Question about Whirlpool GD5DHAXVY Stainless Steel Side by Side Refrigerator
I have a Whirlpool GD5DHAXVY model refrigerator that I got a couple months ago and it rocks back and forth, left front to right rear. There doesn't seem to be enough support in the right rear of the refrigerator. I went online to the Whirlpool site and tried to adjust everything they suggest with no success. I don't think the problem is with the floor not being level because it does the same thing when I roll it out. Any suggestions?
huuum
  • 750 Answers
SOURCE: Side by Side Whirlpool Refrigerator: Refrigerator is freezing food
Hi, riverbyfarm
You did try what i would of recommended first!
The resetting of the system by, turning off the controls of the freezer and the fridge first and then unplugging it or if you can't reach the plug, to throw the breaker off for 5 minutes!
That is a possibility in the order that I described!!!!!
Second I ask, is the freezer packed full to the hilt with packages?
In some refrigerators if the frozen food covers the air vents in the freezer cause they are plied sky high and deep in the freezer it can cause a problem.
The freezer and fridge share the air and have to have the vents or passages free so to allow sharing of the cold air!
Let me know if the measures as I prescribed have an affect.
Waiting for your reply!
Bless You Huuum
Please do not forget to enter a rating here before you sign off.
Thank You.
Posted on Sep 21, 2008
  • 198 Answers
SOURCE: Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Posted on Jan 05, 2009
buddymcl777
  • 67 Answers
SOURCE: Whirlpool ED5PHAXSB side by side refrigerator not cooling...
There are a lot of possibilitys. You'll have to use the process of elimination.
But it could be the thermostat (make sure your setting is midway) The milk spoiling indicates it is too warm so bacteria is breeding
Get a refrigerator / freezer stand alone thermostat (about $5) That will give you accurate readings. The fridge shoud be between 35 and 40 F and the freezer 0 plus or minus 3 when set correctly
It could be your condensor fan is clogged or just that your coils need cleaning (underneath or behind) Use a vacuum with the brush end or chisel point. Dust can cut you efficiency by 20 or 30% by itself.
Assuming this is frost free model the defrost timer may be acting up in the freezer.
Forgive me for not knowing where the coils are and if it is frost free but I can't find a manual for this particular model. However the principles apply in any case.
Posted on May 09, 2009
woodchuck789
  • 4070 Answers
SOURCE: Problems with Whirlpool GD5DHAXVY Stainless Steel Side by Side
Your water filter may need changed. On some models, when it's clogged it bypasses to the drip tray. The only other source of water to the tray is during the defrost cycle which happens about once a day and should not fill it up.
Posted on Dec 14, 2009
SOURCE: Noisy whirlpool condensor fan motor
These motors with the plastic fan are apparently failing so often that when I went to the parts store, the owner told me on guy bought 4 replacement motors for his condo complex. Buy the old version of the motor with a metal fan blade. You have to clip off the white connector on the wiring harness and then wire to the new motor using wire nuts (easy). It's a lot cheaper too - $49 for the motor and blade vs alost $100 for the crappy plastic one. Running llike a champ right now!
Posted on Apr 22, 2010
Fridgaire vibrating and moving ahead during spin cycle
Being a new installation it will need its feet adjusting ;-0)
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 30, 2011 | Frigidaire ATF6000ES Front Load Washer
How do I replace the filter in my whirlpool refrigerator, model GR2FHTXT
In the toe grill of your reefrigerator you should find a filter cap that is covering your filter. Rotate this cap to the left 1/4 of a turn you should feel the filter release from the housing then pull the filter out and discard it. Take the Filter cap from the old filter and reinstall on your new filter. Install your new filter in to the housing applying slight pressure turn the filter 1/4 of a turn to the right. You should feel the filter lock in to place. Now with a BIG container go to your water dispenser and dispense about 3 gallons of water.
Sep 01, 2011 | Whirlpool GD5DHAXVY Stainless Steel Side...
G E front load washer makes loud banging noise in spin cycle. rocks back in forth like is not level. What may be the problem?
It probably is NOT level!
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
John C
Jul 30, 2011 | Washing Machines
Putting in the new water filter to the Whirlpool gold fridge that goes in at the bottom.
Removing a water filter from the base grill of your Whirlpool brand refrigerator:
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Dec 06, 2010 | Whirlpool GD5DHAXVY Stainless Steel Side...
Our new Bravos washer shakes excessively during the spin cycle, is this normal for this model?
No, not normal. Bravos don't even vibrate much. First, make sure the machine is sitting level. If it is level front to back and side to side and still shaking, try this simple test, put your hands on opposing corners (right front, left back) at the same time and try to rock it back and forth and then try it on the other 2 corners (left front, right back). If the machine wobbles at all it would cause this issue. This can be cause by a lose leg or leg mounting issue. If all this checks out you should call for warranty service as it could be something internal and you don't want to let it go for a long time.
Jan 23, 2010 | Maytag Bravos MTW6600T Top Load Washer
Dec 14, 2009 | Whirlpool GD5DHAXVY Stainless Steel Side...
Rocking and rolling back and forth
i would check the bushings in the sway bar or the sway bar itself, either way, have fun buddy
Jun 16, 2009 | 1996 Chevrolet Blazer
2005 Montana SV6 right front turn signal not working correctly
might try to replace the turnsignal relay which is under the dash i belive, it is round and looks like a very small container about 1inchx1inch...If you replace that and it does the same thing you have a short in the wiring harnes that leaders from the blinkers to the actuatore, or a bad ground, start by chasing the ground and making sure they are all tightly secures with no bare wire/ or pinched wires anywhere..
Hope this fix's'ya!
May 19, 2009 | 2003 Pontiac Montana
Refrigerator doesn't cool
Might be your condenser which removes the heat from the refrigeration system may be restricted. Clean under the unit from the front and back.
May 06, 2008 | Whirlpool Gold GB2SHDXPS Stainless Steel
Whirlpool GD5DHAXVY Stainless Steel  Side by Side Refrigerator Logo
114 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
