some cardboard--it should throw off a thin line of oil after a moment or two. If dry, remove the bar and chain (make sure the chain brake is set to off), and clean the engine area where the bar fits to it. Start the engine--oil should ooze out of the small port in the engine side. If ok, clean the small oil passages that run from the large holes (in the drive end of the bar) out to the chain groove on the bar edge. Wash out the interior of the clutch hub with spray carburetor cleaner to remove excess oil. Reassemble the bar/chain and adjust the chain until it just comes up to the lower bar, but not so tight that you can't turn the chain easily by hand. Make sure the chain is filed sharp enough to cut your fingers if not careful. Hope this helps!
Nov 11, 2010 | Garden
Chain saw starts and runs chain is moving at high speed but when placed against log it slows to a stop and does not cut, what should I do
Remove the clutch cover, bar, and chain. Wash out the interior of the clutch with spray carburetor cleaner to get rid of oil build-up. Reinstall the bar, chain, and cover after cleaning the bar drive-end small oil passages that run out to the chain groove. Adjust the chain up to the bar, but not so tight that you can't move the chain by hand. Hope this helps!
Jul 29, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Chain keeps slipping off saw
Remove the bar and chain. Lay the chain out on a bench or table and examine for sideways bent/broken links, badly damaged cutting teeth, or damaged drive teeth. Inspect the bar chain-groove all the way around for any damage. Make sure the tip sprocket turns freely and is not damaged. Check the sprocket on the clutch drum for hooked teeth or other damage. Clean the small oil passages that feed oil out to the chain groove in the drive end of the bar. Start the engine and check the engine side port where the bar fits to--it should ooze out oil from the small port there. If everything checks ok, re-assemble the bar and chain leaving the cover fasteners finger tight. Adjust the chain until it pulls up to the bar, but not so tight that you can't turn turn it by hand. Tighten the bar fasteners and re-check the chain tension. Start the engine and hold the bar tip near some cardboard--it should throw off a thin line of oil after several moments of running at speed. Hope this helps!
Jul 17, 2010 | Craftsman sears 18" Chain Saw Chain (...
My Makita dcs 4610 chansaw is not putting oil on the chain. The oil resevoir is full but no oil. I have cleaned it in general but want to know where the oil comes out in case it is blocked.
Remove the bar and chain, then clean the side of the engine case where the bar fits to. Start the engine--oil should ooze out of a small port in the engine case. If ok, clean the bar and cover, then clean the two small oil channels in the drive end of the bar which allow oil to flow out into the chain groove on each side (only one is active depending on which side of the bar is 'down'). If no oil came out of the engine port, then you need to investigate the oil pump (behind the clutch), oil lines, and oil filter in the tank. The oil pump, in particular, has plastic gears that can become damaged. When oil appears at the port, assemble the bar and chain. Adjust the chain (cover fastemers finger tight) so that the chain just pulls up to the lower bar edge, but not so tight that the chain can't be pulled by hand. Make sure the teeth cut toward you on the bottom run and are properly sharpened. Tighten the cover fasteners firmly and recheck tension. If ok, run the saw at speed for several moments with the tip near some cardboard--it should throw off a thin line of oil. Hope this helps!
Jul 10, 2010 | Makita DCS6401 20 20",64cc Chainsaw 2...
Clutch cover smoking
Remove the bar and chain and wash out the clutch internals with spray carburetor cleaner. Clean the side of the engine case, start the engine and watch for oil oozing out of the side port. Clean the bar drive-end small oil passages that go out to the chain groove on each side and clean the entire chain groove. If oil came out of the engine side port ok, then re-assemble the bar and chain, but leave the cover fasteners only finger tight. Tighten the chain so that the chain comes up to the bar, but not so tight that the chain can't be pulled by hand. Tighten the cover fasteners and recheck the chain tension. Make sure the chain teeth cut toward you on the bottom run and that the chain is properly sharpened. Hope this helps!
Jul 05, 2010 | McCulloch Garden
Chain won't rotate
Assuming that you have a fueled engine saw instead of an electric type, remove the drive cover after releasing the chain brake and backing off CCW the chain adjuster screw. Remove the bar/chain and clean the assortment of parts including the small oil passages that are in the drive end of the bar. Wash out the interior of the clutch assembly with spray carburetor cleaner and let dry. Start the engine without the bar/chain and watch for oil oozing out of a small port in the side of the engine case. If nothing, check the oil pump, lines, and valve/filter within the oil tank. If ok, re-assemble the bar, then the chain over the sprocket and out over the bar. Extend the bar out to tighten the chain, and fit the cover to the saw. Tighten the fasteners finger tight, then adjust the chain up to the lower bar edge (the teeth cut toward you on the bottom run) but not so tight that you can't turn the chain by hand. Tighten the fasteners and recheck chain tension. Check chain oiling by running the bar tip at speed near a piece of cardboard for a few moments--it should throw off a thin line of oil onto the board. Hope this helps!
Jun 26, 2010 | Garden
Husqvarna 350 oil not getting to chain
Take the bar and chain from the saw. Clean the two small ports that run from the large oil holes at the drive end of the bar out to the chain groove on each side. Clean the entire chain groove. Start the engine with these parts removed--oil should ooze out from the side port in the engine case with the engine running at med speed. If it doesn't, then there is trouble near the pump inside the case. When everything is back together, run the saw at full speed with the bar tip near a piece of cardboard--it should throw off a thin line of oil onto the cardboard after a few moments of running. Hope this helps!
May 26, 2010 | Husqvarna Chain Saw 20" Bar
Saw isnt oiling enough
take the clutch cover off and remove the chain and bar....clean everything in the output shaft area and unplug the oil holes and you should be good
Feb 05, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Location of bar oiler adjustment screw on p4018wt
THIS WORKED FOR ME....I have a 2014. I've had that problem for quite awhile. I finally decided to try to fix it. I took the bar and chain off, removed all the crud in there. Then I took a small air compressor and blew out the entire area so it was pretty clean. I started the saw at this point and gunned it some. The oil became noticible within a few seconds where it comes out at, above the outer chain bar bolt. Once I found the hole, I then drained the oil tank, and then using the air pump, blew out the hole from the blade area to the tank, leaving the oil cap OFF. Upon refilling the oil tank with a lighter oil (10 wt), I restarted the saw, and the flow was really coming. After the oil; tank empties, I'll start using the regular bar-and-chain oil again, but it's pretty heavy, even though it says it is 30 wt.
JimBo
Nov 09, 2008 | Garden
Chain locked
Can you turn the chainsaw over ( pull start cord s l o w l y .) if not your friend may have seized the engine. ( no oil in fuel, assuming it is two stroke.) then remove the chain and bar ( usually a couple of nuts/bolts) and try turning it over again. If it turns over or even starts, then the chain bar or clutch may need replacing. good luck.
Nov 02, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
52 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
