Question about LG KU990 Viewty
I have cracked the lens on the camera and would like to replace it
    Genius:
  • 1,416 Answers
Your location will determine the area that will be very comfortable for you to replace the lens of the camera from any of the LG offices around the world what i will advice you to do now is to visit there web site to locate the best and the closer to your local area like
mobile-t-mobile.com slashphone.com in other to avoid damage on the panel.
or visit any good phone technician around you to fix up the lens
thank you and thanks for using fixay.
Posted on Aug 29, 2010
How do I replace the cracked camera lens on my DroidX cell phone?
Please trust the hands of our expert technicians to resolve this issue. Find out repair/replace instructions following this link:
https://motorola-global-portal.custhelp.com/app/answers/prod_answer_detail/a_id/82507
Regards,
Gaby
Motorola Support
Aug 07, 2014 | Motorola Mobility Droid X
The screen will not show the image. it looks as if the screen is cracked, but there is no crack on the screen. also the zoom will not go in or out. the camera turns on, you can hear it and the lights on...
firts resolve the lens issue
1.- Clean the lens surface with a soft cloth (clean the cilinder body of lens)
2.- Turn OFF the camera.
3.- Gently Push the lens
4.- Gently PULL the lens while you turn ON the camera
Check if the lens go in and out. If the lens don`t move try again step 2 to 4
If the lens move, and the Screen continue NOT image (screen is white) you need replace the lens sensor
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | Kodak EasyShare Z650 Digital Camera
Cant get video out on my gopro after a crash on a hillside. It looks OK at the outside, only some scratches.
I had a cracked lens after dropping the camera, it still worked, just had a fuzzy spot from the cracked lens. I went to Quality Video Components/Rage Cameras and they replaced the lens. The literature on their web page lists other internal repairs they make to GoPro cameras. Maybe they can help you, GoPro doesn't do repairs. www.ragecams.com (wearable video)
But now these cameras are getting so abundant, it may be better to buy one than repair it. The lens was half of what a used camera costs on ebay. Or you can buy just the camera by itself new since you don't need the accessories.
Jul 03, 2011 | GoPro Digital Hero 3 Digital Camera
Monitor shows 'Remove Lens Cap' when it has been removed! the shutter also appears to have failed. Can you advise please?
It appears lens assembly got broke for some reason and need to be replaced. Qualified camera tech will take apart lens mechanism and will replace broken/ cracked part to get camera back in function.
Hope this will help.
Thanks.
Apr 15, 2011 | Panasonic Lumix DMC-FZ5 Digital Camera
Dropped my canon eos350d with 18-55m lens. where the lens attaches to the camera is broken ie the casing along the edge that connects to the camera, hence light is getting in and camera is not functioning...
I'm trying to read this correctly, is it the lens that is cracked or the camera/camera body mount?
If it is just the lens you may find it less expensive to purchase a new lens the 18-55mm is a kit lens and fairly inexpensive to purchase over repairing one. If it is the camera I'm not sure what to suggest and the repair would be very expensive to replace the chassis outer body.
Jan 18, 2011 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
My son dropped our flip camcorder and the lens is cracked
[eBay] has replacement lens for the Flip Video. $15.99 free shipping. Also comes with protective lens covers.
Jan 03, 2010 | Pure Digital Flip Video Ultra Camcorder
The lens cracked. The camera still works but the picture shows cracks. Is it possible to repair it?
The same thing happened to mine. Customer support was useless, telling me I voided my (expired) warranty by breaking it, and that it is not a replaceable part.
Here's the fix that worked for me:
If you look closely at the metal bezel around the lens, you will see a seam between two metallic parts, near the front surface of the lens.Take a knife and gently work it around that seam until you separate the two pieces. They are held together with doublestick tape, so they come apart easily. That will expose the lens which is actually not a lens at all, it's a window; a flat glass disk. Take the tip of a pointy knife and gently pry the glass piece(s) off. Again, this is held on with double-stick tape so it will come off easily. If you can find a glass disc that is the same diameter and thickness, you can place that in. The disc is a 20mm diameter by 1mm thick. You can probably order a replacement watch crystal from somewhere like this place:
http://www.esslinger.com/roundmineralglasscrystalx1mmthick.aspx
They cost less than a dollar (not including minimum orders, shipping, etc), and they are probably more scratch/crack resistant.
If you don't want to bother replacing it, your camera is still fixed, just a bit uglier and vulnerable to dust. The front lens has no optical significance, it's just a dust cover and/or a design element.
The metallic bit you took off is little more than a piece of tin foil.
Had they used a more substantial part that could divert shock instead of directly transferring it to the glass, there would be far fewer cracked lenses out there. But that would probably hurt their "go buy a new one" repair policy.
Jul 12, 2009 | Pure Digital Flip Video Ultra Camcorder
Lens Error
lens circuit got crack replace it
Jun 18, 2009 | Canon PowerShot SD700 IS Digital ELPH /...
LG KU990 Viewty Logo
26 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
