Looking for a schematic for a HP 200CD tube osc test equipment
    President:
  • 2,712 Answers
Try here:
http://sharefx.com/
http://www.eserviceinfo.com/
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 07, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Loud static noise in drive channel. gets worse in more drive. Plays fine in clean channel. Drive channels do not seem to work. Amp is Hot Rod Deluxe 40W
The thing you can try is to swap tubes V1 and V2 which are 12AX7's... if major change occurs including loss of any signal, replace the one that WAS in V2 position.
More than this gets into the electronics and if you don't have test equipment it is not a DIY thing so you would need to take it to a shop. There are several components including FET's Q1 and Q2 and what looks like BAD engineering design around these particular parts that could cause the problem.
The bad engineering looks like tinkerers designed the circuit rather than an engineer. Gates of these FET's are left floating on the end of a 1N4148 diode according to my schematic... I have seen MUCH poor engineering or lack of in a lot of the audio equipment.
Dec 08, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Yamaha T100C Amp ...volume cuts out after 5 minutes.
Hi...
Looks like a tube amp.
Get the tubes tested. The tubes themselves should have a dark chrome appearance on the tops and maybe a couple spots on the sides. If there's any gray or milky appearance , then the tube is bad.
Let me know how you fare
Jan 24, 2010 | Audio Players & Recorders
My amp fell forward and the (knob side) hit the ground. Now there is no sound, but everything lights up.
You have probably broken some of the pots. You will need to take it in to be serviced or if you have experience take the amp apart and take the circuit board out. Examine the solder side where the control pots are. Hopefully you didn't break the pots themselves and the solder joints just need to be redone. Also look for broken traces near the pots. They look like little roads which they are for electrons.If they are broken you can bridge them with short pieces of tinned wire and if the circuit board is cracked it can be Crazy glued. Look for all the broken parts and don't miss any. If the pots are broken, Take the broken ones into an electronics supplier and ask for exact replacements. If its a tube amp look for tubes that are loose in their sockets and broken tubes. Absolutely do not work on the amp with it plugged in to the wall (no power running to it) If its anything worse than that, take it in to be repaired as you need schematics, test equipment and direct replacement parts to do a proper job. Hope this helps.
Aug 27, 2009 | Music
Vertical roll
I get Vertical roll on my Apex AD1000 DVD player and need a schematic. I don't know where to get a schematic but I have the necessary test equipment to troubleshoot the problem. Do you know where to get a schematic or know what causes the vertical roll problem?
Solution:
Program the setup menu screen to NTSC instead of "PAL" or "Auto"
Oct 05, 2008 | Apex Digital AD-1110W DVD Player
Blurry, purple cast to picture.
check the crt cap that is connected to your picture tube...it may be greenish inside...try to change the crt...and adjust the focus...
Sep 03, 2008 | Zenith Z25X22S 25" TV
Plug in tv and doesnt work
If you have no Tv repair experience, how do you know what part this is?, as I dont have a clue as you didnt supply a schematic or a picture of what the part was. We techs have a trade we learned not by doing but by going to school to learn the theroy behind the circuits. If you know how to read a schematic diagram, i suggest that you get one and know what part it is that you think you found burnt out. If you go to http://www.servicemanuals.net, download a service manual or schematic diagram, i will assist you in this repair as long as you have the proper equipment such as a mutimeter and know how to trouble shoot solid state electronics. Its not a tube you can take out and test or a board that can be exchanged anymore my freind. Its down to the componet level these days.
Sep 23, 2006 | Mitsubishi VS-50605 50" Rear Projection...
 Grubhead
Grubhead
