Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I purchased an INtex 9 x 18 Rectangular Pool less than a month ago. Th "all in one system" works fine when you select the "FP" (Filter Pump) cycle. However when you switch to the "salt water system" cycle the unit runs a few minutes and shuts down. The service light is on. I did perform all the maintenance suggestions in the manual, but the system continues to shut down within a few minutes. Any ideas?
  • 297 Answers
Service light is not fixable by the consumer
you will need to call intex
they will e-mail you a form fill it out and fax it back to them
you will have a new pump in a few days to your door
it must be under 2 years old and you must have a valid receipt
Posted on Aug 30, 2010
Intex purespa displays current water temp but will not turn on or start filter/bubbles. Bought 1 mo ago: just set it up a week ago. Was working fine for 1 week. TrI'd unplug and reset. Any ideas??
is displayed temp less than 2 degrees than setpoint temperature ? its possible this situation will disallow the pump to go to high speed and the air infusers to work till spa heats back up , or can be a heater fault as well
Aug 15, 2015 | Intex Pool & Spa
How do an intex pump to a non intex pool?
this question has come up before too me , what i respond with is it to be perminate or temporary ? , the reason i ask if its to be perminate then i suggest purchasing the correct filter for the pool, but on temporary situation (to just finish out season) then yes even though the pipe sizes are different , the use of std plumbing home DWV rubber soft connections available at any good hardware/homecenter would work , but heres the temporary part of it , saltwater pool water degrades the rubber making it brittle , but will last a month or so
May 30, 2012 | Intex Salt Water Saltwater System Chlorine...
I have a model 604 - one day the pool pump stopped working i dont know if its the pool filter or just the pump itself (the pool filter is dirty as havnt changed it over for nearly 5 weeks) if i buy a new...
No it won't. I stay in South Africa and bought the pool about 3 months ago. The impeller broke and there are NO aftermarket parts available. Buy a new pool!!! The only way of getting the same pump. I have checked on some other sites and a lot of the guys use a normal pool pump after they have experienced the same problem.
Mar 05, 2011 | Intex Krystal Clear Model 635 Pool Filter...
I got my pump a month or two ago and it worked great but last week it quit working no LCD light or anything. The power going to it is fine but it popped the breaker on the plug when it quit working. Is...
You are not over looking anything.
There are no consumer ways to fix your problem
If you still have your receipt you can call Intex
They will e-mail you a form just fill it out and fax it back
within a few days a new one will be at your door
Aug 06, 2010 | Intex Automatic Salt Water System for ...
How do I hook my 633T intex pump to my 15'x42" pool? The strainers do not attach to the black things inside the pool.
We just cut the holes bigger in the side of the pool, it works great now. Just got to make sure you do not cut it to big! I do nnot understand why they can"t make it standard.
Hope this helps!!!!!!
May 18, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Will not pump when it has a filter in it
filters are too good for pump system.
These pool pumps seam to over heat fast, no quick fix.
* Try getting more air flow around pump.
* Only use pump when using pool or near by.
* Use a pool cover - will help stop dirt/rubbish getting into pool - less to filter.
Jun 02, 2009 | Intex Easy Set 1500 Gph Filter Swimming...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
274 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
