Question about Frigidaire Dishwashers
How do you hook-up the black and white wires?Also, where is the ground wire?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post back with the model no# for your Frigidaire Dishwasher so that I can assist you further.
Thanks
Rylee
Posted on Aug 29, 2010
I'm looking for help. Installing a Woods 59007 timer. It has 4 wires, red, black, green, white. My current electrical setup is a black, white, and ground wire in the box. How do I hook this up? T
Hook all the white wires together.
Hook all the greens or bare copper wires together.
Hook your hot black to the timer black.
Hook your black wire that goes to your light to the red switch wire.
then try the switch if the light doesn't work switch the red and black switch wires around black to light red to black power.
Oct 19, 2014 | Woods In-Wall Digital 5-10-15-30-Minute...
Can't hook up power cord to main motor on Hoover model F5915100
You have a black and white and green wire. Green is ground white is neutral, black is hot . Should say on the motor either L1 = black wire. L2 = white wire , G = Green wire or it say H = black wire, N = white wire , G or the symbol for ground = green wire
Apr 11, 2014 | Hoover SteamVac F5914-900 SpinScrub...
How to wire light switch?
ok! only hook up the switch to the black wires and cap the 2 whites together. just run 12/2 wiring with ground to switch, hook the black to switch in and black to switch out to light.. cap the white wires to and from switch! you can either hook ground wire to switch or the steel switch box. hope this helps, im not very good with words.
May 04, 2012 | Cars & Trucks
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
I am trying to replace a electric baseboard heater that is 220 volts and I am unsure about the wiring. the heater has a red and black wire and there is a white and black wire coming out of the wall.How do...
if ur are replacing the heater and it was originally 220/240 ur wiring should b ok but to b sure trace the line wire back to breaker panel and look at breaker the white and the black should b hooked up to separate breakers if the white is hooked up to a ground bar usually on the inside side of the panel and the black hooked up to breaker ur line is 110/120 and will cause problems when hooked up. if the lines r 220/240 than red can hook up to white and black to black
Sep 25, 2009 | QMark FBE15002 electric baseboard heater...
Electric trailer brake hookup
Truck Brake control
Red/Black stripe Black
Blue Blue
Lt. Blue/white stripe Red
White White
Orange Not used
Jun 28, 2009 | 2006 Toyota Tacoma
Admiral Clean-O-Matic oven: Power cord black red white ground?
Your terminal block has been by-passed .
Hook your black cord wire to the black screw on the terminal block.
Hook your white wire to the white screw on the terminal block. Hook the bare ground to the exterior ground screw.
The 2 wires that are wire-nutted together will have to hook to the red wire on the cord.(they originally went to the third connection on the terminal).
You will probably have to cut and strip the red cord wire and attach it with the 2 wire-nutted connections.
May 24, 2009 | Ovens
Where do you connect the blue wire
Next time don't lose the instructions.....
Black is your answer...
If just simply hooking the blue and black together with the black from the switch/power supply does not work you need to replace the wire going to the fan with a 12/3 wire(white,black,red,ground) along with a switch, what you have now is a 12/2(white,black,ground)
Here is the following way it should be hooked up using 12/3 romex to the fan from wall switch.
White,Black, ground power supply
Make sure 12/3 is fed to the fan location.
From the power you Y off the black to the red with a piece of red wire to the switch.
Then from the switch is red wire.
Then at the fan red connects to blue, black connects to black, white to white, and ground to ground.
Nov 15, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Dishwashers Logo
49 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
