Question about Toshiba M655 VHS VCR
I can not get the line in input to work. there is no L1 on the channel selector.
    Guru:
  • 276 Answers
To record from the line input, there is a button on the VCR's remote called INPUT SELECT. Press this button to get your line input. You press it once to select and again to cycle thru the selections. If you have a L2 input, pressing the button again will go to this input and so on.
Posted on Sep 02, 2010
  • inyo55 Sep 16, 2010
    Can input be changed without a remote?
I have tv westinhouse not have channels
CHECK THE CONNECTOR INPUT SELECTOR CHANNEL THAT IS NOT DAMAGED CHECK THE CABLE CONNECTOR COAXIAL. AGAIN MAKE CHANNEL SCAN., BUT GET NO TUNE CHANNEL. SURE THAT OTHER VIDEO INPUTS., HDMI & USB OPERATING NORMALLY, IF THIS IS OK., MUST REPLACE CHANNEL SELECTOR OR LAST CASE NOT FIND REPLACEMENT., REPLACE THE MAIN BOARD., IN SOME CASES THE CHANNEL SELECTOR COMES AS PART OF THE PRINTED CIRCUIT., THEREFORE TO REPLACE THE MAIN BOARD.
Aug 20, 2014 | Westinghouse 46? 1080p Led Tv ld4680 /...
Bose l1 classic troubleshooting, #1 CHANNEL IS NOT PUTTING OUT AS MUCH VOLUME AS CHANNEL #2
If the input sources for Channels 1 & 2 are the same, adjust the input Trims to get the same output. Then use the R1 Remote.
L1 Model Bose L1 Encyclopedia FAQ Wiki
Jan 25, 2014 | Bose L1 Speaker
Connect Mackie Profx12 to L1 Model II
On the Mackie ProFX12 pan all the inputs to the LEFT and take the LEFT output and ran that to the Model II Power Stand Analog Input. Here is an article with all the details.
Stereo Mixer to Mono L1
Dec 19, 2013 | Mackie ProFX Series ProFX16,...
My remote control's input select button wont work.....how do i do it manually?
Not sure about this particular TV, but usually, you select inputs by channel selector. Go to Channel 1 on TV not Cable or dish, Use the channel selector button on the set itself, go down from 1. You should see somthing like Aux or Line, then aux 2 or Line 2 etc.. eventually (3 clicks or so) rolling around to ch 115. But usually between the highest ch on the set and ch 1 are the auxillary input selections.
Nov 11, 2010 | Emerson EWF2004 20" TV
Panasonic PV-9451 VCR, When setting up the VCR to record a channel, the only channel options are Channel 02 thru 25 and L1 And L2. What has to be reset with the digital cable input??
You will need to use L1 or L2 (one is probably on the front of the VCR, and the other on the back, they should be labeled).
YOu need to plug the digital receiver's output into L1, or L2, and set the VCR to record the one you're using. Then set it to the time you want, and then set the channel on the digital box tho the one you want.
One Channel, One time. (or recurring daily, if your VCR allows daily recording from L1,2)
Jun 13, 2009 | Televison & Video
How do I record a TV Program.
Video & Left,Right audio go out of Comcast cable box to L1 input on DVD recorder,Video & Left,Right audio go out of DVD recorder to a line input of your TV.  Record L1 input on DVD recorder.
Jan 10, 2009 | Panasonic DMR-E80H DVD Recorder
Channel selection
L1 and L2 are just line inputs. This unit does not have a tuner so there are no channels to select.
It requires you to be connected to a TV broadcast via a cable or satellite tuner box... and then would only record what ever channel you were viewing. The DVD is a player only.
It sounds like you should have purchased a DVD Recorder or a DVD/VCR Recorder. The players normally do not have a tuner. A Recorder should have an built-in digital tuner. Some also have the old NTSC tuner and may also have a QAM tuner.
Nov 12, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Line in is stuck on my samsung combo tv
If you cant get the TV off Line In, use the remote or channel up, it should go to ch2. If not, unplug TV for 30 minutes and try again. You may have to have an antenna or source that is active on another source to be able to change off L1. Sony TV's have a menu option that allows you to activate or deactivate other inputs so maybe L1 is the only input that is active.
Feb 17, 2008 | Samsung CXJ1964 19 in. TV/VCR Combo
EWV404 PROBLEM WITH "l1" INPUT
go to the menu and select auto find or auto program channels.
good luck
please mark the post with a fixya!
Feb 06, 2008 | Emerson EWV401 S-VHS VCR
Recording from cable
L1 and L2 are different inputs on the VCR.If you have red, white and yellow input on the front of the VCR then when you put the VCR on L1 it should pick up a signal from the front.To get more channels on your vcr you want to do an autoprogram make sure the cable from the wall is plugged into the input in the back and go to the menu on the VCR and look for channel search or auto program and start the search.usually you can find this setting under something like SETUP, Programming,settings on the main menu of the VCR.You may have to search in the menu of the vcr for a little bit until you find it.Youll know when you got it when the channels automatically start scanning from 1-98.GOOD LUCK and rate me if this fixesya or is helpful.
Nov 16, 2007 | Lands Phones
Toshiba M655 VHS VCR Logo
296 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
