Help whats dose HO6 means on indoor unit
  • 828 Answers
Could be the month by letter and year by number. "H" would be August and "06" would mean 2006.
Posted on May 08, 2008
I have a Haier split type room air conditioner HSU-30HEA03/R2(DB) when I turn it on the display shows E7 what does this mean please.
that mean Communication fault between indoor and
outdoor units. Some wire is cut. check wires from indoor to out door unit. Open indoor unit and check cleme open outdoor unit and check it too
Nov 24, 2017 | Haier Heating & Cooling
We're is master circuit board located on goodman unit
Indoor or outdoor? The one that dose most of the work is located on the indoor if it is a split system.
Aug 21, 2014 | Heating & Cooling
Flashing light the at says e6
Usually Indoor Unit Anti-freezing protection (Cooling
Mode) or Over-heating Protection (Heating Mode)
for Evaporator
A) Indoor room
temperature too low
under cooling mode,
Too high under
heating mode
B) Indoor unit filter or
evaporator too dirty
C) Indoor unit fan motor
blocked
D) Insufficient refrigerant
under cooling mode
E) Indoor unit evaporator
sensor wrong
connection or failure
Jul 28, 2014 | Samsung AQV12VBE Vivace Wall Heat Pump Air...
Panasonic CZ-RTC2 with a fault code E04 does somebody know what that means?
Hi
This error means that your outdoor unit can not communicate with one of the indoor units.
most probably one of indoor units has a trouble.
Oct 22, 2013 | Panasonic CZ-RTC2 Wired Timer/Remote...
What does error code E6 mean? On a Mitsubishi Mr. Slim A/C
Code E6
Error detail Indoor/outdoor unit transmission error (signal receiving error).
Inspected unit Indoor.
Air Conditioning Fault Codes
Aug 01, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
What does error code p8 mean
P8 means Abnormality in outdoor unit.
Check:
1) Wrong wiring of indoor/outdoor
connecting wire
2) Reversed phase
3) Protection device is working
4) Damaged outdoor coil thermistor
Solution:
1) Check the indoor/outdoor connecting wire.
2) Change the connection of electric wiring.
3) Check the protection device.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Hope, helpful.
Feb 03, 2011 | Mitsubishi Heating & Cooling
What is the meaning of fault code. error 02. abnormal on my hitachi remote control for cooling unit rpc 5aq5-p
Indoor/outdoor safety device activated. If your unit stops within 5 seconds, indoor coil sensor defective or short of gas/leak. If your indoor works and but out door unit works for just 5minutes and stops means outdoor coil sensor defective or short of gas or leak. find by amps. If less amps than mentioned, is gas leak/short of gas.
Jan 27, 2011 | Heating & Cooling
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
