Question about Refrigerators
Freezer good fridge icing up need thermostat control model WRN33NWB6
  • bazza p May 12, 2008
    thanks for trying but im after the part as i already now its the defrost control switch at fault trying to get the part is my problem
  • 828 Answers
Http://www.whirlpool.co.nz/ifu_download.php
This URL will enable you to download the owners manual for your stated model number.
Posted on May 08, 2008
  • James Helmer
    James Helmer May 13, 2008
    Thermostat controls temperature and defrost control controls the defrost. They are two separate items. Being more specific on your request helps us to help you.
Food freezing in Refrigerator Freezer ok. Westinghouse model wse6100wa. Have misplaced manual and need to know what temperature is correct and how to fix this problem.
There is a normal setting of the thermostat for the fridge and freezer and you can select the fridge setting to be lower than normal than what is set presently.
If there is no change then the thermostat is not cutting off the cooling and so there is no control of temperature within the fridge. Allow the lowest setting of the thermostat in the fridge section to confirm this fault.
Aug 18, 2011 | Refrigerators
Fisher and Paykel N500B fridge freezer. Freezer not freezing
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Oct 28, 2009 | Refrigerators
The freezer works good but the lower refridgerator barely cools
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
OR
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
Oct 02, 2009 | Refrigerators
There is ice forming in the fridge part of the side by side refridgerator. The fridge is making noise, like a motor. it stops once you open the fridge though. Any ideas?
Ice may also be forming in the freezer.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Sep 30, 2009 | Samsung RS2556 Side by Side Refrigerator
Freezer works good, refrigerator does not get cold
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Sep 08, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer is working good fridge is not very cold .make whirlpool
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
OR
Aug 16, 2009 | Refrigerators
MAYTAG REFRIGERATOR ICE MAKER NOT WORKING, AND REFRIGERATOR ONLY COOL WHEN TURNED UP TO HIGHEST LEVEL. FREEZER IS COLD
Is the freezer cold enough to make ice maker operate. 10 degrees or less.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
Jul 03, 2009 | Refrigerators
Freezer works fine but fridge has lost its temperature.
Jul 02, 2009 | Refrigerators
Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
Mar 18, 2008 | Frigidaire FRS26ZSG
Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Oct 24, 2007 | Refrigerators
Refrigerators Logo
143 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
